 Old 03-25-2008, 12:03 PM   #1
occschemguy's Avatar
Posts: 1,149   (View Stats)
occschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the world
Default front mount or top mount?
what after market intercooler works best top mount or front mount or do u see much of a diffrence, i know some of u have had the ETS top mount then switched to a front mount, why did u and has it made much of a diffrence, if it was just for looks say that.
You can see more on mymyspace
occschemguy is offline   Reply With Quote
The Following User Says Thank You to occschemguy For This Useful Post:
NYpest (03-25-2008)
 Old 03-25-2008, 12:06 PM   #2
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
do you like heat soak?
The Following User Says Thank You to bova For This Useful Post:
NYpest (03-25-2008)
 Old 03-25-2008, 12:07 PM   #3
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
i have a TM love heat soak !!
NYpest is offline   Reply With Quote
The Following User Says Thank You to NYpest For This Useful Post:
occschemguy (03-25-2008)
 Old 03-25-2008, 12:07 PM   #4
dont want to loose boost either, ive heard u loose boost on front mount, and the top mount cools right down if u are moving, right?
 Old 03-25-2008, 12:17 PM   #5
bova's Avatar
Groans: 45
i haven't lost any boost and can't really notice any lag.
 Old 03-25-2008, 12:24 PM   #6
Originally Posted by mdogg View Post
why would you lose boost with a FMIC? You would only lose boost if you have a leak or bad connection somewhere..... on EITHER the top or front ICs....
not necesaraly i turbo is not that great the greater distance can hinder performance, the sti is this way, the stock turbo does not perform well with a front mount bcos of the distance it has to push.
 Old 03-25-2008, 12:29 PM   #7
ultraspeed619's Avatar
Posts: 268   (View Stats)
ultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the world
I had the ETS TMIC and loved it when I was running stock boost. Heatsoak wasn't too horrible here in san diego, though. I now have the Standback and a FMIC running 17psi and no heatsoak whatsoever! Power whenever you want it without worrying about heatsoak, FTW...
MAZDASPEED6
Engine: Cobb SRI/AP | CPE FMIC/DP/MM/HPFP | MagnaFlow 3in CBE | HKS TwinPower Ignition | Denso plugs |
Suspension/Wheels: SSR GT10 19x8 +37 | RPM Street Springs | AutoExe F/R braces | WhiteLine RSB | GT Spec Ladder Bar/Trailing Braces |
Exterior: SSG AE Lip Kit | HomeDepot Front Lip Mod | JDM Tailights | Black Emblems |
Interior: AutoExe ShiftKnob | TWM STG2 | ProSport BoostGauge | Dashawk |
ultraspeed619 is offline   Reply With Quote
The Following User Says Thank You to ultraspeed619 For This Useful Post:
 Old 03-25-2008, 01:17 PM   #8
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
I think he is referring to the pressure drop you get with a FMIC.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
The Following 3 Users Say Thank You to SLS MS3 For This Useful Post:
NYpest (03-25-2008), occschemguy (03-25-2008), Speed6 Guy (03-26-2008)
 Old 03-25-2008, 02:31 PM   #9
bova's Avatar
Groans: 45
if its a good core you won't get a pressure drop, it could be the same drop as the ets. only thing you would really get is turbo lag which most don't even notice.
NYpest (03-25-2008)
 Old 03-25-2008, 02:37 PM   #10
Door is THAT Way Mate ---->
Mr._Pickles's Avatar
Posts: 183   (View Stats)
Mr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these partsMr._Pickles is infamous around these parts
I did an FMIC kit on my GTI and it was a huge PITA.
TMIC are cheaper and take all of 10 minutes to install. They work great and heat soak is never really an issue.
Mr._Pickles is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr._Pickles For This Useful Post:
 Old 03-25-2008, 03:33 PM   #11
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
i just got my 3.25" TMIC ETC core in.... looks great, no regrets.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 03-25-2008, 04:14 PM   #12
bova's Avatar
Groans: 45
the problem is only auto exe and ets make new top mounts for our cars. and if you want to donate a kidney then get the auto exe but and if you want to be weary about what you bought get a ets (heard so many stories about crappy welds and them leaking).
not that you can't have problems with a front mount either, i mean look at me, stupid maf housing.
occschemguy (03-27-2008)
 Old 03-27-2008, 02:58 AM   #13
I think but im not sure, that the 3.5 ETS is the one with the welded end tanks and you need to inspect it before install. The 3" and 3.25" are good to go with casted end tanks.
 Old 03-27-2008, 10:57 AM   #14
grimreaper's Avatar
Posts: 7   (View Stats)
grimreaper is on a distinguished road
does fmic void warranties?
grimreaper is offline   Reply With Quote
 Old 03-27-2008, 11:56 AM   #15
according to Mazda corprate any after market intersooler can void your waranty, even a BOV is grounds for them to revok it!
grimreaper (03-30-2008)
 Old 03-27-2008, 12:15 PM   #16
grimreaper's Avatar
thats cool i understand the situational part, it just seems from the posts ive read that mazda is a little more deaf to the magnos act (spelling?) compared to other auto makers, granted not every single person posts on the forums
 Old 04-02-2008, 06:46 AM   #17
Performance Racing's Avatar
Posts: 193   (View Stats)
Performance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nice
FMIC FTW!
I think the Corksport is sexy as hell, well priced.
Or you can do custom like me for under $600, some have done ti for under $500.
Performance Racing is offline   Reply With Quote
 Old 04-02-2008, 06:48 AM   #18
amen brotha!
heat soak isn't an issue???????
not in comparison to my previous VW. That car heat soaked BAD.
 Old 04-02-2008, 11:48 AM   #19
Jspeed6's Avatar
Posts: 6   (View Stats)
Jspeed6 is an unknown quantity at this point
...I had the 3.5 ETS about a year ago, heat soak was very noticable......switched to the CPE FMIC a few months back and havent looked back. without a doubt in my mind, the FMIC (from any vendor) will out perform any TMIC hands down! this is comming from someone who's had both......just my .02 cents.
....Im in sunny south florida so all I see is hot weather...
"Stock"
Jspeed6 is offline   Reply With Quote
 Old 04-02-2008, 01:03 PM   #20
Averia's Avatar
Posts: 34   (View Stats)
Averia will become famous soon enough
if Mazda corporate voids your warranty due to a BOV, then they would be asked to prove this if it goes to court. Honestly, someone with the financial backing needs to fight it out one of these times....
the only "grounds for them to revok it!" is if the part in question causes the failure. furthermore, based on a little reading, I think they are only allowed to void the part of the warranty pertaining to the aftermarket part and the damage it causes.
It is ILLEGAL for Mazda to revoke your warranty if they simply see that you have an upgraded BOV. But.... someone might have to take legal action for the favorable out come....
but anyways....
Guess it would be hard for my dealership to deny much of anything - the parent company sponsors "Pimp my Ride". Sure if they modification clearly caused the problem but blacklisting a car just because it had mods on it is un-American.
Averia is offline   Reply With Quote
 Old 04-02-2008, 02:30 PM   #21
kurfgator's Avatar
Posts: 13   (View Stats)
kurfgator is an unknown quantity at this point
Going to any upgraded inter cooler will provide better performance. The factory TMIC uses very restrictive paths to increase contact time and reach a higher temperature drop. The drawback? Almost a 3.5 psi pressure drop. The ETS and all FMIC kits (as far as I know) have about a 1-1.5 psi drop. So even with the extra piping of the FMIC the decrease in work required by the turbo will result in no noticeable lag. The ETS will actually have a reduction in lag versus stock so if you went from an ETS to a FMIC you might feel the increase in lag.
The ETS will perform a little better than stock based on the increase in compressor efficiency. To run 15.6 at the manifold the turbo has to run about 19psi with the stock inter cooler and only 17 with the ETS. The ETS also cools almost as well as stock due to the larger core. The greater area of each tube increases cooling contact even though the air isn't being held in the core as long.
The FMIC will do the same as the ETS with a little extra lag (as compared to the ETS, about equal with stock as long as it isn't a custom with an over-sized core). The advantage of the FMIC is that it will keep boost temperatures low regardless of driving conditions. The TMIC will definitely cost you power after idling for a minute while the FMIC will be barely above ambient (remember, it still gets flow when you are stopped if the rad fans kick on) but the TMIC is fine if you are moving at decent speeds.
I have the ETS 3.25" with the SU boost tubes now and while I like it much more than stock I am getting ready to go to FMIC.
As far as warranty, Mazda can void it for your driving habits if they can prove you've been racing. If you are really worried about your warranty, don't mod. It is a little bit like Russian Roulette with Mazda dealers and mods.
kurfgator is offline   Reply With Quote
 Old 04-02-2008, 02:49 PM   #22
Im sitting waiting for that "perfect" fmic to come into existence! its either going to be Cobb or PTP.
 Old 04-02-2008, 02:53 PM   #23
as of right now i will need to go costum anyway none has a intercooler effecient to 500hp. or even close unless cpe gets theres done.
 Old 04-02-2008, 04:15 PM   #24
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
ATP makes a 600hp core but what are you doing to actually need that kind of power?
redrocketz is offline   Reply With Quote
 Old 04-02-2008, 11:39 PM   #25
i dont need that power but want that power!
i am mostly doing it for exposure(get in to more mags and win more shows etc) wich means more and beter sponserships and i enjoy compotition.
 Old 04-03-2008, 11:18 AM   #26
redrocketz's Avatar
OK let me rephrase it what are you doing to get that power?
 Old 04-03-2008, 11:26 AM   #27
we are working out most of the stuff as we go along, but fully built forged motor, gt35r and many supporting mods, still working on the fuel system of wht it will exactly consist of and we havnt decided on a tuning solution as of yet, we may go to a stand alone and be running an extra set of injectors.
 Old 04-03-2008, 01:39 PM   #28
redrocketz's Avatar
what are you using for the built motor?
 Old 04-28-2008, 02:08 PM   #29
FileNotFound's Avatar
Posts: 33   (View Stats)
FileNotFound is a glorious beacon of lightFileNotFound is a glorious beacon of lightFileNotFound is a glorious beacon of lightFileNotFound is a glorious beacon of lightFileNotFound is a glorious beacon of lightFileNotFound is a glorious beacon of light
Groaned at 3 Times in 1 Post
What's your idea of a 'perfect' fmic?
Or what don't you like about the current offerings?
FileNotFound is offline   Reply With Quote
 Old 04-29-2008, 01:23 AM   #30
Perfect = NO fitament issues with any intake i want to run. also, no problems with aftermarket manifolds, piping getting in the way with a TT brace AND still being to run the bottom engine cover.
 Old 04-29-2008, 06:01 AM   #31
phailerider's Avatar
Posts: 4,639   (View Stats)
you forgot to add.... that the ic sits squared up in the grill..lol
I HATE the options we have right now. I think its rediculous that we havent gotten a core that solves these problems.
 Old 04-29-2008, 07:54 AM   #32
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
you better hurry up lol...
I've had a 760HP, 1080 CFM IC core hanging out in front of my speed for a while now
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
 Old 05-06-2008, 10:15 PM   #33
acidbbg's Avatar
Posts: 208   (View Stats)
acidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud of
It's all about what you are looking to get out of this car.
In all honesty i think most are not looking to turn their speed6's into race cars.
Some like myself are just looking for moderate increase of power with ease of install. Go with the TMIC.
For other looking to upgrade turbo's and live in very hot area's (Florida, etc) i would suggest going FMIC.
-C
acidbbg is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/front-mount-top-mount-446/
MazdaSpeed 6 - Turbo Induction [Archive] - Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-01-2008 10:42 PM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 04:19 PM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 03:32 PM
PTP race mount installed Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 22 01-08-2011 05:36 PM
NEW engine mount... clos561 MazdaSpeed 3 - Engine, Transmission & Driveline 34 06-12-2009 10:48 AM
lat Panel TV Slim Wall Mount (24-32in screens) $19.86 Haltech Hot Deals Section 0 03-28-2008 10:20 AM
Put the SU Rear Motor Mount on today kneedragger241 MazdaSpeed 3 - Engine, Transmission & Driveline 10 03-27-2008 09:22 PM
Page generated in 0.50560 seconds with 37 queries
