 Old 07-06-2016, 12:35 AM   #1
johnathan_723's Avatar
Posts: 39   (View Stats)
johnathan_723 will become famous soon enough
Default FMIC help
I wanna put a FMIC in my 07 ms3 but i've already got a cold air intake i wasn't sure if there is any kits you can buy online or DIY you know about that would be practical enough to wanna try on my own.
Not sure what my options are if the cold air doesn't fit do i have to buy a short ram intake? At that point am i better off speeding the extra bit and buy crock sports FMIC with true ram air TMIC replacement
Looking to do it for cheap but not half assed
Sent from my SM-G920W8 using Tapatalk
johnathan_723 is offline   Reply With Quote
 Old 07-06-2016, 12:43 AM   #2
csmaan12's Avatar
Posts: 325   (View Stats)
csmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond repute
I would say do some more research because practically all of the FMIC kits available out there have some sort of different routing in the engine bay.
I see the CX Racing FMIC piping a lot with a TR8 core and your choice of crash bar. Usually that combo should leave you with enough room for your cold air intake. I'd say this route is a better option. Or you could even get the JBR under piping kit and route the pipes under the engine, which mean more room up top.
This is why I'm saying to review all the options because every manufacturer has a different way of routing. I think the only one that may not fit with a cold air intake is the Cobb FMIC because they pipes go down where the intake goes, but I'm not 100% sure on that.
2011 Mazdaspeed3 Mod List:
FREEKTUNED
ETS TMIC
Autotech HPFP Internals
CS Stage II SRI + TIP
Tial QR
UR Catback
UR Catless Test Pipe
Damond RMM
Damond SSP
csmaan12 is offline   Reply With Quote
 Old 07-06-2016, 12:47 AM   #3
Thanks mang i will look into those brands its just hard to tell with some pictures if it will fit or not
 Old 07-06-2016, 12:50 AM   #4
csmaan12's Avatar
I think the CX Racing piping goes down in front of your dipstick, so you should be okay with that. There should be a DIY on that somewhere on here so you can see how it's routed, maybe in the Gen 2 section, but I'll leave that for you to look up .
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
 Old 07-26-2016, 02:59 PM   #5
Tech168's Avatar
Posts: 31   (View Stats)
Tech168 has a spectacular aura aboutTech168 has a spectacular aura aboutTech168 has a spectacular aura about
I have Cobb fmic with injen cai so it will fit
Tech168 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tech168 For This Useful Post:
blackms3_71 (07-26-2016), Djohns (08-04-2016)
 Old 07-26-2016, 07:41 PM   #6
sheston's Avatar
Posts: 1,847   (View Stats)
I would say not to worry about the CAI and get a regular, high flow filter and intake. The temperature difference you see with the CAI is almost meaningless as soon as the air hits the turbo, gets compressed, heats up 150 or more degrees, then gets cooled down by the intercooler etc.
I'm a big fan of upgrading the TMIC and spraying Meth. Best flow and cooling of all worlds
MS3Shadow (07-26-2016)
 Old 08-04-2016, 10:32 AM   #7
jmen73's Avatar
Posts: 63   (View Stats)
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
I had an ATP FMIC and Cobb SRI. It fit fine.
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
 Old 08-04-2016, 12:13 PM   #8
Djohns's Avatar
Posts: 3,944   (View Stats)
I say build your own front mount! I built mine and saved a ton of money even after having the pipes powder coated.
2010 black mica speed3
Soon:built motor
robbspeed (08-04-2016)
 Old 08-05-2016, 09:27 AM   #9
LowFlyin's Avatar
Posts: 188   (View Stats)
LowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant future
Not to thread jack, but any tips for this? I'm in the process of getting ready to do this. Was just going to do tr8 with cx pipe kit
Sent from my LG-H820 using Tapatalk
LowFlyin is offline   Reply With Quote
 Old 08-05-2016, 02:45 PM   #10
Djohns's Avatar
Making a piping kit with pvc first so it's not so much of a trial and error. Take those measurements and try to find pre bent piping. I was lucky because my dad has access to a pipe bender at work.
Soon:built motor
 Old 08-05-2016, 05:48 PM   #11
LowFlyin's Avatar
Thanks I think ill give that a try then. How much did you spend to make your piping kit ? Including pvc also
 Old 08-05-2016, 09:04 PM   #12
Djohns's Avatar
If I recall correctly it was around $400.
Soon:built motor
 Old 08-05-2016, 09:05 PM   #13
LowFlyin's Avatar
Cool thanks, ill price out the cx kit and see if it would be worth doing it.
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Page generated in 0.33655 seconds with 27 queries
