 Old 12-19-2018, 03:43 PM   #41
Dennisaliy's Avatar
Posts: 25   (View Stats)
Dennisaliy has a spectacular aura aboutDennisaliy has a spectacular aura about
Could I hollow out the stock dp? The cats are toast so I cant resell them. Would it be similar to a aftermarket catless downpipe?
Dennisaliy is offline   Reply With Quote
 Old 12-19-2018, 04:02 PM   #42
Dennisaliy's Avatar
 Old 12-20-2018, 01:04 AM   #43
Camwilson's Avatar
Posts: 6   (View Stats)
Camwilson is an unknown quantity at this point
Time to go catless.
Camwilson is offline   Reply With Quote
 Old 12-20-2018, 06:22 AM   #44
Posts: 2,237   (View Stats)
the oem pipe size is smaller so it won't flow as well as an aftermarket dp but it will decrease restriction.
To run the car after doing this, one must install an upgraded hpfp and a tune that will lower the wg duty to avoid overboost or you will go fuel cut untill a rod make it's way thru the engine bloc
 Old 12-20-2018, 07:50 AM   #45
Dennisaliy's Avatar
Okay, I think I'll gut them because that seems like the most cost effective option. Also its already half done lol
 Old 01-03-2019, 01:55 PM   #46
Posts: 2,827   (View Stats)
As stated above, there are precautions you must take when running catless.
1. You absolutely must have a hpfp upgrade. While not as high flowing as the 3" catless dp/rp as I run, it is substantially higher flowing than you were before). You will exceed the fuel capabilities of the stock hpfp to keep up under load if you don't upgrade. When that happens, you can lean out your AFR and destroy your engine.
2. You will need a tune to run catless. You will encounter nasty spikes up to about 21-22 psi (maybe higher, because the stock map sensor runs out of voltage at 22 psi and will not read higher, even though you may be above that number. A tune consistent with higher exhaust flow will eliminate those spikes. Even the canned Hypertech tune I run safely took care of that and runs like a raped ape with catless exhaust with target and actual boost hitting about 18 psi under maximum load.
3. You will probably get a check engine light for improper temperature in the primary cat. Aftermarket downpipes have a raised 02 sensor bung that changes the sensor location in the exhaust flow. My downpipe has this feature. There are aftermarket screw in 02 sensor extensions you can buy to eliminate the problem. Or, you can get a commonly available spark plug anti-fouler extension and drill a hole in the middle large enough for the sensor probe to stick through. There should be threads here on this subject.
It's not as easy as just knocking the honeycomb out of the cats and rolling. You must increase pump capacity and must address the nasty boost spikes.
Whether you want a permanent check engine light or want to raise the sensor is up to you. I would recommend you address the check engine light, or otherwise, you will be unable to know when you have some other problem that triggers a CEL that needs to be investigated and fixed.
Dennisaliy (01-03-2019)
 Old 01-03-2019, 01:59 PM   #47
Dennisaliy's Avatar
3. You will probably get a check engine light for low temperature in the primary cat. Aftermarket downpipes have a raised 02 sensor bung that changes the sensor location in the exhaust flow. My downpipe has this feature. There are aftermarket screw in 02 sensor extensions you can buy to eliminate the problem. Or, you can get a commonly available spark plug anti-fouler extension and drill a hole in the middle large enough for the sensor probe to stick through. There should be threads here on this subject.
This is very helpful. Thank you and everyone who has helped me in this thread.
The Following User Says Thank You to Dennisaliy For This Useful Post:
MSMS3 (01-03-2019)
 Old 01-03-2019, 04:27 PM   #48
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
If you are in a 6 or Gen1 3, just turn off the codes for the secondary O2 when you get tuned...unless you have emissions inspections to pass.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Stock turbo flutter/surge? Yatta 2010 MS3 - Turbo Induction 0 05-13-2013 05:19 PM
Turbosmart Dual Port Flutter/Surge/Flutterdump? ChimmyChong 2010 MS3 - Turbo Induction 22 07-22-2012 10:01 AM
Turbosmart Dual Port Flutter/Surge/Flutterdump? ChimmyChong MazdaSpeed 3/6 - Turbo Induction 1 01-10-2011 09:29 AM
Boost Gauge Flutter bova MazdaSpeed 3/6 - Turbo Induction 21 04-13-2009 11:00 AM
Compressor surge or bpv flutter phailerider MazdaSpeed 3/6 - Turbo Induction 43 04-20-2008 04:42 PM
Page generated in 0.30124 seconds with 25 queries
