 Old 03-09-2009, 09:57 AM   #1
xandrake's Avatar
Posts: 575   (View Stats)
xandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the world
Default Forge BPV O-Rings
I just took apart my Forge BPV for the recommended maintenance (cleaning and regreasing) and realized that the topmost o-ring has been mauled. I tried Patty's "pen test" and it failed.
Anyone else run into this issue? What causes this? How can we prevent it? I've PM'd Patty on the bad forums and have not heard back from him yet.
Will Auto Zone carry a replacement o-ring or should I order from Forge?
Thanks in advance, all.
Xan
xandrake is offline   Reply With Quote
 Old 03-09-2009, 10:12 AM   #2
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
Email forge. They'll mail you replacements.
Crossbow is offline   Reply With Quote
 Old 03-09-2009, 10:14 AM   #3
xandrake's Avatar
Thanks! Time to search for the email addy.
Anyone have any ideas for my other questions though? Why this happens, how to prevent, etc etc....
 Old 03-09-2009, 10:21 AM   #4
Crossbow's Avatar
I think it usually happens when owners swap springs or add shims. The o ring fits in a tiny tiny little groove in the outer cap, and you have to very slowly twist the cap back on, to make sure it doesn't pop off.
If you try to change shims or springs quickly, its incredibly easy for the o ring to pop out of its groove, and since its so tiny, it offers little or not resistance to the twisting of the cap, and will shear in half as you twist the cap on.
I used the contact forge fillout section on their website, dealt with a lady whose email was angel@
 Old 03-09-2009, 11:31 AM   #5
xandrake's Avatar
Hmm...is it unsafe to drive with this valve not holding any boost? I am having trouble finding my OEM piece.
How To Flush Cooling System, Worn Piston Rings, Replacing Headlight Bulb, Unfreezing A Frozen Motor, Prius Cruise Contro Haltech Automotive News 0 02-27-2009 05:00 PM
Mullaly rings man who chooses Ford Fusion Hybrid over Toyota Prius Haltech Automotive News 0 02-03-2009 01:00 PM
Rings TENCms3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 09-17-2008 01:41 PM
Need help! Got new wheels and need hubcentric rings speed3 MazdaSpeed 3/6 - Wheels & Tires 2 08-02-2008 02:20 AM
Hub rings Laloosh MazdaSpeed 3/6 - Wheels & Tires 8 05-13-2008 02:40 PM
Page generated in 0.25616 seconds with 21 queries
