![]() Join Date: Mar 2017
Rep Power: 0 ![]() Thanks: 0
Groaned at 6 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score Mitch |
Groans: 438
| Not Ranked : 0 score Same. Learn to search.
__________________ All good things must come to an end... |
| The Following User Says Thank You to g00s3y For This Useful Post: | Vansquish (03-15-2017) |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Tootles, twinkletoes.
![]() Join Date: Apr 2015 Location: Sterling Heights Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Bye
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. |
![]() Join Date: Sep 2016 Location: Ringgold, Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 411
| Not Ranked : 0 score New intake without maf calibration? Good luck with that.
__________________ ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score At least he got 2 posts :-)
__________________ Max Bolted and Built Stock K04 |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following 2 Users Say Thank You to KiwiFlavor For This Useful Post: | monkey.bones.007 (03-19-2017), Varomnia (03-16-2017) |
![]() Join Date: Jun 2009
| Not Ranked : 0 score OP's post was sad, but this one is about as bad. Most aftermarket intakes when added to the stock turbo and TIP and stock ECU tune require no maf cal or change in tune whatsoever, if they have the same diameter maf housing. Most do. That's how most intakes from the major aftermarket companies' intakes are made - intended to be plug and play on stock tune, TiP and K04, and often with air straighteners if they are CAI style.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 03-20-2017 at 11:39 AM. |
| The Following User Says Thank You to MSMS3 For This Useful Post: | tegxsi (03-17-2017) |
![]() Join Date: Dec 2014 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
| Not Ranked : 0 score Wow. I'd call that a fairly nice answer and he still got mad. Yea, you don't belong here. Sent from my ONE A2005 using Tapatalk |
| The Following User Says Thank You to Biobandit For This Useful Post: | monkey.bones.007 (03-19-2017) |
![]() Join Date: May 2013 Location: CO
Rep Power: 2406 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score Hey op, I found a group that's probably more your style. Look them up and see if they can answer your question. ![]() Crapatalk, it sucks for free! |
| The Following User Says Thank You to monkey.bones.007 For This Useful Post: | KiwiFlavor (03-20-2017) |
| Recommended Air Intake for my 2013 Speed3 | Inspec25 | MazdaSpeed 3/6 - Turbo Induction | 14 | 05-03-2014 01:11 PM |
| Speed6 intake on Speed3? | michaeljp | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-07-2010 06:27 PM |
