  • 1 Post By my2k13speed3
  • 1 Post By mrboostman
 Old 12-03-2015, 03:03 PM   #1
mrboostman's Avatar
Posts: 101   (View Stats)
mrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to all
Default Gen 1 GTX3076 Upgrade
Hi all,
Picked up a pre owned 08 Speed 3 GT about 6 months ago with 150K on it. Did not take long to bolt it ( look at sig). Got an ATP GTX3076 in a box ready to go on in the next couple of weeks. Call me crazy call me a fool but I intend on making 400 WHP on a 150K stock block with lousy California 91 octane. Lucky for me corn is only 30 minutes away. Will start a build thread in a couple of weeks.
Happy Holidays.
2008 MS3 GT, Fully Bolted, Cobb AP V3, TR8 FMIC, JBR Piping, JBR 3.5 Wide Path, Autotech Internals, CPE Stage 2 Rear Motor Mount, CNT Catless DP, CNT Cat Back, 51R Battery Box, Cobb Short Shifter, Enkei RPF1's, Koni Yellows, GTX3076R, Freektuned.
mrboostman is offline   Reply With Quote
The Following User Says Thank You to mrboostman For This Useful Post:
MD1032 (12-04-2015)
 Old 12-03-2015, 03:06 PM   #2
mktx01's Avatar
Posts: 185   (View Stats)
mktx01 is infamous around these partsmktx01 is infamous around these partsmktx01 is infamous around these parts
You can do it!
Build thread and results should be interesting. Good luck.
mktx01 is offline   Reply With Quote
 Old 12-03-2015, 03:14 PM   #3
mrboostman's Avatar
Thanks for the reply. I figure if the motor goes I will just put in a built one. Should be fun while it lasts.
 Old 12-03-2015, 03:32 PM   #4
mktx01's Avatar
Oh, forgot, great choice on the 08' GT but I'm a bit partial to that model.
 Old 12-03-2015, 08:21 PM   #5
mrboostman's Avatar
I really like the model too. By the way bought many parts from RPM.
 Old 12-04-2015, 06:07 PM   #6
sheston's Avatar
Posts: 1,847   (View Stats)
Sometimes it's just hard to keep the smile off my face reading all these build stories
 Old 12-04-2015, 06:12 PM   #7
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
I'm really curious to see if you will actually hit 400whp on shitty ass CA 91 octane... realistically I can't imagine you seeing more than 350-375 on just pump...
why not just do 91 with meth?
Cheapspeed likes this.
The Following User Says Thank You to my2k13speed3 For This Useful Post:
mrboostman (12-04-2015)
 Old 12-04-2015, 06:42 PM   #8
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
He said he has access to corn. 400 will not be possible on 91 alone.
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
 Old 12-04-2015, 08:05 PM   #9
mrboostman's Avatar
Thanks for the replys. gdawg25 is right I will be running corn with the 91 to hit the 400. The question is how much corn? Stratified told me with 4 gallons per tank I would run out of injector before octane. I would be happier if I only had to run 3 gallons. Can someone chime in who has run a BT with 91 as to a recommended corn mix ratio.
 Old 12-04-2015, 08:30 PM   #10
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I ran 25% E85 and 75% 91 with my gtx3076 and made 370awhp without additional fueling.
23 psi and about 16* timing. Turbo was sleeping lol...
But i have a much more efficient setup (v-band, CPE mani, FMIC, EWG) so it's not really a fair comparison but you could still come close.
If you keep the tmic I would suggest you get a cheap meth kit with a small nozzle for cooling.
Btw, 370awhp ~415whp for you =) VD numbers
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 12-04-2015, 10:03 PM   #11
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
You won't make 400whp without tuning for meth, full exhaust including equal length headers.
 Old 12-05-2015, 12:21 PM   #12
mrboostman's Avatar
Did you run that 14.2 with the GTX3076R?
 Old 12-05-2015, 03:22 PM   #13
Cheapspeed's Avatar
No, that was on the k04 with E50.
 Old 12-06-2015, 02:46 PM   #14
mach69's Avatar
Posts: 79   (View Stats)
mach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond repute
I feel bad for you Cali folks who can only get the crappy 91 octane.
Back on topic, I would perform a compression test on the motor before installing the turbo.
2008 Mazdaspeed 3 - True Red
Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map
Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM
Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings
mach69 is offline   Reply With Quote
 Old 12-06-2015, 06:00 PM   #15
sheston's Avatar
Someone should use Meth in tank to see if they get more injector headroom, I use less Meth than Eth to get the same octane knock protection. Might help you
 Old 12-06-2015, 06:35 PM   #16
mrboostman's Avatar
I think I will get a compression check. Can anyone chime in on acceptable compression?
 Old 12-07-2015, 04:23 PM   #17
Boost_creep's Avatar
Posts: 829   (View Stats)
Neutral  +1 score
180 psi across all cylinders would be acceptable.
 Old 12-07-2015, 09:01 PM   #18
mrboostman's Avatar
According to this thread 165-175 PSI should be enough.
DISI Compression Results
 Old 01-23-2016, 11:27 AM   #19
mrboostman's Avatar
Got freektuned dynotuned in SoCal yesterday. Justin is awesome. Tuned it to 380whp/380tq . He said it had more but I decided to stop before the 400 mark, because of 160k on the motor. 20 away from my goal, I guess I can live with that for now. It is so hard to keep straight with that power already. Use freektune, Justin is the best. Thanks Justin.
Justin@Freektune likes this.
Justin@Freektune (01-23-2016)
 Old 01-23-2016, 01:45 PM   #20
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Pleasure working with you sir! Car made that power effortless too
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Cheaps gtx3076/ewg Cheapspeed MazdaSpeed 3/6 - Big Turbo Builds 368 07-16-2018 06:00 PM
ATP GTX3076 EWG Shit speedy308 2010 MS3 - Big Turbo Builds 31 09-13-2014 08:03 AM
MS6 GTX3076 EWG Bulgsta MazdaSpeed 3/6 - Big Turbo Builds 76 08-12-2014 09:32 PM
endlink upgrade needed w/ ASB upgrade? red07 MazdaSpeed 3/6 - Suspension & Brakes 12 11-26-2008 01:34 AM
Page generated in 0.38248 seconds with 29 queries
