Like Tree8Likes
 Old 08-13-2015, 02:59 PM   #1
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I just got this reply on my GTX warranty. Started blowing through quarts of oil within 2k miles.
"We did complete the inspection and testing on your turbo unit.
What we found was that the unit is 100% good and is per factory spec.
The ball bearing turbos are more sensitive to the breather/PCV/oil drain issues than the journal bearing BNR unit that you're running now.
I'm going to have to make a couple of installation changes and you will see the issue go away on your car:
1. I'm going to recalibrate the oil supply port at the turbo.
2. I'm going to send you a NEW banjo bolt to use at the oil feed port on your turbo. If you still have the old one, please throw it away."
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
Garrett m33 turbo skiptowncat MazdaSpeed 3/6 - Turbo Induction 9 08-14-2012 03:41 PM
Who DOESN'T run a Garrett turbo Ezekiel81923 2010 MS3 - Turbo Induction 138 08-02-2012 05:20 PM
GARRETT 3" Turbo Inlet Pipe Kit Blackedout1978 2010 MS3 - Turbo Induction 3 03-13-2012 01:51 PM
Failed Thread essejkcamraw MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 57 11-17-2010 11:16 AM
Page generated in 0.25060 seconds with 22 queries
