 Old 09-14-2016, 09:12 PM   #1
mrboostman's Avatar
Posts: 101   (View Stats)
mrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to allmrboostman is a name known to all
Default Gen 1 TR8 & JBR Piping Installed
Hey All,
Installed a Treadstone TR8 Intercooler and JBR Piping today. After it was installed CEL and Traction Loss lights came on. Code P0638 came up on the AP. I got the common no throttle response problem. I cleared the code and throttle response was back. I am still getting the code after I clear it each time. Read some threads on the problem and some were caused by foreign objects getting sucked into the throttle body and blocking it up.
It leads me to believe that some metal from inside the TR8 core or some kind of debris lodged somewhere in the intercooler piping got sucked into the throttle body and maybe into the engine.
Some have said their engines have blown after getting the Code P0638.
It is pretty upsetting when you pay money to do an upgrade on a perfectly
running car and end up causing this kind of problem. Ain't that a bitch.
I am not giving up all hope. Tomorrow I will pull the throttle body and hope there is something stuck in there I can remove. If not it is probably already in the engine and may blow soon.
If anyone had a similar problem with this code and knows ways of correcting it, please chime in.
My advise to anyone getting ready to do a similar upgrade would be to maybe blow some compressed air through the core and piping before installing it.
Thanks.
2008 MS3 GT, Fully Bolted, Cobb AP V3, TR8 FMIC, JBR Piping, JBR 3.5 Wide Path, Autotech Internals, CPE Stage 2 Rear Motor Mount, CNT Catless DP, CNT Cat Back, 51R Battery Box, Cobb Short Shifter, Enkei RPF1's, Koni Yellows, GTX3076R, Freektuned.
mrboostman is offline   Reply With Quote
 Old 09-28-2016, 09:45 AM   #2
jmen73's Avatar
Posts: 63   (View Stats)
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
So did you find anything?
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
Ms6 piping in ms3 Crasth Mazdaspeed3/6 General Discussion 5 05-04-2016 03:50 PM
Cx racing piping or pg piping for my fmic blake0521 2010 MS3 - Turbo Induction 34 09-25-2014 03:51 PM
PG FMIC Piping vs CX Racing Piping GreyGhost 2010 MS3 - Turbo Induction 2 04-17-2013 08:37 PM
Page generated in 0.22927 seconds with 21 queries
