 Old 06-04-2014, 05:25 PM   #1
Wildfyre116's Avatar
Posts: 41   (View Stats)
Wildfyre116 is a jewel in the roughWildfyre116 is a jewel in the roughWildfyre116 is a jewel in the roughWildfyre116 is a jewel in the rough
Default Forge BPV V1 Flutterering STILL
Is there something else that will cause a forge BPV v1 to "flutter" instead of the normal "sword clash" beyond not being lubed right and/or having the wrong spring/shim?
I don't remember exactly when my BPV started to flutter instead of making the correct sound, but it either happened gradually enough to where I didn't notice immediately, or happened a while ago and I forgot about it. When I originally installed the part, I used a standard chassis grease to lube it. It worked great and made the right sound, but I don't think it was meant to be used in a BPV, so I'm guessing it eventually stopped being effective. Last week I took the BPV apart, cleaned it, then re-lubed with a synthetic brake caliper grease. It wasn't my first choice for lube, but it had a great heat range (far beyond what the BPV would see) so it seemed like it'd work great. That didn't fix it, though, so I tried changing out my blue spring to blue spring + 1 shim, red + 0, and yellow + 0. All produced no change and the BPV still fluttered.
Anything I'm missing? I've done some searching and only found people saying to re-lube or try new spring combos. Mods in sig if needed (stock TMIC setup).
2007 MAZDASPEED 3 GT :: HTP 3.5" Intake :: Corksport Test Pipe :: Godspeed FMIC :: AutoTech HPFP Internals :: Grimmspeed EBCS :: Cobb AP :: Freektune OTS+ :: SURE Short-Cut & Counterweight :: TRZ "Dog-Bone" RMM :: JBR 80 TMM :: Forge BPV V1 :: Denso ITV22 Plugs :: JBR EGR Block-Off :: ProSport Boost Gauge :: Tow-Hook License Plate Relocate
Wildfyre116 is offline   Reply With Quote
 Old 06-04-2014, 05:57 PM   #2
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Make sure you don't have the plunger installed upside down.
Clean, relube with some mobile one grease or white lithium can work to.
Make sure your O-Rings are in place and in good shape.
Run blue spring with no shim to start.
Big Dog is offline   Reply With Quote
 Old 06-23-2014, 09:44 AM   #3
Quick update for anyone who has experienced this before and might still be working on it; the culprit was the worm-clamp on the intercooler-to-throttle-body hose being broken. It would tighten to a certain amount, then "break" back a few notches if you tightened it further (beyond hand-tight). Replaced the clamp, tightened it with a ratchet, and viola - problem fixed.
1st Gen Forge BPV mpc12347 MazdaSpeed 3/6 - Turbo Induction 13 02-03-2010 06:24 PM
Page generated in 0.24378 seconds with 21 queries
