Like Tree3Likes
  • 1 Post By aaronc7
  • 2 Post By Agent_Orange
 Old 06-14-2014, 09:19 PM   #1
Yarizon's Avatar
Posts: 3   (View Stats)
Yarizon has a little shameless behaviour in the past
Default Help psi ms6
Today I installed the accessport to my ms6, i used the map CAI MAZDASPEED 93oct and the psi was of 12.5? Why?
When i use the stock map it says 13.2 psi. Why? It supose to be 15? Help me
Enviado desde mi iPhone con Tapatalk
Yarizon is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Yarizon For This Un-useful Post:
Swinger13 (06-14-2014), Vansquish (06-14-2014)
 Old 06-14-2014, 09:22 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Post a 4th gear WOT log.
 Old 06-14-2014, 09:52 PM   #3
Yarizon's Avatar
Why with the stock map has 13.2 psi?
 Old 06-14-2014, 09:53 PM   #4
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
blue 2 shims
Agent_Orange likes this.
The Following 3 Users Say Thank You to aaronc7 For This Useful Post:
Agent_Orange (06-14-2014), skiptowncat (06-18-2014), Swinger13 (06-14-2014)
 Old 06-14-2014, 09:57 PM   #5
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
first post a cry for help...
Performance:
Stratified Tune in progress
The Following User Says Thank You to Swinger13 For This Useful Post:
 Old 06-14-2014, 09:59 PM   #6
Groans: 665
Sigh...
OTS maps are baseline tunes, and far from quality. The performance of which can vary greatly vehicle to vehicle, and different mod setups.
The OTS garbage SHOULD run within +/- 1.5 psi of targets for that specific map.
15 - 1.5 = 13.5
If you want help beyond that, or to see if there may be a mechanical issue in play...
POST A 4TH GEAR WOT LOG.
The Following 3 Users Say Thank You to Agent_Orange For This Useful Post:
aaronc7 (06-15-2014), Swinger13 (06-14-2014), Vansquish (06-14-2014)
 Old 06-14-2014, 10:06 PM   #7
Yarizon's Avatar
Sigh...
15 - 1.5 = 13.5
Thank you now i understand.
Why with the CAI MS map has 12.5? It should be 14.5?
 Old 06-14-2014, 10:13 PM   #8
Groans: 665
aaronc7 and Swinger13 like this.
The Following 7 Users Say Thank You to Agent_Orange For This Useful Post:
aaronc7 (06-14-2014), biggman026 (06-14-2014), Hargarbl (06-14-2014), ms6mil (06-14-2014), Skyman88 (06-22-2014), Swinger13 (06-14-2014), Vansquish (06-14-2014)
 Old 06-14-2014, 10:25 PM   #9
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
Um
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
The Following User Says Thank You to biggman026 For This Useful Post:
 Old 06-14-2014, 10:27 PM   #10
wdautrem's Avatar
Posts: 159   (View Stats)
wdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the world
What were your BATs? What altitude are you at? What gas were you running? Were you seeing any knock? What was your WGDC? Do you have any boost leaks? What gear were you in? How long were you actually WOT?
Post a WOT log, 3rd or 4th gear, to answer some of these questions, (donate), and maybe we can actually help you.
wdautrem is offline   Reply With Quote
The Following User Says Thank You to wdautrem For This Useful Post:
 Old 06-14-2014, 10:28 PM   #11
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
He just explained to you why it would be that way. Reading > you
Now post a damn 4th gear log so they can see what's going on and try to help you . Also be sure to mention what mods you have done to the car.
The Following User Says Thank You to Hargarbl For This Useful Post:
 Old 06-14-2014, 10:46 PM   #12
Groans: 665
I had this thread locked up after telling OP to start reading, but he didn't feel that was an effective solution. So here we are.
I think a quote from John Doe sums it up:
"Wanting people to listen, you can't just tap them on the shoulder anymore. You have to hit them with a sledgehammer, and then you'll notice you've got their strict attention."
In his defense, there does seem to be a language barrier.
 Old 06-14-2014, 10:50 PM   #13
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following 3 Users Say Thank You to ms6mil For This Useful Post:
Agent_Orange (06-14-2014), Swinger13 (06-14-2014), Vansquish (06-14-2014)
 Old 06-15-2014, 06:31 AM   #14
jm211's Avatar
Posts: 943   (View Stats)
Love pulp fiction. And the exact line I was thinking.
OP, these ar target values so a bit of variance is e pected. Also, due to your lack of verbs, I would suspect your car has BOOST LEAKs resulting in a loss of psi.
The Following 2 Users Say Thank You to jm211 For This Useful Post:
Agent_Orange (06-15-2014), ms6mil (06-15-2014)
Page generated in 0.34417 seconds with 28 queries
