  • 1 Post By dustinarden
 Old 09-08-2015, 02:50 PM   #1
dustinarden's Avatar
Posts: 113   (View Stats)
dustinarden is just really nicedustinarden is just really nicedustinarden is just really nicedustinarden is just really nicedustinarden is just really nice
Default Got my boost gauge installed
Got the gauge installed yesterday. Pulls about 20ish on vacuum at idle. I've seen boost go as high as 20 (or really f'n close to it).
I've noticed when going WOT trying to see where I peak the needle is very "jittery". When i'm doing a nice long pull it seems far more stable as it climbs.
Is this normal or indicative of something that needs to be looked into?
I might be able to get a video of it, but I doubt it. Nothing says safe like video'n with one hand and trying to steer and shift with another :/
dustinarden is offline   Reply With Quote
 Old 09-08-2015, 03:10 PM   #2
Police - Grammarhead
Vansquish's Avatar
If you're on the stock tune/turbo, you're not pulling 20psi of vacuum, and you should be around 15psi of boost at a max. It sounds like something isn't working properly.
 Old 09-08-2015, 05:45 PM   #3
idle doesnt seem to be off. At least no different than it used to be. Is it possible the line is kinked or is leaking somewhere? I got two pretty nasty kinks in the line when pulling it up through the vent, but I clipped the line before those kinks.
I've noticed the vacuum goes down lower than the 20's at times. I think its when the clutch is engaged but not idle.
The only visible mod that I have that would relate to pressure is a cold air intake (mazdapeed CAI - filter is in the fender well next to the driver tire).
The boost pressure goes up to the 20's or just before it but again thats only at WOT and the needle is very shaky ...
 Old 09-08-2015, 06:07 PM   #4
ihasmazda's Avatar
Posts: 1,011   (View Stats)
i used to have the same gauge on another car. Are you using the supplied air line that came with the gauge?
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
 Old 09-08-2015, 06:09 PM   #5
yeah. tiny little nylon/hard plastic 1/8inch line if i'm not mistaken. Have that tightened into the plastic T it came with (brass compression nut to the T from the line, and the same nut on the back of the gauge).
 Old 09-08-2015, 08:13 PM   #6
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Check it against your AP to see what its reading from the OBD. My vacuum is always around -9 I think it may have dipped into the -10's but never close to -20. I also am in MS3 not sure if you are in MS6 or not.. and if there is even a difference in vacuum between the two.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 09-08-2015, 08:14 PM   #7
I don't have an access port. I wish I did!
I'm in an 07 speed6.
 Old 09-08-2015, 08:25 PM   #8
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
That's on an AP that reads -psi
@dustinarden; that boost gauge reads inches of mercury in vacuum and mine reads -22inMg at idle with ac off on my autometer mech gauge.
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
The Following 2 Users Say Thank You to davychronic For This Useful Post:
5doorsoffury (09-09-2015), Atticaz (12-31-2015)
 Old 09-09-2015, 07:36 AM   #9
^Thanks!
I noticed at idle with AC on it tends to stick pretty close to -20. When in gear but not on the throttle i've seen it go down to -25 for sure. Confirmed today on the way into work. Also shot this quick video of the sputter i'm talking about. Video quality kinda sucks .. kind hard to make out what the needle is doing - but hoping someone can say "normal or not" haha.
https://youtu.be/HM_1h8lLNfM
 Old 09-09-2015, 07:40 AM   #10
Yatta's Avatar
Posts: 1,862   (View Stats)
I would test the gauge with a vacuum pump and/or a known good source of pressure... seems to be reading high on both ends? or maybe its ‘Absolute’ pressure (I kid).
 Old 09-09-2015, 07:47 AM   #11
Mechanical boost gauges have that flutter in the needle because of how the ebcs works. Mine does the same thing, no worries. With my ac on mine sits around 19inmg, i wouldnt worry about it. Youll notice on your ap when you are in boost, it never stays at the same number. Just the nature of the beast, if you dont like the flutter than an electric boost gauge should clear that up.
Haha
 Old 09-09-2015, 07:56 AM   #12
I dont really mind the sputter to be honest. I just wanted the gauge to see where I was heading as far as boost goes. With the other mods done to the car I wanted to be sure I was at or close to stock levels.
@davychronic - thanks for the help. I appreciate it. Now I can go worry with important things.
The Following User Says Thank You to dustinarden For This Useful Post:
davychronic (09-09-2015)
 Old 09-09-2015, 08:42 AM   #13
Yea its not smooth like spring operated boost control so its flucuates a lot under boost while the ebcs trys to maintain whatever boost you tell it to.
but if you are hitting 20psi under boost on a stock map something is SERIOUSLY wrong @dustinarden;
 Old 09-09-2015, 08:53 AM   #14
Yatta's Avatar
didn’t catch the in/mg... another way to reduce (not remove) the needle hop is to use a liquid filled gauge, but an electronic gauge would be cheaper and more effective I think.
 Old 09-09-2015, 10:12 AM   #15
ihasmazda's Avatar
which gauge pod do you have there. i need to pick one of those up before they disappear like every other ms6 part...
 Old 09-10-2015, 09:51 AM   #16
I was watching it today and it seemed to be more like 15-17 under WOT. I'm going to keep my eye on it for the next few days and see if I see it go to 20 again .. maybe I just thought it was 20?
its a blockhead8 pod molded into the stock vent. The transaction went very smooth with him. Paypal'd the money and had the pod within a week or so.
painless! The vent seems to be a little looser than I would like, but I havent really tried to wedge it in there too hard yet (in case i had to fix anything with the wiring) but even as it is it hasnt moved at all during normal driving/throttle, etc. Very pleased with it so far!
Atticaz likes this.
ihasmazda (09-10-2015)
 Old 09-10-2015, 04:01 PM   #17
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
first you should be idling about 18-20 in/hg's. The fluttering it like previously mention an issue with your EBC or your tune.
track weight 3220
street weight 3370
MS6: finally installed my fvcking boost gauge m4tic MazdaSpeed 3/6 - Car Audio & Electronics 51 02-16-2014 04:09 PM
aftermarket boost gauge installed SPEEDfreak239 2010 MS3 - Car Audio & Electronics 33 05-12-2012 01:38 PM
ProSport Premium Boost Gauge Installed nmmazdaspeed3 Appearance - WHITE 11 03-31-2011 02:58 PM
Help, installed STRI Boost Gauge.. Stuck at 30psi marcusdigi MazdaSpeed 3 - How-To's 8 07-05-2009 03:00 AM
Page generated in 0.39040 seconds with 26 queries
