 Old 01-19-2011, 05:04 AM   #1
Feargod69's Avatar
Posts: 64   (View Stats)
Feargod69 has a spectacular aura aboutFeargod69 has a spectacular aura about
Default Exhaust gasket
When you instaled your downpipe, did you changed the gasket between the turbo and the dp. At mazda, it cost about 95$ cad.
Anyone can answer this question..
Thank you
Insured, taxed and tested, Go chase real criminal!
Cobb catted downpipe, corksport cat-back, CP-E CAI, PG turbo inlet, CX Racing FMIC, Cobb Accesport w/ Stage2+MSCAI2 91 v108, Denso ITV22 spark plug, Weapon R Oil catch can w/ 2nd PCV valve, TRZ dog bone rear engine mount.
Feargod69 is offline   Reply With Quote
 Old 01-19-2011, 05:09 AM   #2
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
no mine was fine..and you can get same gasket for much cheaper than the dealer
i believe this works and its 30 on su..probably even cheaper if looked around more
edit: i had link fail, su sells msp gaskets looks same tho
PERM TUNED
 Old 01-19-2011, 04:56 PM   #3
jeb8699's Avatar
Posts: 122   (View Stats)
jeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to behold
i didnt replace mine on my 6
jeb8699 is offline   Reply With Quote
 Old 01-20-2011, 05:59 AM   #4
Feargod69's Avatar
looks like iwont change it then... but what was the millage on the car when you replace it
 Old 01-20-2011, 06:08 AM   #5
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i've done a few downpipes, only replaced that gasket once and that was because lenny wanted to.
mileage was anywhere between 16k and 60k
 Old 01-20-2011, 02:14 PM   #6
jeb8699's Avatar
i think i was like 37k mi
 Old 01-24-2011, 10:28 AM   #7
Feargod69's Avatar
thank for the info
 Old 01-24-2011, 10:56 AM   #8
Gatorbait's Avatar
Posts: 125   (View Stats)
Gatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant futureGatorbait has a brilliant future
I'm about to replace my DP, and picked one up from Mark @ SU for like $35.....probably won't need it, but figured it's cheap insurance just in case. I don't want to through the install and THEN find out after that i have an exhaust leak.
'06 MazdaSpeed6 Current Mods: COBB SRI, COBB Inlet, Cobb AP, SU RMM, ETS TMIC, Ebay DP, SU Shifter Bushings, JB short shifter plate,Stoptech D/S rotors with EBC redstuff, Bilsteins w/Eibach springs. On the Horizon: need moar moniez
Gatorbait is offline   Reply With Quote
 Old 01-24-2011, 10:56 AM   #9
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
I did not replace mine. I've never replaced it any of the times I've had the turbo or DP off. I don't see any reason to do so. It's friggin metal.
 Old 01-24-2011, 01:19 PM   #10
Feargod69's Avatar
i guess it a question on how comfortable u are without changing it
 Old 01-24-2011, 03:46 PM   #11
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
If you don't want to buy one, just use Copper RTV. That stuff is amazing. Lots of high power turbo guys don't bother with gaskets...
 Old 01-25-2011, 08:04 AM   #12
Feargod69's Avatar
good to know thanks
 Old 03-03-2013, 09:18 PM   #13
abaker92's Avatar
Posts: 10   (View Stats)
abaker92 is a glorious beacon of lightabaker92 is a glorious beacon of lightabaker92 is a glorious beacon of lightabaker92 is a glorious beacon of lightabaker92 is a glorious beacon of lightabaker92 is a glorious beacon of light
Groaned at 3 Times in 1 Post
I would like to buy a gasket for 35 dollars. I'm replacing my turbo back exhaust.
abaker92 is offline   Reply With Quote
 Old 03-04-2013, 07:32 PM   #14
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Hey man, welcome to the forum. You may want to check out some of the new member threads and resources in the new member sub forum. They have alot of good info.
That tubo to downpipe gasket is pretty expensive, I have replaced it twice. I generally get my original Mazda parts from "Mazda Parts" | Mazda Accessories and you can find my oem part number thread in the Mazdaspeed 6 engine and transmission subforum, it is stickied near the top. Alot of ms3 and ms6 parts are the same and this gasket is shared between both cars.
By going VIP you have access to alot more of the forum including a for sale section where you can pick up parts for really good prices.
2006 Mazdaspeed 6
 Old 03-05-2013, 01:15 PM   #15
cuda's Avatar
Posts: 8   (View Stats)
cuda will become famous soon enoughcuda will become famous soon enough
No need to replace it. Its a multi layer gasket, just like a Cometic. I bought one not knowing this from SU, think it was about $50.
2008 speed3
Hypertech tuned...cause I dont wanna go fast
but when I do.......
72 Barracuda, 9 sec. N/A 3500 lb. pump gas street car.
60 ft. 1.36
1/8th 6.17@110.8
1/4 9.73@136.9
full int. full exh. DOT drag radial
cuda is offline   Reply With Quote
 Old 10-23-2014, 09:36 AM   #16
jerihaly's Avatar
Posts: 5   (View Stats)
jerihaly has a little shameless behaviour in the past
Default gasket leak
I did the down pipe and fudged the threads in the turbo up, took the turbo off and just cleaned the threads with a tap. I put everything back together and while driving, heard a whiney noise under boost, quite positive its the manifold to turbo gasket. I picked one up for $20 and put it on, still making the noise. Should I have sanded the surfaces first? Or could it be something else?
jerihaly is offline   Reply With Quote
The Following User Says NO Thank You to jerihaly For This Un-useful Post:
Turbo_Steve (10-23-2014)
 Old 10-23-2014, 06:11 PM   #17
AshFromCan's Avatar
Posts: 295   (View Stats)
AshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the world
You should watch out or you will get banned doing this. Putting the same post in multiple threads even dead ones that are years old. Then you'll be out a great source of information. Sorry I can't answer your question though.
2013 White MS3
Power |Cobb V3 AccessPort| |Ultimate Racing TBE w/ V2 DP| |Cobb FMIC| |Cobb SRI/TIP| |Autotech HPFP Internals|
Supporting |Cobb RMM| |Cobb Shift Weight|
AshFromCan is offline   Reply With Quote
 Old 03-03-2013, 09:25 PM   #18
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
please don't revive 2year old posts with bs
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
warlockfan92 (03-03-2013)
 Old 10-23-2014, 11:51 AM   #19
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
I bought a new OEM turbo-dp gasket from mazda-parts.com. I also utilized Grimmspeed's Subaru multi-layer gasket for the downpipe to CBE connection. Worked perfectly.
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
 Old 10-23-2014, 06:03 PM   #20
mxlplx71's Avatar
Groans: 128
I just saved a bunch of $$ on my car insurance
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
bpv gasket boosthead MazdaSpeed 3/6 - Turbo Induction 3 08-01-2010 05:19 PM
help with exhaust gasket johnnybochamp MazdaSpeed 3 - Engine, Transmission & Driveline 2 07-06-2010 05:08 PM
BPV gasket? Zeya MazdaSpeed 3/6 - Turbo Induction 18 05-13-2008 06:18 PM
Page generated in 0.39663 seconds with 33 queries
