![]() Join Date: Mar 2010 Location: Spanaway, Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 146
__________________ 2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs) |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score You should be fine reusing them if they looked fine. If you can hear a leak that much I doubt its just the gaskets. |
(Thread Starter) | Not Ranked : 0 score any ideas then? im lost if its not the gaskets lol everything else looks to be fine
| Not Ranked : 0 score Where is the leak coming from? |
(Thread Starter) | Not Ranked : 0 score it sounds like its coming from the turbo,dp,exhaust manifold area. when the hood is open you cant really tell at idle but once you give it a little gas its like a loud leaking farting noise from up there
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score I would check all of your manifold nuts. Possibly the bottom one on the drivers side that's a pita to get to. Tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
(Thread Starter) | Not Ranked : 0 score i didnt take the exhaust manifold off to swap the turbos. but 2 of the studs have bolts seized on them close to the bottom of where the threads meet. im not sure if that is causing them to not go into the turbo well enough or what? when i start it, the noise is super loud on a cold start sounds like insane ticking from the exhaust manifold like a small leak? and dies down with the idle. im lost now lol
![]() Join Date: Feb 2012 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() Thanks: 5
Groaned at 108 Times in 27 Posts
((SLIK-6)) | |
(Thread Starter) | Not Ranked : 0 score FUCK THIS!! i put bolts where the f'd up studs were and now it still sounds like its leaking, and is now pulsing every couple seconds.. its like pulsing then a real light exhaust pop
![]() Join Date: Jun 2013 Location: Alamogordo NM
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Take the e man off. check for blow by. It sucks cock but it's prob a bad e man gasket. Check the face of the manifold that mates with the motor and you should be able to see. |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score I had a pretty bad exhaust leak near the mani/head side. took offf the egr, and tightened them down. Might have to replace the gasket
__________________ atp 2871r, cobb ap,front mount, devils own stage 2 meth,hks ssqv, pg exhaust manifold,port/polished intake mani,intake mani spacer,dnp exhaust electrical cutout,cobb dp, custom exhaust, cpe sri intake,cpe tip, cpe hdfp, turbosmart manual boost controller,itv 22,greddy occ,cpe injector seals, cobb front/rear sways,dominant E rear camber arms,awr endlinks,su front mount, tower bar, drilled slotted rotars/hawk pads |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score damnit. |
| MPS 6 turbo inlet install questions/worries | Dazsmith | MazdaSpeed 3/6 - Turbo Induction | 0 | 11-30-2011 10:03 AM |
| Sure TB gasket install | pzr2874 | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 08-08-2011 07:18 AM |
| turbo or head gasket going out not sure???? | reconbygod12 | Mazdaspeed3/6 General Discussion | 7 | 12-25-2010 11:19 AM |
| Intake manifold gasket install | cm-jp1 | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 06-01-2009 04:31 AM |
