Like Tree12Likes
 Old 10-13-2015, 03:37 AM   #361
Residual oil in exhaust. Or you are burning oil and it's motor time. Time for a leakdown test.
lincam182 likes this.
lincam182 (10-13-2015)
 Old 10-13-2015, 05:03 AM   #362
lincam182's Avatar
Posts: 24   (View Stats)
lincam182 has a spectacular aura aboutlincam182 has a spectacular aura about
I doubt it is residual in the exhaust, since I have new turbo, downpipe and cat back exhaust. I need to do a research on leak-down test and see what is it and how is it done.
lincam182 is offline   Reply With Quote
 Old 03-20-2016, 12:51 AM   #363
Speedie6's Avatar
Posts: 1,838   (View Stats)
Sorry to bump an old thread. But, I was just trying to understand how this change is supposed to work. I understand the valve cover was redesigned to do a better job of keeping blow-by out of the breather line. I get that.
What I don't understand is, what value is changing the location of the breather attachment? I suppose it might have slightly different suction characteristics. Maybe more suction, maybe less. What was the goal they were reaching for? Just trying to understand what it did. Thanks.
360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust
The Following User Says Thank You to Speedie6 For This Useful Post:
pittsburghmazda3 (04-07-2016)
 Old 04-07-2016, 12:24 PM   #364
pittsburghmazda3's Avatar
Posts: 26   (View Stats)
pittsburghmazda3 is a jewel in the roughpittsburghmazda3 is a jewel in the roughpittsburghmazda3 is a jewel in the roughpittsburghmazda3 is a jewel in the rough
I just read through most of this thread. Having a similar issue. Car is an '09 MS3 w/ 85k miles (out of warranty) lightly modded (CPE SRI, TIP, cat back and test pipe. I smoke at idle, and also like a mofo between shifts. Consuming a lot of oil as well (prob at least a quart per gas tank).
Tried 5w40 Rotella as well as the Bnoon bolt, and absolutely no change. Car has been parked since August and I don't drive it anymore cause the smoke is so bad.
Took off the intake to check things out and there were pools of oil in the intake tract. Also tried running the car with just a breather filter on the valve cover and capped off the connection in the SRI, and still having the same issue.
The only other thing I can think of is rings, but that still doesn't explain all the oil in my intake (before turbo).
Anyone think this TSB would help me out (haven't seen anything about people smoking between shifts) or would I just be wasting my time?
[SIGPIC]http://i721.photobucket.com/albums/ww216/pa2vbms3guy/Untitled.jpg[/SIGPIC]
pittsburghmazda3 is offline   Reply With Quote
 Old 04-07-2016, 12:36 PM   #365
Dommo14's Avatar
Posts: 694   (View Stats)
Dommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the world
Sounds like time for a BNR hommie... your turbo seals maybe leaking.
I'm stock bro.
Dommo14 is offline   Reply With Quote
 Old 04-07-2016, 12:46 PM   #366
That's one other suspect I forgot to mention.
The only thing that confuses me, is I had a small pool of oil in front of the turbo, where the rubber coupler from the TIP clamps to the compressor inlet. If the seals were bad, wouldn't most of the oil be located after the turbo?
 Old 04-19-2016, 05:57 AM   #367
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
sir if i may say^^
I think you are confused, the oil in the intake and pre turbo has nothing at all to do with seals... but exactly the venting this whole thread is about, i believe what you see is the crank case vent line oil that collects in our intakes... if it bothers you too much, get a OCC
also another thing to mention since you seem to be confused(i dont blame you) but the compressor side that you took the picture of, isnt what has "seals that leak" on our platform(at least if i understand it all correctly) the seals leak on the exhaust side only, since by building up crank case pressure the oil cant drain out of the turbo, so being stuck inside of it, it has but one plase to go, out the exhaust side seals and into the exhaust, the stuff ur taking pics of, i have had in my intake for the last 80k... no problems... well cept the aweful oily mess, honestly i think its time cars started to be equipped with literal shop vacs to suck that sort of shit in instead of feeding in into the intake... thereby giving your intercooler that special thermal inner coating... lol
anyways hope that clears it up
also i notice some ppl mentioned that not having a open exhaust can "mask" the problem... thats a bit funny imho cuz i think that the reduction in backpressure caused by an open exhaust actually creates the problem in the first place(granted it appears the issue occurs not in a binary fasion but almost in a sliding scale of severity, i guess its like how do you americans say? everyone is a little gay? jk rofl, sry couldn't resist), since the pressure diff between the oil in the turbo, and the place it wants to leak is even greater when you open up the exhaust(due to lack of pressure of the stock exhausts restriction), so having a free exhaust is like putting someones hand in warm water... they are liable to piss themselves at a greater rate than average, just like the smoking turbos when paired with less backpressure
so if your car is parked because it is smoking so much, try putting ur stock exhaust on at least temporarily and see how much oil you still burn, i recon if I am right it should be at the very least less than before... but hey this is all just stuff I dug up from reading on the subject, so some of it might be just other ppls best guesses passed along, but to me it all sounds quite plausible not to mention coincides with my observations on my own car...
but you def don't need to worry about the oil in the pictures, if anything, thats a sign that your pcv is working really well in sucking all that blowby out, lol, almost working TOO WELL, based on your concern, but honestly I haven't seen a cleaner turbo outlet on the compressor side anyways
also when is the last time you seafoamed?
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 04-19-2016, 06:57 AM   #368
Police - Grammarhead
Vansquish's Avatar
Originally Posted by leo766 View Post
sir if i may say^^
You need to do more reading...
When the engine is in vacuum, the pressure differential across the turbo oil seals is into the compressor outlet side. Oil can pass from there into the intake and turbo inlet via the bypass hose.
There's a reason that a lot of threads suggest that if you see oil in your manifold or in the turbo compressor inlet/outlet that you have failing turbo seals.
Seafoam doesn't do a damn thing in the L3-VDT.
leo766 (04-19-2016)
 Old 04-19-2016, 08:37 AM   #369
leo766's Avatar
ok I see what happened... the huge write up I was referancing in my head I somehow confused compressor housing with exhaust housing, in that analysis Bryan from BNR did of our K04 forever ago... lol I guess no sleep+ long time ago = me being the confused ass bastard.... I blame the colorado weed
... but hey at least I admit it freely, and even preface what I say with the fact that I don't know everything, and that most of my info is second hand, thx for the correction
p.s. not that it matters but what had me thinking of all this so backwards was the fact that Bryan mentioned he had a fix for our turbos that would completely seal off the compressor side from the crankcase/oil, i guess with time it turned into me recalling it as a feature of the stock turbo instead of BNRs solution, bleh, i suck
The Following User Says Thank You to leo766 For This Useful Post:
Vansquish (04-19-2016)
 Old 06-06-2016, 10:35 AM   #370
Revolv0's Avatar
Posts: 104   (View Stats)
Revolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud of
I had a very bad smoking turbo, leaving a smoke cloud that would blot out the sun behind me. Ran the Rotella 5W-40, and it did not do a thing to stop the smoke. Went to mazda after stocking out and had the turbo replacement covered under warranty. They don't look at ECU tune unless there is suspicion to do so.
Good Luck to all, its a shame this happens after only 50,000 Miles.
Revolv0 is offline   Reply With Quote
 Old 08-14-2016, 02:11 PM   #371
Allaboutthesnail3's Avatar
Posts: 29   (View Stats)
Allaboutthesnail3 is on a distinguished road
Will getting a new turbo really "fix" the problem? Will the new turbo get damaged just like the stock turbo after a while? .... I'm new here btw.
Allaboutthesnail3 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Allaboutthesnail3 For This Un-useful Post:
g00s3y (08-14-2016), MS3Shadow (08-14-2016)
 Old 08-14-2016, 04:55 PM   #372
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Oh, well since you're new it's perfectly fine that you decided to be a lazy fuck, do no actual reading or research on this topic, and ask to be spoon fed a simple answer.
Fucking noob.
thrisnospork and MS3Shadow like this.
The Following 3 Users Say Thank You to g00s3y For This Useful Post:
blackms3_71 (08-14-2016), MS3Shadow (08-14-2016), thrisnospork (08-14-2016)
 Old 08-14-2016, 08:45 PM   #373
Well seeing as how I spent a good 10 hours reading everything about this problem. I'm not satisfied with the answers.. Or maybe I don't understand. Fix is the vent kit, or big turbo, or higher idle RPM. None of those seem like good fixes I need someone with real insight that can tell me a BETTER solution. If I put a new turbo what is the guarantee that the seals on that turbo won't get messed up? And if that oil is not able to be pushed out all that pressure will blow a seal somewhere else?
 Old 08-14-2016, 09:14 PM   #374
g00s3y's Avatar
Groans: 438
You want a better solution. Sell the car and buy a prius, you'll have a lot less to worry about.
 Old 08-15-2016, 06:27 PM   #375
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
Blow-by gets worse with increased miles and/or increased power levels. We can maintain it but it's a never ending battle...
I believe there is a threshold at a power level (not sure where exactly) where I would switch from a vacuumed PCV set up (for lower power/lower boost), to a fully vented set up under boost (higher power/higher boost).
.....and other factors forgotten lol (ring gaps, CR, bore, ignition timing).
Sent from my LG-D852 using Tapatalk
Performance:
Stratified Tune in progress
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/final-smoke-idle-fix-mazda-tsb-01-a-73738/
Design's Long Term Ownership/Build Thread This thread Refback 09-18-2015 04:13 PM
Design's Long Term Ownership/Build Thread - Page 8 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Pingback 09-14-2015 03:22 PM
Turbo inlet Corksport - Page 2 - Mazda 3 Quebec This thread Refback 09-05-2012 09:26 AM
Tonka Toughest Mighty Truck (handle color may vary) (Oct 15, 2007) This thread Refback 06-25-2012 05:56 PM
404 Not Found This thread Refback 06-15-2012 11:29 AM
White smoke - Page 3 This thread Refback 11-12-2011 07:02 PM
White smoke - Page 2 This thread Pingback 10-03-2011 11:52 PM
???????? ???!!!!!! This thread Refback 05-15-2011 10:06 AM
Smokey turbo seals - NEW mazda fix apparantly? This thread Pingback 05-08-2011 10:02 PM
FUMEE BLANCHE DE L'ECHAPEMENT - Mazda 3 Quebec This thread Refback 05-03-2011 01:23 PM
Mazda savuttaa pitkän tyhjäkäynnin jälkeen / osia mistä / takaisinkutsu ...? This thread Refback 04-29-2011 12:08 PM
Mazda savuttaa pitkän tyhjäkäynnin jälkeen / osia mistä / takisinkutsu ...? This thread Refback 04-29-2011 03:01 AM
Any input on the 'speed3, Civic Si, and GTi as family cars? - MX-5 Miata Forum This thread Refback 04-27-2011 07:25 AM
Seal de Turbo - Mazda 3 Quebec This thread Refback 03-20-2011 08:42 AM
smoking at idle fix at mazda This thread Refback 03-09-2011 09:33 AM
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
The Smoke at Idle TSB. New Turbo required. TSB 01-004/10 Dated 08/18/2010 FreeFlyFreak MazdaSpeed 3/6 - Turbo Induction 66 08-27-2011 08:24 PM
idle smoke getting serious Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 16 11-03-2010 01:43 PM
Smoke at idle sleeper329 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2010 01:56 PM
smoke at idle ms3-87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2008 01:15 PM
Page generated in 0.39092 seconds with 31 queries
