 Old 02-07-2009, 01:35 PM   #1
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world
Default fucked up the inlet hose clamp. what to do?
in search of the psi that my car seems to be missing, i've tightened every hose clamp i can find. just did the throttle body one today.
also, though, i went after the inlet clamp again, despite already tightening it twice. i managed to get it to the point where the hose clamp "slips" aka tighten, tighten, then it 'pops' and goes down a few rungs or whatever you wanna call them.
what should i do? i left it in a 'tight' part of the cycle mentioned above, and presumably the clamp is pretty tight if i got it to the point of slipping. and, if i need to replace it (and i have a t-bolt in hand), what's the easiest way to swap w/o ripping the whole damn inlet out?
08_ms3_gt is offline   Reply With Quote
 Old 02-07-2009, 03:33 PM   #2
mlassek's Avatar
Posts: 200   (View Stats)
mlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to allmlassek is a name known to all
just loosen it until each end separates then do the same thing with your t-bolt and wrap it around the inlet, slide the bolt thru the hole and tighten er up
bent rod
mlassek is offline   Reply With Quote
 Old 02-07-2009, 03:39 PM   #3
aspiring turbo guru
08_ms3_gt's Avatar
fuck, yea, i suppose it really is that easy, isn't it? *smacks head*
if only the inlet was easier to get to, i would've already done it by now. and taken the inlet off to check for shaft play on the turbo.
any tips for how to detach the stock clamp from the glue holding it on? i've been able to do the other ones fairly easily, but i can foresee this one being annoying.
 Old 02-07-2009, 03:43 PM   #4
CHIEFSMS3's Avatar
Posts: 163   (View Stats)
CHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud of
I have been in there and replaced the turbo inlet.
I think that your only option will be to remove the battery and tray
remove the turbo inlet and put the new t-bolt clamp on.
You would have to have very small hands to replace the clamp
with everything still in place.
CHIEFSMS3 is offline   Reply With Quote
 Old 02-07-2009, 08:13 PM   #5
babcockxmx's Avatar
Posts: 539   (View Stats)
babcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the world
just take off the inlet. it takes 10 minutes and will make it hell of alot less stressful
2007 BM MS3
babcockxmx is offline   Reply With Quote
COBB Turbo Inlet Hose for the MazdaSpeed 3 Cobb Tuning MazdaSpeed 3/6 - Turbo Induction 52 03-09-2010 10:46 AM
COBB Tuning Turbo Inlet Hose SALE! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 13 06-17-2009 02:51 PM
Cobb Turbo Inlet Hose Now Available badams118 MazdaSpeed 3/6 - ECU Computer Tuning 24 02-04-2009 11:39 AM
Page generated in 0.25769 seconds with 23 queries
