![]() | | #41 | ![]() |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
![]() | | #42 | ![]() |
![]() Join Date: Apr 2011 Location: Millsboro, De
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,597
| Not Ranked : 0 score Yeah the VNT turbos are awesome. Just watch out for sticky vanes. Is this an OEM turbo?
__________________ 2006 Mazdaspeed 6 GT-unDISI swap in progress 1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5 Skreets be calling... [SIGPIC][/SIGPIC] |
![]() | | #43 | ![]() |
![]() Join Date: May 2011 Location: Montréal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 97
| Not Ranked : 0 score Not mine, but there is 2 of them at my job sitting in their box. I'll see if i can get one for cheap since we are not gonna use them
__________________ Mazdaspeed3 - sold - Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18 - Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 - - 2010 drag time : 12.737@108.51mph - 259whp@280wtq - 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq 2014 Black Mazda 6 GT MT - Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing - RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19 - 3M Gloss Black Chrome Wrap - Autoexe Shifter Knob |
| The Following User Says Thank You to mrdouble99 For This Useful Post: | 06Speed6 (05-03-2012) |
![]() | | #44 | ![]() |
Sweet man, keep me posted!
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
![]() | | #45 | ![]() |
Groans: 56
| Not Ranked : 0 score Cummins 5.9/6.7? If so that's fucking wild. I'd love to tell the rednecks around here my tiny 4cyl has the same turbo as their bromobiles
| The Following 3 Users Say Thank You to BigRedSpecial For This Useful Post: |
![]() | | #46 | ![]() |
| Not Ranked : 0 score Oh ok I thought Cummins used the Holset turbos. When I was first gonna do a VGT I was gonna use one from a 6.0L P-stroke I think Garrett makes it.
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah the garrett turbos are a different design and it is very prone to failure. Ford uses garretts and dodge uses the holset
![]() | | #48 | ![]() |
| Not Ranked : 0 score Yeah that must be where I got the sticky vanes comment from.
![]() | | #49 | ![]() |
Groans: 189
| Not Ranked : 0 score The Holset turbos can still stick (I have one that was stuck; fucking sucked getting it apart); it just isn't as prevalent due to the design (moving vane wall vs individually moving vanes in the Garrett). Honestly I don't think either turbo would be problematic on a gas engine unless it ran rich all the time.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | 06Speed6 (05-04-2012) |
![]() | | #50 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score In for 800awhp ms6
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
| The Following 3 Users Say Thank You to Boosted Beluga For This Useful Post: |
![]() | | #51 | ![]() |
Groans: 189
| Not Ranked : 0 score Unlikely; these are comparable to 35 series turbos if memory serves. Also, I need to find that compressor housing and ship the turbo.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | 06Speed6 (05-04-2012), Boosted Beluga (05-04-2012) |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks man! There is are 6, 7, and 8 blade compressor wheels and they flow from 60 to 75lb/min, i think the batmowheel flows even more but there seems to be some debate as to whether the turbine has enough power to take advantage of that extra flow.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Alpha (05-16-2012) |
![]() | | #53 | ![]() |
Groans: 50
| Not Ranked : 0 score A 7 blade sounds good
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score I finally got through to Brayden at fleece performance and talked to him about their controller. It is $625 and directly plugs into the turbo and controls it through the can bus. It has a 0-5v map reference that can be scaled to any map and a ground and a ign on power input. How much it opens the vanes vs manifold pressure is tuneable on a 16 cell table. Seems a little much considering that their diesel controller has alot of inputs for virtually everything and its $625 also.
![]() | | #55 | ![]() |
| Not Ranked : 0 score There are a few for sale on cummins forum. Also boostaddiction.com sells them reworked. He is a friend of @Captain KR
| The Following User Says Thank You to BobtailedSnail For This Useful Post: | 06Speed6 (05-16-2012) |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well here is a blast from the past, I got an email last night from David Suprock and apparently his vgt controller is ready. When I looked at it last it was definitely the best controller out there. Its expensive as fuck but considering all of the sensors it has, its not a bad price. Ill post the link later.
| The Following 3 Users Say Thank You to 06Speed6 For This Useful Post: |
![]() | | #57 | ![]() |
Groans: 56
| Not Ranked : 0 score Awesome! I was wondering about this the other day
![]() | | #58 | ![]() |
| Not Ranked : 0 score This is gonna be nice
![]() | | #59 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score So you're stilling looking at doing this?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah I am pretty sure. I need to see how well my motor flows then ill know if I need to go bigger. Link: VGT Controller Pre-Order
| The Following User Says Thank You to 06Speed6 For This Useful Post: | sidekick (01-28-2013) |
![]() | | #61 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score I can't believe *edit* people aren't going ape shit about these things more. *edit* I got one of these cheap ($175 shipped or so) because it needed to be rebuilt, which you can do pretty cheaply (~$400 I think) - I just wanted to take it apart because no way am I gonna afford the craziness it would take to run this thing, and that's even before the engine build costs. Here's my thread, but it doesn't tell you guys anything you don't already know. Except never leave the compressor housing off while you're trying to remove the exhaust housing if the turbo isn't tied down. For updates I still have the turbo sitting around. Deep Creep, WD-40, PB Blaster, you name it - nothing could get the grunge loose using a 3 lb rubber mallet. I'd really need a bench vise if anything. |
| The Following User Says Thank You to Speed3eak For This Useful Post: | 06Speed6 (01-28-2013) |
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah the turbo shops around here always have a few laying around that are or can be rebuilt. They are the dsm broke ass ricer special but in this case the special is actually good.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Speed3eak (02-01-2013) |
![]() | | #63 | ![]() |
| Not Ranked : 0 score Before I sold my hx-30w I just had to take a hammer, wrap in a cloth and gave the t3 inlet flange a good tap. And it spun loose.
| The Following User Says Thank You to BobtailedSnail For This Useful Post: | Speed3eak (02-01-2013) |
| holset hx35? | Fagwagon | MazdaSpeed 3/6 - Turbo Induction | 154 | 09-13-2012 01:39 PM |
| Holset HE351 | Justin Lee | Mazdaspeed3/6 General Discussion | 1 | 01-03-2012 07:31 PM |
| holset turbo powa | austin102085 | MazdaSpeed 3/6 - Big Turbo Builds | 106 | 06-24-2010 01:09 PM |
