  • 1 Post By udntknw
 Old 09-07-2013, 03:55 PM   #1
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
Default FMIC HIGH BATS
Hello all Lex and I are in the process of tuning my newly installed BNR S3 but my Bats do get kinda toasty in the 140+ range this is on a baseline map with just 2 pulls after the car warmed up I have a CXracing Core with PG piping.Do keep in mind I live in south Florida and its hot as fuck down here anything you guys recommend for lower my bats or dose this florida wheather have me beat here are some logs.Any help would help I have had this turbo installed for 2 weeks now and going nowhere slow.BTW I have already taken 3 hours and taken off the front bumper Friday night and pressure tested the pipes to test for leaks none found IC has dings but no leaks.Honestly I think the fucking stock sensor is in a really bad place to being with.
tokoam is offline   Reply With Quote
 Old 09-07-2013, 04:26 PM   #2
Spray the IC itself with Meth or water? Or go meth injection. Or find another way to lower engine bay temps maybe.
Or a bigger IC core.
Only ideas I can think of. I have no knowledge of how the car behaves in Florida, but those are the only simple ways I can think of to lower the BATs.
 Old 09-07-2013, 04:28 PM   #3
DSIT995's Avatar
Posts: 1,768   (View Stats)
Cxracing core isn't the best...
Tr8l core + meth is the way to go!
tapping.... tap tap
99 Miata NB - Stock for now
 Old 09-07-2013, 04:36 PM   #4
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
I am I'm AZ, and cruising with the cxracing core, I pull around 130-140 for my bats, WOT goes to around 115-120, that was before meth. Meth will drop you to low 60s/high 50s in the lovely heat lol. Should have my ap back Monday and can post a log before and after meth.
Edit, you should be colder than me. My IATs are like 108 right now and you're a good 10° below me lol
 Old 09-07-2013, 04:37 PM   #5
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Check the cold pipe, it might be getting heatsoaked. I have this problem as well, but have done a few things to help. If your cold pipe is getting heatsoaked its from the main radiator hose, and I think also from the fan blowing hot ass air on the cold pipe.
I zip tied the rad hose so it's further away from the cold pipe, but my cold pipe still gets pretty hot. I also wrapped most of it in fiberglass heatwrap but it didn't seem to help much. It's frustrating because the hot pipe will be only be a little warm, and the IC will be cold, but then the air gets heated up right before it goes back into the motor from the cold pipe. I think I need to find a new rad hose or something to route it better.
It could also be because of the tiny cxracing core I have heard it isn't very effective.
2012 MS3
Stratified 91
 Old 09-07-2013, 04:38 PM   #6
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
TIG on the intake manifold will help reduce the intake manifold heat soaking. Staying out of boost before the log will help.
just tappa it in...
bhamitgeek likes this.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
 Old 09-07-2013, 04:40 PM   #7
mr.speedy3's Avatar
This! I just remembered that. Typically the radiator hose sits directly on the cold pipe (FMIC) going to the throttle body. I just flipped it around. It gave me the room I needed. I had BAT issues when the radiator hose hit the cold pipe.
 Old 09-07-2013, 04:42 PM   #8
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
I live in plantation aswell and my temps bever get that hot. Id say average at the end of a multi gear pull is upwards of 120ish* but generally in the 115* area. (Without any meth) @Roddiy;
Who lives in s.fla as well has a cxracing core so im sure he can post up some numbers.
I will say thou if you search around the site you will see ALOT of threads on that specific core and how it is for the lack of better terminology... Not adequate at producing good results for our cars.
Treadstone is just south of us in cutler ridge. Might make sense to head down there and pick up a tr8 or a tr6 at the very least. Either will run you less then $250
Also if you are refering to the sensor in the front of your car by your fmic that's the outside temp gauge.
TEAM LUXURY
 Old 09-07-2013, 04:44 PM   #9
tokoam's Avatar
Anyone have any input on the godspeed core ? The dimensions are bigger than tge CXracing one I will be getting meth kit in the near future but for now its gotta wait the wife will chop me if I waste any more money.
 Old 09-07-2013, 04:47 PM   #10
Sid3wayS's Avatar
Groans: 97
Its the same thing only a knock off of a knock off.
TEAM LUXURY
The Following User Says NO Thank You to Sid3wayS For This Un-useful Post:
emag remrofni (09-07-2013)
 Old 09-07-2013, 05:04 PM   #11
udntknw's Avatar
TR8L core FTW!
just tappa it in...
**Old Motor**
**New Motor**
The Following User Says Thank You to udntknw For This Useful Post:
himurax13 (09-30-2013)
 Old 09-09-2013, 04:18 AM   #12
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
Replace CXracing IC with TR8 and you'll be happy - I did the same thing and BATs dropped ~30F across the board on WOT pull.
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline   Reply With Quote
 Old 09-09-2013, 10:47 AM   #13
tokoam's Avatar
Rather than mess with cutting and rigging the tr8 I went with the ultimate racing front mount. Looks extremely clean. Damn expensive though we shall see how it turns out
 Old 09-09-2013, 10:49 AM   #14
snailD's Avatar
Posts: 3,039   (View Stats)
the cx core isn't the best, that is your issue. expensive call with the UR but it should do the trick
 Old 09-29-2013, 11:16 AM   #15
tokoam's Avatar
Well here it is me and my buddy installed the UR fmic yesterday and I am pretty impressed by its performance and how it came out.Aside from getting 2 dents from shipping from canada I think it all worked out at the end any way here is a partial log i took last night driving home after just installing it.Now I will get back with Lex so we can get my tune sorted and my damn creep issue resolved.Btw sorry in advance for the crappy pics it was taken on a shit phone
 Old 09-29-2013, 12:13 PM   #16
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Silly question, throttle body by-pass mod done?
Nator is what it does.
Agent_Orange (09-29-2013)
 Old 09-29-2013, 12:21 PM   #17
tokoam's Avatar
Nope.
 Old 09-29-2013, 12:27 PM   #18
kritz's Avatar
Groans: 95
Originally Posted by tokoam View Post
Nope.
Do it MEOWWWW!
 Old 09-29-2013, 05:38 PM   #19
mr.speedy3's Avatar
Do it MEOWWWW!
+1 then do meth while you're at it
 Old 09-30-2013, 08:38 AM   #20
kish89's Avatar
Just curious, does it really makes such a big difference?
Yea I know every degree less matters, but is it worth it, especially for us with cold winter days?
 Old 09-30-2013, 12:16 PM   #21
kritz's Avatar
Groans: 95
185º coolant yes it makes a difference. I have no issues and it gets a little colder in NY than by you.
Sent while driving fastest k04 pu
kish89 (09-30-2013)
 Old 10-02-2013, 09:27 PM   #22
tokoam's Avatar
I will be doing this mod this weekend I live in FL and its hotter than donkey balls down here at times.We shall see how well it works but overall my bats dropped about 30F which is nice.WMI is next that is when i get some cash saved up.
The Following User Says Thank You to tokoam For This Useful Post:
kritz (10-03-2013)
MS6 High Bats snailD MazdaSpeed 3/6 - Turbo Induction 35 07-06-2012 12:38 PM
FMIC install but still high BATS KRheeder MazdaSpeed 3/6 - Turbo Induction 61 07-06-2012 12:33 PM
My BATs.....High? MS6FL MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 02-28-2012 10:15 PM
Fmic and high ect's Shooter445 MazdaSpeed 3/6 - Turbo Induction 20 05-12-2011 01:18 AM
high bat's with new FMIC??? Realgib3 MazdaSpeed 3/6 - Turbo Induction 62 06-15-2010 07:23 AM
Page generated in 0.42037 seconds with 30 queries
