 Old 10-14-2009, 02:04 AM   #41
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
From my understanding, you need a pill if you are using an internal WG ans the valve bleeds off the excess boost pressure. Whereas an EWG bleeds off the pressure for you. So the pill is not needed... sound right?
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
 Old 10-14-2009, 08:28 AM   #42
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
bump????
The Following User Says Thank You to For This Useful Post:
SpeedSixxx (12-10-2009)
 Old 10-14-2009, 09:25 AM   #43
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Originally Posted by 18psiWhiteMS3 View Post
bump????
If you run EWG like the This perrin instruction shows you do not need a pill (the last diagram for EWG).
If you leave the top nipple of the ewg and use the solenoid to bleed air away from the wastegate, you will need a pill (this is a similar setup to stock).
Hook it up like the perrin instruction and don't worry about any of the pill nonsense.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
phantom3 (10-14-2009)
 Old 10-21-2009, 03:12 PM   #44
phantom3's Avatar
Groans: 190
I just got off the phone with Greddy Tech support. From the horses mouth "You need to remove any restrictions as the valve unit itself is the new restriction". The tech said that is why my boost is falling off so bad.
Oil restrictor bolt install bnoon MazdaSpeed 3 - How-To's 250 03-19-2014 06:47 PM
done! gt3076 samsel450r MazdaSpeed 6 - Engine, Transmission & Driveline 122 11-09-2009 04:35 PM
411whp with gt3076 @ 25psi... howd he do it phailerider MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 01-05-2009 01:32 PM
Page generated in 0.25435 seconds with 22 queries
