![]() | | #41 | ![]() |
![]() Join Date: Jul 2008 Location: Raeford, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 154
| Not Ranked : 0 score That sucks about the PG headers. I need to order some headers i am thinking about going with the DNP? |
![]() | | #42 | ![]() |
![]() Join Date: May 2008 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
(Thread Starter) | Not Ranked : 0 score Well the PG manifold might be here by next weekend maybe. But I'll be out of state Saturday. Might do the install Sunday. But I have 5 mid-term essay's due the following week. So if not next weekend, maybe the next. Although I do have 3 days off of school. So maybe? I'll post up any results and how the GT28 responses to it. Tonight I spiked up to 24psi. I think that happens when I run up too high in the rpms to shift. I try to keep my shifts under 6000rpms to hit a sweet spot for the next gear. Usually the spikes are 22 psi. Anyways, I'll look up that Wilmington shop. Thanks for the info.
__________________ 2012 MX-5 SE |
![]() | | #43 | ![]() |
(Thread Starter) | Neutral : +1 score Manifold finally arrived Friday. Installed it friday night. Here's the pic of the PG manifold with ceramic coating by Jet-Hot. (posted this pic in the PG threads) Now I can start to get down and dirty with some SB tuning. Then off to the dyno. Gotta wait for decent weather though...
| The Following User Says Thank You to JimmyMac For This Useful Post: | RocketScientist (04-24-2010) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Nice... Looks good. How hard was it to get the stock manifold off?
__________________ 2012 Mazdaspeed3 LSM Should have gotten a speed6 2008 Mazdaspeed3 GT Black Mica [sold] Built motor, Etc. 383 hp 401 tq GTX2867R @ 25 psi |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well for me, getting the stock manifold off with the stock turbo was a piece of cake. However, with the GT turbo, it's kinda a pain in the ass because of the studs sticking out of the head and the big fat compressor housing on the GT turbo. I played dumb and didn't unbolt the dp from the turbo. So I had to man handle the manifold out of there. I didn't bother taking off the valve cover either. It may seem impossible. But I found a way to get the PG manifold in there. Kinda like the preschool ball with shaped holes in it, and you had to put the correct block into the correct hole to fit it in there. I wish the weather would warm up so I can head out to tune the car some. I'll play with it this weekend. Wish I had the Standback V3 software. I hate the V2 software. PITA. Hey, where do they cruise in Fay? What's the main strip?
![]() | | #46 | ![]() |
| Not Ranked : 0 score the main places alot of people go are skibo rd. or raeford rd. Have you noticed any other exhaust manifolds that are good? Besides PG?
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score DNP looks good. But I would wait for the Steedspeed. That looks to be a pretty good unit with an external wg port already machined into the unit for future upgrade possibilities.
![]() | | #48 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Did ATP fix the problem with the boost creep? When not, how can we fix it without using a external westgate? |
![]() | | #49 | ![]() |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() Thanks: 4
| Not Ranked : 0 score Any update if ATP fix the problem with the boost creep? |
![]() | | #50 | ![]() |
| Not Ranked : 0 score No, they said it was not the turbo causing the issue. They suggested getting an external wastegate, or porting the internal wastegate (causing it to leak boost BTW.) Another option that they offer is a "surge protected compressor housing"
| The Following User Says Thank You to 7mileshome For This Useful Post: | dlogic (09-13-2009) |
![]() | | #51 | ![]() |
| Lurkers
Posts: n/a
| anyone have pics of the restricter pills ?> |
![]() | | #52 | ![]() |
| Banned ![]() ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score whos using the 2871 |
![]() | | #53 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score Use t3 flanged turbos. I would advise going with that over an ATP stock flanged turbo ANY day. |
![]() | | #54 | ![]() |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() Thanks: 0
Groaned at 8 Times in 5 Posts
| Neutral : -1 score gt turbo's ftw |
| The Following 2 Users Say NO Thank You to phong3992 For This Un-useful Post: |
![]() | | #55 | ![]() |
![]() Join Date: Jul 2008 Location: new york city
Rep Power: 0 ![]() Thanks: 1
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score I took my turbo off my 2007 speed 3 today no blades left on compressor side of turbo and was making 5 to 9 psi.I spoke to B N R turbo has anyone used there stage two upgrade whch bolts up to my down pipe and exhaust manifold .Looking for feed back before i make a purchase,i would greatly appreciate ny members imput.My car has mazdaspeed cai,greedy exhaust,turbo xs dp,rp,bov,accessport. |
![]() | | #56 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors | |
![]() | | #57 | ![]() |
![]() Join Date: Feb 2010 Location: Peru, IN
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score im wanting to get the gt35r and i had a question about how the whole 2-1 hoses work and how it goes to stock soleniod...i kno u will say read the thread and go to link but the link isnt working for me and ive tried searching and thats not working so if u could paste it in here on how u could hook that up that would be great
__________________ 2008.5 Mazdaspeed 3 GT...Fully Forged Block...Ported Heads...Wiseco Forged Pistons/Pauter Forged Rods...COBB SRI...COBB DP...COBB AP...PnP Fuel Pump Internals...Cometic Head Gasket...ARP Head Studs...Denso Iridium HR:8...StreetUnit Rear Motor Mount...ACT 6 Puck Sprung Clutch Kit...Aluminum Flywheel... |
![]() | | #58 | ![]() |
| Not Ranked : 0 score JimmyMac describes it best on the first post of this thread.
![]() | | #59 | ![]() |
| Not Ranked : 0 score but what about the boost prob?
![]() | | #60 | ![]() |
| Not Ranked : 0 score Check my proir posts (about 8 ago) on this thread. You can call ATP and ask them their opinion, but if your asking me, the only way to manage your boost correctly on a non-oem turbo is to have an external wastegate+manual/electronic boost controller.
![]() | | #61 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score supposedly their porting the housings now?? not sure if you have to ask for it, and if it is actually enough to effectively control lower boost lvls. be curious to see results???
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #62 | ![]() |
| Banned ![]() Join Date: Sep 2009 Location: La Crosse, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
| Not Ranked : 0 score ATP FAIL FLANGE |
![]() | | #63 | ![]() |
| Not Ranked : 0 score ^^Explain Please^^
![]() | | #64 | ![]() |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score atp fail flange?
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
![]() | | #65 | ![]() |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score the atp mazda specific turbine housing that is set up for iwg is restrictive - a regular t3 flange with out the internal blockage of a iwg setup flows better - you have to run an ewg t3 mani setup to make this work tho here's a story about when socks changed turbine housings Byebye ATP Fail
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) Last edited by cpolly69; 03-26-2010 at 07:02 AM. |
| The Following User Says Thank You to cpolly69 For This Useful Post: | 7mileshome (03-26-2010) |
![]() | | #66 | ![]() |
![]() Join Date: Nov 2010 Location: Breckenridge CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
Groaned at 93 Times in 33 Posts
| Not Ranked : 0 score it might be a fail flange, i personally cant believe a turbo that works in IWG config on other cars magic/epic fails on ours, that is the only reason they would insist its not their turbos and not wind up with a civil suit up their anal crevass dont worry, before you start typing ur flame, i am going to possibly eat dirt when my atp 3071 arrives this week(then the saving begins, since i am getting this B protuned again) since the sad fact is, people upgrade their turbos and dont change the tune... how or why ppl think this is ok if you want your car to run... nm im not going any further but well see if given all the love and care if this thing will in fact run... otherwise ATP needs to STFU and withdraw their product from the market either way, i willr eport back my personal experiance(probable rape according to this forum)
__________________ Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray! Cpe: FMIC, CAI, TIP, HPFP, bone engine mount Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar Turbine Tech: Extra front motor mount, both diff mounts +bushings EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk, AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto. 17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand |
![]() | | #67 | ![]() |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score holy fucking old thread genius!!! Look at post dates first
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
![]() | | #68 | ![]() |
Groans: 27
| Not Ranked : 0 score Haha this^^ Man ATP has redesigned their iwg setup for the 3071 since this old ass thread. Sent from my iPhone using Tapatalk
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
![]() | | #69 | ![]() |
![]() Join Date: Sep 2009 Location: Fort Collins, CO
Rep Power: 0 ![]() Thanks: 27
| Not Ranked : 0 score So problem is fixed for the 2871 too i take it? Or is BNR the way to go... |
![]() | | #70 | ![]() |
![]() Join Date: Jun 2013 Location: Jackson Tn
| Not Ranked : 0 score Hey guys, I read this forum and was wondering when hooking up a mbc into the bpv hose, that's where i have my prosport booost gauge at. just curious i'm new to this site but it got me thinkin... would i just get a different T fitting to incorperate it? |
![]() | | #71 | ![]() |
Groans: 27
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) | |
![]() | | #72 | ![]() |
![]() Join Date: Oct 2012 Location: Northern Utah
Rep Power: 0 ![]() ![]() ![]() Thanks: 12
Kyle | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/gt-series-turbo-questions-8572/ | ||||
| albuquerque nm mazda 6 owners - Mazda6 / Atenza | This thread | Refback | 02-15-2009 10:36 AM | |
| Display Modes | |
| ENDING: lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) | Haltech | Hot Deals Section | 0 | 04-10-2008 05:21 AM |
| Expiring: lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) | Haltech | Hot Deals Section | 0 | 04-07-2008 07:02 AM |
| lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) | Haltech | Hot Deals Section | 0 | 04-04-2008 09:50 AM |
| EXPIRING lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) | Haltech | Hot Deals Section | 0 | 03-27-2008 11:50 AM |
| lenovo ThinkPad Coupon Code (10% off X Series, 15% off R Series, 10% off T Series) | Haltech | Hot Deals Section | 0 | 03-26-2008 01:24 AM |
