![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
(Thread Starter) | Not Ranked : 0 score I just got my new turbo Oddly, wastegate actuator is mounted well below the position of the oem, with a slotted bracket thaat has been set to the far end of the slot to try to get it closer in line. It uses a bent arm actuator rod. Not as effective to transfer force Whole thing looks awkwardly done Also, While It has an intake with a nicley machined lip to clamp on The output is rough cast, withe a huge casting shift, and out of round. This area has to hold full boost. Anyone else have this unit, and notice these issues? They're behind on orders, and i wonder if i have a cobbled unit Wish i could post a pic of the casting, but the laptop is dead, And i can't get a pic up with lollipop, i could with kitkat
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch Last edited by meicalnissyen; 03-12-2015 at 08:11 AM. |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Mine seemed normal although I did move the WG actuator for clearance and reset the arm pressure. econman's GTX2867R Install posts 32-36 Picture would help describe your issues.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
| The Following User Says Thank You to shamie For This Useful Post: | meicalnissyen (03-12-2015) |
(Thread Starter) | Not Ranked : 0 score I just measured the endplay at .004 The stocker with 90K is at .001
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
(Thread Starter) | Not Ranked : 0 score So, interesting talk with ATP tech support regarding: crummy casting "we get them from garret that way and they never leak" The lack of mount bracket boss "it doesn't need one, we've never had a manifold crack" The odd angle of the wastegate actuator arm "we put it there because of clearance issues" Which when called on that, became " its because of the cold side housing" So, has anyone fabbed bracket to pickup the bottom downpipe stud as a support point? Anyone had issues with the actuation of the IWG bellcrank and reconfigured the acutator bracket? Thanks
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score @Scare Dem; has the same turbo but never mentioned any of these issues.
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
| The Following 2 Users Say Thank You to Mauro_Penguin For This Useful Post: | meicalnissyen (03-12-2015), Scare Dem (03-12-2015) |
![]() Join Date: Dec 2008 Location: FLORIDA
Rep Power: 1419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,235
| Not Ranked : 0 score Can you grab a few pictures today? Are you concerned about the WGA hitting/rubbing the firewall?
__________________ 2008 Mazdaspeed3 GT GTX2867r ![]() |
| The Following User Says Thank You to Scare Dem For This Useful Post: | Mauro_Penguin (03-12-2015) |
(Thread Starter) | Not Ranked : 0 score I don't think so, Concerns are odd bent arm actuator for no good reason i can see, so far The single port actuator and a rinky dink, poke a hole in your boost tube, boost port supplied in the kit Lack of support bracket, and ways to fab one Supplying a huge coolant feed line, and reusing the oem return?? The seams in the casting the boost tube has to seal over. And the smaller than oem output diameter. Other than that...... Golden And THANKS for weighing in, id have pics up, but the new android is jacking me I may have to try that tappa talk thing
| Not Ranked : 0 score I had the same observations as you, but I slapped it on anyway and have been loving it ever since.
Ok Ill see about fabbing a support bracket Suck up the rest
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch | |
| Not Ranked : 0 score Are you talking about a support bracket to hold the turbo up like the way the k04 is held up?
(Thread Starter) | Not Ranked : 0 score ^ yup
| Not Ranked : 0 score You don't need a bracket. The manifold holds it up. Are you running stock manifold? Exhaust.
(Thread Starter) | Not Ranked : 0 score Xs power v1
| Not Ranked : 0 score You'll be fine without the bracket. Someone on here has/tried to modify the factory bracket. It's going to take some digging to find it. My WGA was "bent" as well. My phone is dead, but I can post pics on my thread of how mines looks to compare. I need more input on your question about the Coolant feed lines. We're going to get through this together. You're going to have that thing installed this weekend once the GTX "looks/seems" to be in working order. Try to post pics man.
(Thread Starter) | Not Ranked : 0 score Since im biching as i go, the nice an fitting hose is at least 1.5 inches to long, leaving a "p-trap" effect. I was asked earlier if i was worried about firewall clearance Yea, now The edge of the acutator is 10 and an eigth from the mani surface. Thats an inch plus over oem, and looking straight down on it there is a free 1/2" on the table from bad bracket design. And if i touch it, any turbine failure is on me
![]() Join Date: Jan 2014 Location: Kissimmee FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 191
| Not Ranked : 0 score To be honest I can't say I noticed this on mine.. Did you @Scare Dem; ?
Last edited by Nel Mazdaspeed; 03-14-2015 at 06:17 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Nel Mazdaspeed For This Useful Post: | JSmith (03-14-2015) |
| Not Ranked : 0 score Yours and mine did not have this issue. I've been trying to picture these issues in my head, but without pictures I cant help.
| The Following User Says Thank You to Scare Dem For This Useful Post: | Nel Mazdaspeed (03-14-2015) |
(Thread Starter) | Not Ranked : 0 score Well, i am mounting to an xspower v1 mani, so that muddies the water somewhat. Ill try accessing the forum from a desktop at work today, and posting pics
| The Following User Says Thank You to meicalnissyen For This Useful Post: | Nel Mazdaspeed (03-14-2015) |
(Thread Starter) | Not Ranked : 0 score Heres one to start Angle isnt perfect but you can see the WGA could be moved closer to the comp, bying clearance to the FW.
(Thread Starter) | Not Ranked : 0 score Sweet, it worked, I'll get some more up in a bit. Lives to save and whatnot
(Thread Starter) | Not Ranked : 0 score more pics of casting, bell crank design geometry I'll shoot the return line, and a good vertical shot of the linkage tonite, and post em tommorow
I wouldnlikento be the first to tell you to make sure to check and tighten down the 6 compressor housing bolts before you install the turbo. The 28 series does not have a gasket inbetween there and can leak out boost pressure bad.... I found out first hand. Last edited by Nel Mazdaspeed; 03-15-2015 at 12:13 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Nel Mazdaspeed For This Useful Post: | meicalnissyen (03-15-2015) |
| Not Ranked : 0 score Looks good to me so far.
![]() | | #24 | ![]() |
| Not Ranked : 0 score No gasket that seals the surface connection.. ![]() ![]() So I used a very thin layer of high temp RTV... ![]() Im not saying you will have this problem, but I sure did. |
| The Following 2 Users Say Thank You to Nel Mazdaspeed For This Useful Post: | Mauro_Penguin (03-20-2015), meicalnissyen (04-10-2015) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score This is what happened to me before I used the RTV. |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score More pics, and I played with paint abit to illustrate the drain lin, because of the excessive lenght, the bend will keep it from flowing freely, particularly if there were to be any pressure in the crankcase looks like the pretty line gets a double male barb and a couple clamps, sad, cuz the barb restricts flow as well the linkage, Because the push point is behind the rotaion axis, the effective mechanical advantage is falling the further it rotates. since its welded, there is no good way to fix that the actuator, see how the rod is actually bent out a bit to meet the actuator? there is a solid 1/2 inch, if not more that it could be moved my redesigning the bracket. which would gain firewall clearance, and improve the pushrod geometry Neil , the compressor leaks?????? Damn, I just watched that on my phone, nice real nice. arent those the bolts that loosen on a BNR? So, when You buy this "kit" you get a pair of AN fittings with holes machined WAY to large, A custom drain hose thats too long, a wastgate actuator rod with bad geometry, a wastegate actuator that is malpositioned and may hit the firewall, and unless you take it apart and seal it, it blows bubbles for you Brilliant
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I sealed up as well. Then had to detorque the comp side and use a pipe to rotate it 5 deg to clear the boost toobz Grrr Guardian Angel and a fast synapse BPV and hope
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch Last edited by meicalnissyen; 04-10-2015 at 08:08 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #28 | ![]() |
| Not Ranked : 0 score You realize the drain line is yours to modify? Disassemble one end, cut off whatever you need, and reassemble the line....
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (03-20-2015), Mauro_Penguin (03-20-2015), meicalnissyen (03-15-2015), NCspecV81 (03-15-2015) |
![]() | | #29 | ![]() |
that 38 you mention, that leads to what? screamer pipe?
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch Last edited by meicalnissyen; 03-15-2015 at 12:17 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #30 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score A few cracks yes, once this happens it's impossible to control boost. This has happened before me and some buddies after me with MZR Flange ATP Garrett hotsides
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
![]() | | #31 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score Except they're crimped on so you have to buy new fittings to reassemble.
__________________ 3rd rebuild on the way...maybe... |
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Code Monkey (04-07-2015) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score see left pic, post 44
![]() | | #33 | ![]() |
| Not Ranked : 0 score Not sure what I'm supposed to be looking at.
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score So, the OEM return line is a larger bore than the braided line, but know this, that flange has to be drilled out to accept the 5/16 screws in the ATP chra, I don't know what variety, but it is a work hardening stainless, and you will need carbide to do it. Also, the pipe ends don't face each other perfectly and kinked a bit on a rebend. In hindsight, I would flat grind the flange face at a slight angle to get the bulk of the mismatch corrected with a simple bracket and wire, I was able to keep the WGA rod free from blanket interference I am now reasonably happy wiht the WGA mechanical geometry, you can see the new WGA bracket finished next to the supplied bracket, and mounted up The support bracket will be, using a long stud, clamped against the DP's nut. that is not ideal, granted, but I could not come up with a better, practicable way
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch Last edited by meicalnissyen; 04-09-2015 at 12:39 PM. |
| The Following 3 Users Say Thank You to meicalnissyen For This Useful Post: |
![]() | | #35 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score I'm not sure why ATP has such a hard problem with our drainline. They have always been a little long. I hate RTV. I would have called and chapped someones butt. They would have had an oring to me by the next day. In fact, given all your troubles I would have requested a new turbo and kit. My HTA3586 was a better bolt-on option than your turbo and mine is a T3. I'd swap that crap yesterday.
__________________ 2013 CWP and Stock |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | Mauro_Penguin (03-20-2015) |
![]() | | #36 | ![]() |
Just in case you run an EM that positions the turbo a tad higher than the stock location.....
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #37 | ![]() |
Groans: 30
| Not Ranked : 0 score Boost control on these turbos are alright with the 'bent' actuator arm but I'd be more concerned of the shitty ATP IWG Port getting cracks like mine and quite a few other MZR Flange Garrett's I've spoken to. The boost becomes uncontrollable and will spike violently when/if this occurs and my turbo had only seen 24psi max on e85 and less than 10k miles when it happened. EWG is the ultimate solution and ATP makes a EWG hotside for 38mm wastegates if your manifold doesn't support EWG.
![]() | | #38 | ![]() |
Groans: 30
| Not Ranked : 0 score Here was my IWG port, eventually went 44mm TiAL MVR and blocked this port with a Cobb IWG bracket
| The Following User Says Thank You to impossible For This Useful Post: | meicalnissyen (04-10-2015) |
![]() | | #39 | ![]() |
Groans: 30
| Not Ranked : 0 score Either way the ATP oil return is shite. Leaked on me, went with a Kozmic O/R, no leaks whatsoever
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Another gripe to throw on the pile: The heater pipe attaches to the oem compressor housing Garret does not have a tapped boss on the housing ATP should have fabbed a bracket, and supplied it with the "kit"
| GTX2867R Build | mainelyperformance | 2010 MS3 - Big Turbo Builds | 5 | 06-17-2014 04:43 AM |
