![]() Join Date: Jun 2009
| Not Ranked : 0 score
It comes with new hoses and is easy to install. You leave them factory POS where it is and install the Grimmspeed unit to the side of your battery box. No reason to replace a plastic nipple with another one you will just break again, sooner or later.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Richys10 (02-19-2016) |
| GrimmSpeed 3 Port Boost Control Solenoid ? | ms6ms6 | MazdaSpeed 3/6 - ECU Computer Tuning | 42 | 04-14-2012 09:04 AM |
| Anyone using the stock boost control solenoid with an MBC? | madvillain | MazdaSpeed 3/6 - Turbo Induction | 0 | 07-28-2010 08:26 PM |
| Boost Control Solenoid Part #??? | ITALIA3 | 2010 MS3 - Troubleshoot/Diagnostics | 4 | 06-29-2010 03:34 PM |
