![]() Join Date: Jan 2014 Location: Bismarck ND
Rep Power: 0 ![]() Thanks: 20
(Thread Starter) | Not Ranked : 0 score I am going to be buying this kit in a month or so, is anyone using it or heard anything. I do plan on going BT with a 450 to 500 hp goal will this be sufficient for that goal. http://www.d2power.com/shop/product.phpid_product=56 Thanks for any advice. haha nice
__________________ Cobb sri/ Cobb tih/ Cobb ap v3/ Cobb xle bpv... Corksport rmm/ Corksport hpfp/ Corksport dp/ Corksport rp... JBR tmm/ JBR pmm/ JBR ssp&ssb... Denso ITV 22... Freektune...CPE single exit cb...HDI FMIC... |
![]() Join Date: Jul 2013 Location: Canberra, AUSTRALIA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 187
| Not Ranked : 0 score Hey there...i'm using the HDI GT2 kit as are a few other guys here in AUS. Has been installed on my car for over 6 months with no issues at all. One thing I should mention is that when i received my kit, it had an adapter for the BPV but no hose included to connect it to the coldpipe going to the TB - you might need to source a radiator hose of similar diameter and cut it to suit. |
| The Following User Says Thank You to TRBLSM For This Useful Post: | 06wwpms6 (05-29-2014) |
(Thread Starter) | Not Ranked : 0 score Thanks for your answer man, I was looking through the instructions and noticed on the final pic of everything installed the plastic lip on front bumper isn't installed is yours on or wont it fit with the intercooler?
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
Also, with the bpv plate, I had to source new bolts + locking nuts, but I believe they now offer it with an "extras" kit that gives you it
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP | |
| The Following User Says Thank You to SarcasticOne For This Useful Post: | 06wwpms6 (05-29-2014) |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score I am currently using this kit. I don't know of anyone else using this kit on an MS6 here in the states. It will be very capable of handling your power goals. This kit was designed for the MPS6 which has a different PS cooler than the stateside MS6. The MPS6 seems to share a PS cooler with our regular MZ6. The PS cooler is shaped differently, is much larger, and will not clear for the HDI cold side piping. I first tried to bend the cooler out of the way, but no joy. My final solution was a $20 univeral PS cooler from Advance Auto and some extra PS hose. You will have to replace the entire PS cooler assembly. Other than that, I had no issues. I did not need to buy another coupler for the throttle body, just used the one that was already installed.
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
| The Following User Says Thank You to theschrum For This Useful Post: | 06wwpms6 (05-29-2014) |
(Thread Starter) | Not Ranked : 0 score thanks for all the useful information I didn't know bout the ps pump will take a look today if that sumtin I wanna tackle.
![]() Join Date: Dec 2015 Location: Snohomish, WA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Has anyone else gone this route? They are being sold on ebay and I'm curious to see if any changes have been made since these other posts; it'd be nice to not have to replace the ps cooler. |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
| Not Ranked : 0 score As far as I know it's only the AUS MPS6 that has the PS cooler in a different location. They only have a hardline where our cooler is which clears the IC pipes for them. My MPS has the same cooler as the MS6. I cut the hardline before the cooler and replaced a small section with easy to bend hose so the cooler could sit along the IC pipe. I just taped it onto the pipe but I'll make a custom bracket for it now. Took a lot of work to make it work since there were no instructions for our cooler type. A couple things makes the install "hard" * Relocation of PS cooler * BPV mounting pipe is too tall, need to be cut down like 2 inches * Relocation of washer bottle - wires/hoses * Aligning IC pipes It's an awesome kit and when it's mounted you will be very satisfied. I'll probably replace the special HDI clamps/oring/adapters and put normals couplers on instead because I need more wiggle room once I get the CPE/CS manifold on
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi |
| Not Ranked : 0 score I'm still a noob to mazdas - am I understanding correctly: MS6=Mazdaspeed 6? what's MPS6? |
MPS is Mazdaspeed in international markets. Also nice on the 2 year thread necro. sent from my Nexus 6P
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Vansquish (03-08-2016) |
| Not Ranked : 0 score Sometimes necromancy is needed to get answers. I bought my car in Canada...wonder which ps cooler it has. Guess I need to do more research. |
![]() Join Date: Aug 2012 Location: Romania , Europe
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Groaned at 32 Times in 15 Posts
| Not Ranked : 0 score I have mounted the HDI GT2 intercooler 5000 Miles ago. Is a nice piece , but installation takes a few mods and is a very tight fit. As a long term I can tell you that the brackets holding the washer fluid reservoir did brake so it was hanging in one bolt only. I almost lose it. Have to make some stronger brackets. Also the brackets holding the intercooler itself doesn't look so beefy. Regards
__________________ Silver Mazda 6 MPS /Built Engine/ GramLights 57xtreme 18x8.5 et45 \ Vredestein Ultrac Vorti 225x40R18 |
| The Following User Says Thank You to calinflorinalexandru For This Useful Post: | :: Gusto :: (06-08-2016) |
![]() Join Date: Dec 2008 Location: CT :: Stratford :: 203
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 632
Groaned at 34 Times in 27 Posts
__________________ :: somewhere between CT & VA :: yea yea - i know i cant spell | |
| intercooler and E85 | speeding3 | MazdaSpeed 3/6 - Turbo Induction | 5 | 07-31-2013 05:43 PM |
| intercooler & AP | Speedy64 | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 10-12-2012 07:35 PM |
| Why you need to run an Intercooler? | superskaterxes | MazdaSpeed 3/6 - Turbo Induction | 35 | 08-03-2012 10:10 PM |
| Evo 8 intercooler | zumin | 2010 MS3 - Turbo Induction | 6 | 02-25-2011 03:25 PM |
