 Old 10-28-2013, 01:36 AM   #1
speed3sailor's Avatar
Posts: 835   (View Stats)
speed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the world
Default EWG w/ stock manifold
Alot of you probably have seen @h.h.sk1nny; s thread about running the BNR S3 EWG with the stock exhaust manifold. He is now going back to pursue a K04 11sec 1/4 mile so i ended up with his BNR. The internal wastegate is welded closed so i started working on making my manifold EWG also. Let me start by saying that the cast iron is a pain in the butt to cut through. It doesnt really help that i dont have the right tools to cut it with though. He said he used a hole saw to cut it but that didnt work very well for me. I ended up using a step drill bit and some time with a dremel. I then used a piece of 38mm forged iron tube that i found at a local harware store. Only about 1 or 1.5 in of it was used. I had to dremel the bottom to match the exhaust manifold since it is curved. Then i had the Vband flange that came with my EMUSA EWG welded onto the pipe and the pipe welded onto the manifold. The welds look pretty good. I am located in Italy so i had to get some guy that spoke very little english to weld it up for me and he used a stick welder. we will see how long it lasts.
I ended up using a cutting wheel to go back and cut off all of the stock heat shield mounting points because the welder couldnt get to one spot very well and i wanted to wrap the whole thing in heat wrap. After the cutting wheel, i went back with a grinder and after the grinder i used a dremel again to make it all smooth.
This is the first thing i have ever heat wrapped and i think it went pretty good. i was going to cut out the metal between the first 2 runners but ended up saying screw it and just wrapped them together. I was going to wrap around the entire thing but realized it would be good to be able to make sure the welds are not cracking. I ended up painting it also.
I have to get the angle of the dump tube changed to clear the downpipe but other than that, it is done.
07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17
speed3sailor is offline   Reply With Quote
The Following 19 Users Say Thank You to speed3sailor For This Useful Post:
Andrewbox (12-31-2013), atvfreek (11-22-2013), ckMS3 (10-28-2013), Code Monkey (10-28-2013), CWP_MS3 (10-28-2013), Easter Bunny (06-07-2015), Enki (10-28-2013), ESA (12-03-2013), h.h.sk1nny (10-28-2013), jdmage_mx5 (10-28-2013), Jsn_Rob (11-23-2013), killer-ms3 (10-28-2013), LatinKraze (08-17-2014), Micha (08-09-2015), rfinkle2 (10-28-2013), sidekick (12-31-2013), stanley0910 (11-23-2013), superskaterxes (10-28-2013), Swinger13 (10-28-2013)
 Old 10-28-2013, 09:25 AM   #2
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Looking good buddy!!! This setup is freaking sweet!!! EWG is gonna put a massive grin on your face lol. Let me know if you need any help with anything. Running lines for the 3 port is super easy too. Have fun with it
h.h.sk1nny is offline   Reply With Quote
The Following 3 Users Say Thank You to h.h.sk1nny For This Useful Post:
Micha (08-09-2015), rfinkle2 (10-28-2013), speed3sailor (10-28-2013)
 Old 10-28-2013, 10:53 AM   #3
Thanks. I can't wait to get it running again. Thanks for all the help.
The Following User Says Thank You to speed3sailor For This Useful Post:
 Old 10-28-2013, 01:25 PM   #4
If anyone is interested in what parts were used or have any questions on how to do this, let me know.
 Old 11-22-2013, 01:17 PM   #5
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Post a video yo!
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 11-23-2013, 02:22 AM   #6
Post a video yo!
It's still not up yet. I'm starting to go nuts. It's been 2 months. I'm waiting on my FMIC still. It should be up by next weekend. I'll post videos soon.
The Following 2 Users Say Thank You to speed3sailor For This Useful Post:
bstover17 (01-01-2014), Micha (08-09-2015)
 Old 11-22-2013, 01:11 PM   #7
truredms3's Avatar
Posts: 429   (View Stats)
truredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the worldtruredms3 is the leader of the world
Groaned at 6 Times in 4 Posts
i might need your knowledge with this im planning on doin this very soon.
truredms3 is offline   Reply With Quote
The Following User Says Thank You to truredms3 For This Useful Post:
speed3sailor (11-23-2013)
 Old 11-22-2013, 01:18 PM   #8
truredms3's Avatar
Have you been running this yet ? How's it holding up if you r
Sent from my SGH-T999L using Tapatalk
 Old 11-23-2013, 02:44 AM   #9
Da6d's Avatar
Posts: 927   (View Stats)
Da6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the worldDa6d is the leader of the world
Groans: 87
I love external wastegates. I'm curious to hear a DISI ewg. (In person) I too will be ewg on the 6 just waiting. My expectations are kind of in the middle, the last ewg setup I had was:
I'm hoping the DISI sounds even half as good. Post up that video!
Da6d is offline   Reply With Quote
 Old 01-01-2014, 10:42 AM   #10
R33 Skyline GTS25T Open wastegate/screamer pipe 38mm tial - YouTube
That's about how it sounded on spring pressure. Now that it's cranked up, it sounds different
 Old 11-23-2013, 05:41 AM   #11
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I wouldn't count on those welds lasting long. Welding on cast iron is almost a guarantee of cracks.
07 MS3
The original Genpoo Hater
 Old 11-23-2013, 06:46 AM   #12
we will see. H.H.sk1nny has been running his for like 6 months. The welds on mine look much better than his(not talking trash) and were done by a professional who welds cast iron frequently. This is not a permanent mod and I suspect it will hold up longer than I plan on using it.
If it does crack. I will post that on here as well. I wont try to hide it.
The Following 7 Users Say Thank You to speed3sailor For This Useful Post:
bstover17 (01-01-2014), Da6d (11-23-2013), Easter Bunny (06-07-2015), h.h.sk1nny (11-29-2013), SLOWHATCH (11-30-2013), stanley0910 (11-23-2013), truredms3 (11-23-2013)
 Old 11-29-2013, 11:03 PM   #13
h.h.sk1nny's Avatar
^True story. I have been running a good solid 6months, issue free. I actually just plopped a stock k04 back in and got a thorough inspection on my bird turd welds. Still looking ugly, but no cracks at all. A lot of old school guys think it is impossible to weld cast iron, but it has come a long way. They have welding rod that is meant for cast iron. Few tricks like heating up the piece being welded and cooling it off in the sand will help how long the weld lasts too; I did neither.
Micha (08-09-2015), speed3sailor (11-30-2013), truredms3 (11-30-2013)
 Old 12-31-2013, 08:55 AM   #14
so, ive been running this EWG setup for about a month now. It is working great now that I got a new Tial wastegate. The EMUSA wastegate didn't work out for me. Here is what my setup looks like now.
The Following 4 Users Say Thank You to speed3sailor For This Useful Post:
Andrewbox (12-31-2013), ckMS3 (12-31-2013), Code Monkey (12-31-2013), Micha (08-09-2015)
 Old 12-31-2013, 09:14 AM   #15
GOT 2RBO's Avatar
Posts: 355   (View Stats)
GOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the worldGOT 2RBO is the leader of the world
videos and more info!!
GOT 2RBO is offline   Reply With Quote
The Following User Says Thank You to GOT 2RBO For This Useful Post:
speed3sailor (01-01-2014)
 Old 01-01-2014, 10:30 AM   #16
ill post videos soon. this thing sounds crazy. its making some good power though.
here is a comparison of the K04 vs BNR S3. im still in the process of tuning. more power is to be had.
 Old 01-02-2014, 08:28 AM   #17
LatinKraze (08-23-2014), rob ms6gt (01-12-2014)
 Old 01-06-2014, 09:29 AM   #18
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
I love the sound of that ewg flutter!
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
The Following 2 Users Say Thank You to Status Update For This Useful Post:
Cheapspeed (05-25-2015), speed3sailor (01-06-2014)
 Old 01-06-2014, 10:56 AM   #19
I love it too. Especially in the first couple gears when I'm spinning and the dump tube is shooting out all kinda of crazy flames and popping and stuff. I need to extend the tube a little bit so it's flush with the bottom of the car though.
Hess22 (04-22-2014), Status Update (01-06-2014)
 Old 08-23-2014, 01:56 PM   #20
ciezczak1's Avatar
Posts: 416   (View Stats)
ciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the world
How are the welds holding up on the ewg?
sent from the s5
GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port
ciezczak1 is offline   Reply With Quote
 Old 08-23-2014, 03:08 PM   #21
Still going strong. No cracks or issues of any kind.
 Old 08-23-2014, 03:32 PM   #22
LatinKraze's Avatar
Posts: 804   (View Stats)
I'm planning on doing this. Thanks for the vids. Sounds wicked
2016 CX-5 GT AWD
 Old 09-16-2014, 09:50 AM   #23
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Bumpin dat old thread. I'll be doing this soon. Tial MVR 38mm on a BNR S2. What flange did you use?
 Old 09-16-2014, 11:13 PM   #24
one that comes with the Tial plus a small amount of tubing that was welded to the manifold to raise the flange a half inch or so because its hard to put a flat flange on a round runner.
in the original post i said that i used the vband flange that came with the Emusa wastegate but that wastegate was a POS and when i got the Tial, i swapped out the flanges just to make sure everything sealed good.
Gr8Speed (09-17-2014)
 Old 05-24-2015, 08:59 AM   #25
speed3freak89's Avatar
Posts: 49   (View Stats)
speed3freak89 is a splendid one to beholdspeed3freak89 is a splendid one to beholdspeed3freak89 is a splendid one to beholdspeed3freak89 is a splendid one to beholdspeed3freak89 is a splendid one to beholdspeed3freak89 is a splendid one to beholdspeed3freak89 is a splendid one to behold
@speed3sailor i am interezted in doing this looked over your setup several times. What did u spend in the build for the materials.?I know its been a while since post did anything go wrong with it?
speed3freak89 is offline   Reply With Quote
 Old 05-29-2015, 02:43 PM   #26
the only thing I had issues with was with firewall clearance. I would get whoever is doing the welding for you to just spot weld it and then check fitment. I still don't have a ton of clearance but have never had issues with it touching the wall. its been a year and a half and going strong.
 Old 05-24-2015, 10:05 AM   #27
MSP6's Avatar
Posts: 1,246   (View Stats)
Old ass post bump FTL but meh....
you have to add a ; to the end of your mention.
@speed3sailor;
The Following User Says Thank You to MSP6 For This Useful Post:
Vansquish (05-25-2015)
 Old 05-24-2015, 10:52 AM   #28
@MSP6; I know its a old thread but i am interested in his EWG build on stock manifold. Been something i ben wanting to do since i uograded my turbo.
 Old 05-24-2015, 11:57 AM   #29
MSP6's Avatar
@Vansquish; I had to to tag you...
Also @speed3freak89; No biggie, which is why I said "meh". I'm forced to work 6am-6pm today and I'm bored as shit so I was hoping OP had updated this with something to entertain me for a few minutes.
 Old 05-25-2015, 11:45 AM   #30
Police - Grammarhead
Vansquish's Avatar
LMAO..."interezted"
 Old 05-25-2015, 12:06 PM   #31
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
Good work! Nice to see someone trying this with the stock mani. Hell if it fails a used one shouldn't be hard to find. Fingers crossed for you!
 Old 05-25-2015, 12:42 PM   #32
@ SuckSqueezeBangBlow; another member has done it as you can see by pics. I am planing on buying used stock manifold off ebay. Found a couple for $90. Im gonna do my EWG project on that incase something happens i still have my stock manifold. As soon as i get the used manifold and a EWG i will get on with the build. I will post pics of build.
 Old 05-29-2015, 08:13 PM   #33
@speed3sailor; thanks for that info. I will be doing all the work myself. I will definately keep that in mind.
 Old 06-06-2015, 06:50 PM   #34
Finally got Tial Wastegate and welded it in manifold. Looking for a better way to keep the old IWG valve on exhaust housing closed. I got it closed but i am wondering what orhers did . I dont want to weld it closed incase i need it in future if anything were to happen to the EWG.
The Following User Says Thank You to speed3freak89 For This Useful Post:
Code Monkey (06-06-2015)
 Old 06-06-2015, 06:55 PM   #35
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Doesn't Cobb make an adjustable IWG bracket so that you can keep it closed all the time?
 Old 06-06-2015, 08:50 PM   #36
joeyspeed3's Avatar
Posts: 82   (View Stats)
joeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant future
Yep they do lots of people use it go check them out
2013 CWP Mazdaspeed3
Bnr S3 v2//Cobb AP//Autotech internals//3 BAR MAP sensor//3 port EBCS//CNT catback//Ebay catless DP//Tr8 core with cxracing piping kit//Hks bpv//Jbr True 3.5" intake//Jbr ssp//Jbr shift knob//Jbr Trilogy//XXR 527 habanero 18x8.75 +35//H&R springs//385/370 AWD mustang dyno
joeyspeed3 is offline   Reply With Quote
 Old 06-06-2015, 09:00 PM   #37
TRBLSM's Avatar
Posts: 73   (View Stats)
TRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond repute
You can just take weld the flapper closes and disconnect the actuator arm. Only need to grind the tack welds to revert back. Or go the cobb bracket
Tapatorque steering
2006 True Red 3 MPS - Top Mounted 5858 in progress
TRBLSM is offline   Reply With Quote
 Old 06-06-2015, 11:19 PM   #38
LatinKraze's Avatar
Holy shit! Is that how you're leaving the dump tube?
2016 CX-5 GT AWD
The Following User Says Thank You to LatinKraze For This Useful Post:
speed3sailor (06-14-2015)
 Old 06-06-2015, 11:22 PM   #39
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
So many things wrong in that picture
The Following 4 Users Say Thank You to Etipp98 For This Useful Post:
Easter Bunny (06-07-2015), jdmage_mx5 (06-07-2015), speed3sailor (06-14-2015), SpeedRebirth (06-07-2015)
 Old 06-07-2015, 08:25 AM   #40
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I thought the exact same thing when I saw it.
Dump tube in terrible spot
Oil catch is in a terrible spot
No clamp on MAF housing to intake coupler
Air filter is so dirty it's probably performing worse than stock
I'm sure there are a few other things I'm failing to mention. I will solute you though on the EWG on stock manifold; just extend the dump tube down to keep the fireballs out from under the hood.
Etipp98 (06-07-2015)
Page generated in 0.62371 seconds with 40 queries
