(Thread Starter) | Not Ranked : 0 score Lets talk about Bigger Throttle Bodies and this one: SilverDemon/JM Fabrications Intake Manifold Interest Thread there seems to be some considerable interest in the bigger 75mm TB. Its a direct PnP to the stock flange (either stock IM or the JMF mani or anything with stock bolt pattern). All you would need to do is swap 2 pins on your stock connector and change your APP/DWB tables in ATR. So lets get a serious interested list going. You pretty much have to get one if your planning on getting the JMF mani and it would prob make a considerable amount of power on a PnP stock IM if your BT. Price point should be between $250 and $350 because we really need to combined 2 TB's to make one and it also will include a PTFE spacer (aka same as the TIG but 1/2" thick) which is required to make it mount flush to the IM flange. These are hard enough to find so get one while you can!!! .9 SilverDemon 1. NJSPEED3 2. TWOptSL0W 3. doubleflusher 4. downmented 5. chimmike 6. SFWD 1934 7. PapaSmurf 8. mrmonk7663 9. jmhinkle 10. jacksonMS30 11. Etipp98 12. sLow6 13. theschrum 14. SIXual Panda 15. Celestspeed3 16. Nitr0EngiE 17. Speedie6 18. ManiacMx3 19. SSinstaller 20. LittleredMPS 21. ozzzzz 22. Don06speed6 23. BobtailedSnail 24. 06Speed6
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner Last edited by superskaterxes; 12-16-2012 at 08:25 AM. |
| The Following 21 Users Say Thank You to superskaterxes For This Useful Post: | 06Speed6 (12-15-2012), atvfreek (12-18-2012), djuosnteisn (12-14-2012), Don06speed6 (12-14-2012), doubleflusher (12-14-2012), Downmented (12-14-2012), Easter Bunny (12-15-2012), JacksonMS30 (12-14-2012), Jh8909 (12-14-2012), kmac (12-14-2012), maxwella (12-15-2012), mazdafreak (01-05-2013), Nitr0EngiE (12-18-2012), NJSPEED3 (12-14-2012), redboat (04-18-2013), SilverDemon (12-14-2012), SIXual Panda (12-14-2012), Snyeed (01-20-2013), Speed_j23 (12-14-2012), Tomas (12-18-2012), wolly6973 (12-20-2012) |
Groans: 433
| Not Ranked : 0 score FWIW, unless you have big turbo and major headwork done, with the JM IM, this isn't gonna do much, really, on a stock IM, stock head, stock turbo car.
you dont need any headwork or cams or anything else to benefit from this. i would say for stock turbo its a waste but even on a ported stock IM (which 99.9% of the forum has on BT), the stock TB is a major restriction.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score Was that the one you are using? How does it fit around a regular 3" coupler. Put me down for one... |
yes exact one i was using. its like 3.1 inches or something but a 3" coupler fits just fine and is nice and tight.
| The Following User Says Thank You to superskaterxes For This Useful Post: | kmac (12-14-2012) |
Groans: 125
| Not Ranked : 0 score Tight is good, put me down for one, ill need it for my ...new...build |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score |
Groans: 433
What I'm getting at is, for stock turbo guys, or even guys with ported IM's but stock head (not even mild porting), there are better places to spend the money......yank the head, have a shop hog out both sides.....gains will be had!
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
lets think about this for a second. the stock TB is 60mm which is 4.37 in^2. the blade prob accounts for 20% of that area which leaves you with ~3.5in^2. lets ROUGHLY say each port on the head is 1 square inch (its def bigger but lets go with this for now). thats 8 in^2 of total area the air can flow through. 8 in^2 >>> 3.5 in^2 catch my drift? your always limited by your greatest restriction. This is why i saw such big gains on the JMF mani with bigger TB vs. stock one because even though i had the mani, the stock TB was still the biggest restriction.
| The Following 11 Users Say Thank You to superskaterxes For This Useful Post: |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score Gimmie nao!!!
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following User Says Thank You to doubleflusher For This Useful Post: | NJSPEED3 (12-14-2012) |
Groans: 113
| Not Ranked : 0 score Im about to Rob Pablo tonight! |
| The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post: |
![]() Join Date: Jul 2012 Location: Glen Burnie, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 464
| Not Ranked : 0 score Has anyone tested this on a k04 to be sure we get no benefit?
__________________ 2006 CSRT8 CAI, Tune |
Groans: 433
| Not Ranked : 0 score I might be in just because the price is stupid cheap, honestly. If I can snag 10-15whp at teh same boost level that'd be great. Especially since torque doesn't increase much overall.
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | kmac (12-14-2012), superskaterxes (12-14-2012) |
Groans: 113
| The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post: | Chimmike (12-14-2012), kmac (12-14-2012), ms3blackmica (12-14-2012), superskaterxes (12-14-2012), wolly6973 (12-20-2012) |
![]() Join Date: Mar 2011 Location: Nor Cal- Pittsburg
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score I would be interested in this. Do you have an ETA on when they would be available? Did you just have to knock down your DBW/APP tables to compensate for the increased air flow? Jason
__________________ JRL Tuning 510-459-7229 www.full-race.com |
and yes there was very minor adjustments done in ATR. i can provide you with the tables i used or u can tweak them as u see fit.
| The Following 5 Users Say Thank You to superskaterxes For This Useful Post: | Alpha (12-14-2012), kmac (12-14-2012), NJSPEED3 (12-14-2012), SpeedRebirth (12-18-2012), wolly6973 (12-20-2012) |
| Not Ranked : 0 score Sounds good to me. Go ahead and put me down as well. Jason
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
| Not Ranked : 0 score winning
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
| The Following User Says Thank You to Downmented For This Useful Post: | kmac (12-14-2012) |
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
| Not Ranked : 0 score Put me down ant Sent from my flying tapadildo
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
| The Following User Says Thank You to PapaSmurf For This Useful Post: | superskaterxes (12-14-2012) |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score Sure, why not... I've got every other bolton lol
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
| The Following User Says Thank You to Alpha For This Useful Post: | kmac (12-14-2012) |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score Just to chime in, I have over 10,000 miles on this TB with no real issues. Dialing it in can be a bit of a pain, but that is likely with any modification to the TB (I have seen threads where people with ported stock took a lot of work to dial in.) The way I have mine right now, it can be a little rough in the on->off or off->on throttle between 2000-3000rpm but nothing that keeps it from being extremely daily drivable. I need to test superskater's tables to see if they provide improvements on my setup though.
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. |
| The Following 4 Users Say Thank You to Erich For This Useful Post: |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score Put me down. Timing works out for build of course.
__________________ |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
| Not Ranked : 0 score Alright, I'm in. Put me on the list please
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - |
![]() | | #24 | ![]() |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score Can't say I'm in right now but definitely subbed for future interest
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
![]() | | #25 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Put me down for one
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
![]() | | #26 | ![]() |
![]() Join Date: Feb 2011 Location: Killeen, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 504
Groans: 34
| Not Ranked : 0 score I'm in.
__________________ BT Build in process, should have engine running in a couple days.....knock on wood. |
![]() | | #27 | ![]() |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score I am in. What parts are you using from the stock TB other than the cover? Would I be able to send one of my stockers to you to make it cheaper, or possibly just swap parts over myself?
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score its actually from a different TB altogether but it has the same connector as stock which makes it PnP.
![]() | | #29 | ![]() |
![]() Join Date: Nov 2010 Location: Lancaster, PA
Rep Power: 1111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,516
Groans: 56
| Not Ranked : 0 score Put me on the list! I'm in! |
![]() | | #30 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
| Not Ranked : 0 score I'm down, money ready.
__________________ Fueled by the haters. |
![]() | | #31 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score I feel i could really use this, if we can keep closer to 250 ive had some recent job issues changes only working part time right now how many mm is stock tb |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score 60mm
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Nitr0EngiE (12-14-2012), SarcasticOne (12-20-2012) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score put me down for sure |
![]() | | #34 | ![]() |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
__________________ 360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust |
![]() | | #35 | ![]() |
![]() Join Date: Jun 2008 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
Groaned at 6 Times in 1 Post
| Not Ranked : 0 score I am most definitely in! Add me to the list please.
__________________ Current mods.......Starting Over...Bigger and better! |
![]() | | #36 | ![]() |
Groans: 60
| Not Ranked : 0 score Keep me at the bottom of the list. I don't even have a running car, but I'm in. I'll let it sit until I fix my shit next summer...
![]() | | #37 | ![]() |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score Oh gawd I want this, but I only has TMIC and plans for BNR ![]() Must check if manifold has tmic mount
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
![]() | | #38 | ![]() |
![]() Join Date: Jan 2010 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 188
| Not Ranked : 0 score Im in + whatever it costs to ship downunder.
__________________ Time for some BT action...Bring it!!! [SIGPIC][/SIGPIC] |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Your problem is bad mojo emanating from your ported injectors. To break the curse you must send those injectors to the far reaches of the country (Seattle should be good.)
| The Following 5 Users Say Thank You to Erich For This Useful Post: | 06Speed6 (12-15-2012), Easter Bunny (12-15-2012), Monotonous ONE (12-15-2012), SSinstaller (12-14-2012), superskaterxes (12-16-2012) |
![]() | | #40 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
Top of the list bitches!!
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
| The Following 8 Users Say Thank You to SilverDemon For This Useful Post: | 86AmishMs3 (12-15-2012), BlueStreak (12-18-2012), BrianB6 (12-17-2012), doubleflusher (12-14-2012), Easter Bunny (12-15-2012), jmhinkle (12-17-2012), NJSPEED3 (12-14-2012), Vader (12-14-2012) |
| oil in throttle body | darkm6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 17 | 03-13-2010 06:26 AM |
| Throttle Body Spacer | SPEEDRAC3R | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 12-01-2009 10:49 AM |
