 Old 03-29-2008, 07:54 AM   #1
speed3's Avatar
Posts: 504   (View Stats)
speed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant future
Groans: 56
Groaned at 43 Times in 21 Posts
Default Exhaust Leak
I just installed my turboxs downpipe. I have a very bad exhaust leak at the end of the downpipe that connect to the 2nd cat. It sound like they are snakes under my car. how would this effect the performance of the car. Is it like a boost leak? I'm gonna get it fix on Monday anyways. I am also running straight pipe all the way to the back.
speed3 is offline   Reply With Quote
 Old 03-29-2008, 08:13 AM   #2
Loosen up the mid pipe and reseat it into the socket in the bottom piece of the down pipe. Be sure you crank down the two spring bolts evening...
 Old 03-29-2008, 09:14 AM   #3
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
and its not like a boost leak.... your leaking exhuast, boost is fresh air.
Page generated in 0.24173 seconds with 21 queries
