 Old 03-12-2012, 03:41 PM   #1
Kydizzle's Avatar
Posts: 505   (View Stats)
Kydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the world
Default Gasket questions on bnr turbo install
Hey guys. my turbo to manifold and turbo to DP gaskets only have around 10k miles on them from swapping an sst a while back. but after my install of the bnr turbo today i had a bad exhaust leak sounds horrible not sure if those are the problem do i need to replace them again? let me know guys thanks.
2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs)
Kydizzle is offline   Reply With Quote
 Old 03-12-2012, 03:44 PM   #2
You should be fine reusing them if they looked fine. If you can hear a leak that much I doubt its just the gaskets.
 Old 03-12-2012, 03:57 PM   #3
Kydizzle's Avatar
any ideas then? im lost if its not the gaskets lol everything else looks to be fine
 Old 03-12-2012, 03:59 PM   #4
Where is the leak coming from?
 Old 03-12-2012, 04:06 PM   #5
Kydizzle's Avatar
it sounds like its coming from the turbo,dp,exhaust manifold area. when the hood is open you cant really tell at idle but once you give it a little gas its like a loud leaking farting noise from up there
 Old 03-12-2012, 05:08 PM   #6
atvfreek's Avatar
Posts: 7,787   (View Stats)
I would check all of your manifold nuts. Possibly the bottom one on the drivers side that's a pita to get to.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 03-12-2012, 05:39 PM   #7
Kydizzle's Avatar
i didnt take the exhaust manifold off to swap the turbos. but 2 of the studs have bolts seized on them close to the bottom of where the threads meet. im not sure if that is causing them to not go into the turbo well enough or what?
when i start it, the noise is super loud on a cold start sounds like insane ticking from the exhaust manifold like a small leak? and dies down with the idle. im lost now lol
 Old 03-12-2012, 06:16 PM   #8
mazdaspeed4life's Avatar
Posts: 93   (View Stats)
mazdaspeed4life is infamous around these partsmazdaspeed4life is infamous around these partsmazdaspeed4life is infamous around these parts
Groaned at 108 Times in 27 Posts
Damn bro ...sucks
((SLIK-6))
mazdaspeed4life is offline   Reply With Quote
 Old 03-12-2012, 08:48 PM   #9
Kydizzle's Avatar
FUCK THIS!! i put bolts where the f'd up studs were and now it still sounds like its leaking, and is now pulsing every couple seconds.. its like pulsing then a real light exhaust pop
 Old 06-17-2014, 11:38 PM   #10
death wagon's Avatar
Posts: 2   (View Stats)
death wagon is an unknown quantity at this point
Take the e man off. check for blow by. It sucks cock but it's prob a bad e man gasket. Check the face of the manifold that mates with the motor and you should be able to see.
death wagon is offline   Reply With Quote
 Old 08-07-2014, 08:13 AM   #11
h0rsies's Avatar
Posts: 133   (View Stats)
h0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond repute
I had a pretty bad exhaust leak near the mani/head side. took offf the egr, and tightened them down. Might have to replace the gasket
atp 2871r, cobb ap,front mount, devils own stage 2 meth,hks ssqv, pg exhaust manifold,port/polished intake mani,intake mani spacer,dnp exhaust electrical cutout,cobb dp, custom exhaust, cpe sri intake,cpe tip, cpe hdfp, turbosmart manual boost controller,itv 22,greddy occ,cpe injector seals, cobb front/rear sways,dominant E rear camber arms,awr endlinks,su front mount, tower bar, drilled slotted rotars/hawk pads
h0rsies is offline   Reply With Quote
 Old 08-07-2014, 08:49 AM   #12
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
damnit.
MPS 6 turbo inlet install questions/worries Dazsmith MazdaSpeed 3/6 - Turbo Induction 0 11-30-2011 10:03 AM
Sure TB gasket install pzr2874 MazdaSpeed 3 - Engine, Transmission & Driveline 3 08-08-2011 07:18 AM
turbo or head gasket going out not sure???? reconbygod12 Mazdaspeed3/6 General Discussion 7 12-25-2010 11:19 AM
Intake manifold gasket install cm-jp1 MazdaSpeed 6 - Engine, Transmission & Driveline 8 06-01-2009 04:31 AM
Page generated in 0.31139 seconds with 27 queries
