 Old 01-29-2015, 12:16 AM   #1
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Default FMIC Dilemma
I bought a new TR8 core from someone and almost a year later, still collecting parts for BT build, I found that it's actually a TR10. Guess I should have checked the part number a long time ago. Anyway, I also purchased a COBB piping kit that I planned on using with what I thought was a TR8.
After some searching, I didn't really come up with any solid solutions. I'd really rather not cut the stock crash bar. I'm wondering if the Genpu crash bars would work on the Genwon? I think I saw someone use the UR crash bar to mount a TR10 on their Pu.
Any other ideas for a possible solution?
BT is a 5858 with a goal of 500ish whp. I suppose if I had to, a TR8L would work just fine.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 01-29-2015, 08:03 AM   #2
El Beaner's Avatar
Posts: 4,262   (View Stats)
I psoted on DFW Mazdas as well - posting here for you too
Why not get with Donny at RPM to see if it's possible to fab up some brackets to fit the TR1035 core with no modifcation.
Based on the pics you posted on Facebook - I'm leaning now that you have a TR1035 core since you said the mounting points are on the side
TR10
TR10 Intercooler 666HP- TREADSTONE PERFORMANCE
TR1035
TR1035 Intercooler 666HP- TREADSTONE PERFORMANCE
HEre are the specs between the 3
TR8 = 7.8" X 22" X 3.5" - overal length 28"
TR10 = 10.5" X 24" X 3.5" - overal length 34"
TR1035 = 10.5" X 22" X 3.5" - overall length 30"
THe 1035 is only 2" longer than the Tr8 so the piping you have "should" be able to work(might be a bit tight)
The mounting locations for the 1035 and the Tr8 look like that are very similar.
SOLD 2012 LSM Tech - 11/17/17
 Old 01-29-2015, 08:22 AM   #3
Quigs's Avatar
Posts: 1,152   (View Stats)
Also, check with HTP to see if the new crash bar they are about to release (for genone) allows for more room for larger FMIC cores.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
The Following User Says Thank You to Quigs For This Useful Post:
senor blanco ms3 (01-29-2015)
 Old 03-25-2015, 10:33 AM   #4
Cdreyes12's Avatar
Posts: 40   (View Stats)
Cdreyes12 is a name known to allCdreyes12 is a name known to allCdreyes12 is a name known to allCdreyes12 is a name known to allCdreyes12 is a name known to allCdreyes12 is a name known to all
Default Cutting crash bar.
Is there a write up on how to cut the crash bar to install the tr8 core on a Genpu?
Cdreyes12 is offline   Reply With Quote
 Old 03-25-2015, 11:09 AM   #5
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
https://www.google.com/search?q=genp...YQ_AUoAA&dpr=1
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 03-25-2015, 11:14 AM   #6
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Been done a few times in our group. Check in here ...http://www.mazdaspeedforum.org/forum/foru...tta-ga-145575/
we'll talk about it.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
mxlplx71 (03-25-2015)
 Old 03-25-2015, 03:21 PM   #7
Cdreyes12's Avatar
Much appreciated. I've been looking last few days. Only found posts about cores and that you have to cut crash bar for tr8 but no how tos. Thank you!
wheel dilemma tytanium MazdaSpeed 3/6 - Wheels & Tires 8 11-15-2013 10:30 AM
exhaust dilemma sen7inel Mazdaspeed3/6 General Discussion 24 10-27-2013 04:09 PM
My New Dilemma Stealth01 Mazdaspeed3/6 General Discussion 17 08-07-2011 11:22 PM
Air filter dilemma Night Wolf MazdaSpeed 3 - Engine, Transmission & Driveline 14 03-17-2010 02:01 AM
17" Dilemma martin_nj MazdaSpeed 3/6 - Wheels & Tires 6 02-20-2009 10:39 AM
Page generated in 0.28677 seconds with 25 queries
