![]() Join Date: Jan 2015 Location: Windsor, Ontario. Canada
Rep Power: 0 ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score Im looking to buy a fmic right now, i found a local one for a good price but thought it might be a bit small. It is 2.5 x 27.5 x 7. currently have autotech internals, ap v3, rmm, cai and will soon be looking to run with max bolt ons for a year or 2 then go big turbo, but I don't want to re buy any parts along the way.. how much hp do you think this size intercooler would be good for? thanks |
| Not Ranked : 0 score it is not just a matter of hp but also about how you will use it. You can have a very efficient at cooling IC that create a larger pressure drop. (good for lapping /autocrossing) Or one with less temperature difference allowing less pressure drop for quick road wot or short boosting time...
| Not Ranked : 0 score To add to Jeff, the construction of the core also matters quite a bit. A CX racing core is a decent size, but shit for design and construction. Depending on your power goals, FMIC may be entirely unnecessary anyway.
(Thread Starter) | Not Ranked : 0 score thanks, pressure drop is 0.2-0.5 at 15psi and 2-5 at 35psi, not sure the construction of the core. it's currently a daily that i want to bring to the track occasionally |
| MS6 RMM hole sizes | mrQQ | Mazdaspeed3/6 General Discussion | 9 | 02-10-2016 01:31 PM |
| tire sizes | vally1978 | CX-7 > Wheels, Tires, Brakes & Suspension | 6 | 10-27-2015 04:37 PM |
| fmic core sizes what yall running | dooderek | MazdaSpeed 3/6 - Turbo Induction | 6 | 11-13-2010 12:28 AM |
| speaker sizes | 08Speed3 | MazdaSpeed 3/6 - Car Audio & Electronics | 3 | 02-12-2010 03:34 PM |
| FMIC Core sizes? | racebitz | MazdaSpeed 3/6 - Turbo Induction | 10 | 11-08-2008 01:57 AM |
