Like Tree12Likes
 Old 03-01-2011, 06:13 PM   #1
evidence's Avatar
Posts: 1,033   (View Stats)
Default The final smoke at idle fix from Mazda TSB 01-002/11 dated 2/23/11
Looks like they released the crankcase vent setup revision a couple days ago. Anyone had this yet? I have a 2nd PCV with my OCC and never had this issue, but if dealers are giving it out no reason not to get it..
edit: PDF of TSB attached.
Some things.
The Following 11 Users Say Thank You to evidence For This Useful Post:
Addikted To Boost (03-10-2011), AJ713 (03-10-2011), Dano (03-04-2011), Dash08 (03-04-2011), Docnox (03-14-2011), dougefresh_ (07-28-2011), FreeFlyFreak (03-02-2011), labikesrcool (06-20-2011), RichieRichness (03-09-2011), skeeter149 (03-04-2011)
 Old 03-01-2011, 06:23 PM   #2
Do you have the entire TSB? What I am seeing here is the relocation of the crankcase ventilation closer to the turbo inlet.
 Old 03-01-2011, 06:23 PM   #3
Keeping it attached:
bertrand_CX_7 (07-13-2011), dougefresh_ (07-28-2011)
 Old 03-01-2011, 06:24 PM   #4
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
yo, hal. do you think this will be the fix to our probs?
2015 Mazda 6
 Old 03-01-2011, 06:25 PM   #5
evidence's Avatar
That's all I got.
it appears they are all new parts, but the TIP (D) is newly designed to have a spot for the new vent hose (B). People with an aftermarket tip might be SOL.. Curious why the cylinder head is new, maybe some of the magic is under there, or possibly could just be to accommodate the required angle of the new hose? Vacuum tubes appear to be thicker also..
Some things.
 Old 03-01-2011, 06:26 PM   #6
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
I was just at the Mazda dealer and the tech specifically stated that they are ONLY doing this fix for CX-7's, and it doesn't work, for what it's worth.
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
The Following 6 Users Say Thank You to emag remrofni For This Useful Post:
-cj- (03-04-2011), Chriscote (08-05-2011), Docnox (03-14-2011), Fobio (03-01-2011), Raider (03-01-2011), SpeedSixxx (03-04-2011)
 Old 03-01-2011, 06:26 PM   #7
Well we could have SURE change the TIP. So we need to source the new inlet and the new breather i take it.
 Old 03-01-2011, 06:27 PM   #8
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
new hose is going downhill vice uphill. that's my in b in fluid mechanics.
 Old 03-01-2011, 06:35 PM   #9
evidence's Avatar
The preference is to actually have no fluids coming through though. I think the problem is the more efficient you make the venting system the more likely you are to pick up some fluid. If you don't vent well enough, you create too much pressure and the oil return lines get choked up, backing up the oil in the turbo and burning it. We see both of these things.. I've no idea how to fix both safely though, hopefully Mazda did.
Some things.
 Old 03-01-2011, 06:40 PM   #10
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Its not replacing the cylinder head. Its only replacing the valve cover, with a better baffle. That's a gen2 valve cover they are using. People have used that method here already. The inlet reroute crap seems like more fail though.
 Old 03-01-2011, 06:41 PM   #11
m4tic's Avatar
Posts: 4,928   (View Stats)
Originally Posted by evidence View Post
That's all I got.
cylinder head cover = valve cover
i dont recall those vacuum hoses
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 03-01-2011, 06:43 PM   #12
the vacuum pressure right before the compressor inlet in alot greater then all the way out by the filter like it is now so it prob helps to pull more air out. i dunno what the baffle is doing different but im sure they did some math on the breather hole sizes and whatnot
 Old 03-01-2011, 06:45 PM   #13
evidence's Avatar
Ya, just missed the 'cover' word when typing it out. So there is a difference under there then. Are people seeing any benefit from the gen2 cover? Is it a direct swap on a gen1?
Some things.
 Old 03-01-2011, 07:15 PM   #14
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
I wonder if they turned it upside down and drilled a bunch of little holes in it.....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 3 Users Say Thank You to cpolly69 For This Useful Post:
Dano (03-04-2011), sellers (03-06-2011), superskaterxes (06-10-2011)
 Old 03-01-2011, 07:27 PM   #15
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
I wonder if this will ever become a recall. They know turbo smoke is an eventuality. Doubt it but it would be nice. I wonder what they are charging for these parts. With my experience when parts start get replaced under warranty in greater frequency the costs mysteriously drop. Maybe that is the case with these. Do these TSBs have the updated part numbers?
ak_spray is offline   Reply With Quote
 Old 03-01-2011, 07:32 PM   #16
patrick failman
Groans: 74
this isn't killing folks so i doubt we'll see a recall. not like my windstar with its snapping rear axle. and yes, that white shit is great stuff insulating foam.
The Following User Says Thank You to karl-hungus For This Useful Post:
DaleNixon (03-09-2011)
 Old 03-04-2011, 11:29 AM   #17
nairb250's Avatar
Posts: 125   (View Stats)
nairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the worldnairb250 is the leader of the world
Groaned at 23 Times in 15 Posts
looks like somebody had this done, i'm interested considering my ms3 is on it's 3rd turbo
nairb250 is offline   Reply With Quote
The Following 5 Users Say Thank You to nairb250 For This Useful Post:
GAMISTAD (03-05-2011), sellers (03-06-2011), skeeter149 (03-04-2011), wildacex187 (03-07-2011), zpele (06-10-2011)
 Old 03-04-2011, 11:47 AM   #18
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
hahahahahahaha
I seem to recall seeing a pic of a green VC somewhere with that mod....
cpolly69 (03-04-2011), superskaterxes (06-10-2011)
 Old 03-04-2011, 12:18 PM   #19
m4tic's Avatar
but im used to 1100rpm
that worked for me
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 03-04-2011, 01:08 PM   #20
spike589's Avatar
Posts: 295   (View Stats)
spike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond repute
Groaned at 6 Times in 3 Posts
their ordering the parts for my car when they come in ill take pics of them. but as far as the TIP its suppose to tie in were you get vacume for the boost controller and tee in from their. The valve cover were the breather hose is is suppose to be taller and a baffle built in.
Corksport 3in catback resonator removed, Turbo XS catless downpipe, Cobb AP Stage 2 ots map, COBB SRI, RPMC inlet, Ported/ Rebuilt Ko4, ported exhaust manifold, ported and ects delete, JBR EGR delete, JBarone passenger, rear and tranny mount, JBarone SSP/ knob/ bushings,DDM HID low/high/fogs, Snow performance stage 2 MAF meth kit, Matt Damond OCC and check valve, Tenzo Concept-9 wheels, Turbosmart 50/50, Denso ITV-22, Tinted tailights-reflectors-corners, prosport boost gauge, DIY FMIC, Carbon hood wrap, NRG shorty antenna
spike589 is offline   Reply With Quote
 Old 03-04-2011, 01:18 PM   #21
m4tic's Avatar
oh yea.. forgot about the bcs nipple...
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 03-04-2011, 02:20 PM   #22
Supernova Mafia's Avatar
Posts: 26   (View Stats)
Supernova Mafia is on a distinguished road
Groaned at 6 Times in 2 Posts
Subed
Supernova Mafia is offline   Reply With Quote
 Old 03-04-2011, 02:29 PM   #23
GTISPEED3's Avatar
Posts: 775   (View Stats)
GTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the worldGTISPEED3 is the leader of the world
Groaned at 8 Times in 5 Posts
Originally Posted by nairb250 View Post
looks like somebody had this done, i'm interested considering my ms3 is on it's 3rd turboYouTube - Mazdaspeed 3 smoking turbo fix (Legit)
That guy sounds like such a douche
subbd
7mileshome likes this.
GTISPEED3 is offline   Reply With Quote
 Old 03-04-2011, 04:30 PM   #24
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Sub
Madoomabusa74 likes this.
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
Fatguy729 is offline   Reply With Quote
 Old 03-04-2011, 05:16 PM   #25
cpolly69's Avatar
Groans: 27
Originally Posted by Fatguy729 View Post
Sub
You know at the top of the thread there is a little button that says "thread tools"
You can click this and click subscribe - Magic....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 6 Users Say Thank You to cpolly69 For This Useful Post:
802MS3 (03-09-2011), bcmountainspeed (03-04-2011), djthom (06-12-2011), i8urgti (03-29-2011), redboat (02-22-2013), skeeter149 (03-04-2011)
 Old 03-04-2011, 05:41 PM   #26
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
oddly enough i dont smoke (knock on dash) but am interested in long term of this thing.
 Old 03-04-2011, 05:57 PM   #27
Groans: 209
So I retract my previous post as I got a call from the dealer the other day saying that they were wrong and that they are actually doing this fix as well as the turbo. I got my car back today so I'll try and keep you guys filled in on how it works.
it was a mexican
The Following 2 Users Say Thank You to emag remrofni For This Useful Post:
IshiKage (03-04-2011), skeeter149 (03-04-2011)
 Old 03-04-2011, 06:07 PM   #28
IshiKage's Avatar
Groans: 278
if you are running the stock dp and or testpipe. they are hiding it.
i would smoke here and there with stock dp and cs testpipe
2015 Mazda 6
 Old 03-04-2011, 06:26 PM   #29
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
I wish this were true. Mine smokes like a chimney if I get on her.
 Old 03-04-2011, 06:37 PM   #30
fengrs's Avatar
Posts: 179   (View Stats)
fengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond reputefengrs has a reputation beyond repute
time to call the dealer.
fengrs is offline   Reply With Quote
 Old 03-05-2011, 11:11 PM   #31
Lytheum's Avatar
Posts: 187   (View Stats)
Lytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the worldLytheum is the leader of the world
going to the dealer tuesday for possible blown strut(s)....wonder if i should ask about this. so far 5w40 and 950 idle have stopped the smoke
Lytheum is offline   Reply With Quote
 Old 03-05-2011, 11:24 PM   #32
mazdaspdmike's Avatar
Posts: 784   (View Stats)
mazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the world
Groaned at 50 Times in 30 Posts
yeah gonna wait to hear more positive results before I dive in... just got my goddamn TIP only a month or two ago too, dammit.
'12 Ford Focus SEL
mazdaspdmike is offline   Reply With Quote
 Old 03-05-2011, 11:30 PM   #33
08.5MS3's Avatar
Groans: 89
Enjoy it. This is pertaining to you only if you're smoking. You're tuned, see if you can up the idle a bit to balance out the pressure.
 Old 03-06-2011, 11:04 AM   #34
IshiKage's Avatar
Groans: 278
fuck i dont want to stock out to get this fix.
well. one dealership insist on changing the turbo. so ill go get that done then go to the other dealer to get the pcv fix
2015 Mazda 6
 Old 03-07-2011, 07:27 PM   #35
Bujwazay's Avatar
Posts: 486   (View Stats)
Bujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the world
hmmm...well I've modded a little bit and haven't unleashed the smoke monster yet but this seems interesting...keep us posted on how it works (or fails...)
Bujwazay is offline   Reply With Quote
 Old 03-07-2011, 07:45 PM   #36
Been smoking since September before the tune, and somewhat after too, unfortunately. Going for my re-tune to iron out the hiccups Wednesday, will talk to him about the idle and see if I can't get a fix there. Otherwise idk, may just accumulate the fix parts over time and then do it myself down the road when aftermarket "fix friendly" TIPs are released.
'12 Ford Focus SEL
 Old 03-07-2011, 08:03 PM   #37
Groans: 209
After driving for a bit now that I have my car back, the one observation I've made is that the turbo spool sound seems to be muffled compared to what it was beforehand. Maybe this is just in my head. Anyone who has some technical knowledge that could explain this? It's not like I care or anything, as I've never really been a big fan of it in the first place.
it was a mexican
 Old 03-07-2011, 08:07 PM   #38
IshiKage's Avatar
Groans: 278
now add a catless dp and see what happens
2015 Mazda 6
 Old 03-09-2011, 08:48 AM   #39
streetspeed3's Avatar
Posts: 1   (View Stats)
streetspeed3 is an unknown quantity at this point
I am going to the dealership tomorrow, for the same fix. "Turbo Ventilation". Hopefully it works.
streetspeed3 is offline   Reply With Quote
 Old 03-09-2011, 09:14 AM   #40
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Did anyone notice this difference?
wtf is that?
RichieRichness is offline   Reply With Quote
The Following User Says Thank You to RichieRichness For This Useful Post:
Sport6 (03-09-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/final-smoke-idle-fix-mazda-tsb-01-a-73738/
Design's Long Term Ownership/Build Thread This thread Refback 09-18-2015 04:13 PM
Design's Long Term Ownership/Build Thread - Page 8 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Pingback 09-14-2015 03:22 PM
Turbo inlet Corksport - Page 2 - Mazda 3 Quebec This thread Refback 09-05-2012 09:26 AM
Tonka Toughest Mighty Truck (handle color may vary) (Oct 15, 2007) This thread Refback 06-25-2012 05:56 PM
404 Not Found This thread Refback 06-15-2012 11:29 AM
White smoke - Page 3 This thread Refback 11-12-2011 07:02 PM
White smoke - Page 2 This thread Pingback 10-03-2011 11:52 PM
???????? ???!!!!!! This thread Refback 05-15-2011 10:06 AM
Smokey turbo seals - NEW mazda fix apparantly? This thread Pingback 05-08-2011 10:02 PM
FUMEE BLANCHE DE L'ECHAPEMENT - Mazda 3 Quebec This thread Refback 05-03-2011 01:23 PM
Mazda savuttaa pitkän tyhjäkäynnin jälkeen / osia mistä / takaisinkutsu ...? This thread Refback 04-29-2011 12:08 PM
Mazda savuttaa pitkän tyhjäkäynnin jälkeen / osia mistä / takisinkutsu ...? This thread Refback 04-29-2011 03:01 AM
Any input on the 'speed3, Civic Si, and GTi as family cars? - MX-5 Miata Forum This thread Refback 04-27-2011 07:25 AM
Seal de Turbo - Mazda 3 Quebec This thread Refback 03-20-2011 08:42 AM
smoking at idle fix at mazda This thread Refback 03-09-2011 09:33 AM
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
The Smoke at Idle TSB. New Turbo required. TSB 01-004/10 Dated 08/18/2010 FreeFlyFreak MazdaSpeed 3/6 - Turbo Induction 66 08-27-2011 08:24 PM
idle smoke getting serious Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 16 11-03-2010 01:43 PM
Smoke at idle sleeper329 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2010 01:56 PM
smoke at idle ms3-87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2008 01:15 PM
Page generated in 0.59850 seconds with 45 queries
