![]() | | #41 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() | | #42 | ![]() |
| I need a price on the catch can setup John.
![]() | | #43 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score |
![]() | | #44 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1819 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Groaned at 39 Times in 23 Posts
| Not Ranked : 0 score ptp can you post a pic of the check valve you are using and what can type/manufacturer are you using? |
![]() | | #45 | ![]() |
| Not Ranked : 0 score Its the same unit we are using for the SRT4 but we are using slip lock fittings to go to the hard plastic line on both sides. I will get some pictures up of the installed unit this weekend. I might start to offer these if its working to keep the oil out of the intake. |
![]() | | #46 | ![]() |
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Sounds like a truly essential mod. Blueish smoke, bad turbo/turbo seal(s), white smoke most likely condesnation build up if you have no cats or a high flow cat. I have the CPE turboback and I get a smell of burnt FUEL, not oil since it's a true high flow cat. Doesn't burn everything, but just enough to get you through smog testing. |
![]() | | #47 | ![]() |
![]() | | #48 | ![]() |
![]() Join Date: Mar 2008 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score Is there any point in returning the vented gases to the intake (other than emissions) Why not just plug the intake hole and vent the can to atmosphere? -enganear |
![]() | | #49 | ![]() |
| Not Ranked : 0 score People say that it changes the LT fuel trims. Personally I don't see how but the DH's are showing changes. |
![]() | | #50 | ![]() |
![]() Join Date: Mar 2008 Location: Planet Earth, v3.7
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score I definitely need the catch can/ check valve set up. This will help with my blow by, but doubt it's gonna do much for my bad turbo seals I need the big wheel and new seals. |
![]() | | #51 | ![]() |
![]() | | #52 | ![]() |
![]() Join Date: Mar 2008 Location: Kirkland, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groans: 87
(Thread Starter) | Not Ranked : 0 score Too expensive for my Army pockets.....however I can afford a badass rebuild! |
| The Following User Says Thank You to Death-From-A-Mile For This Useful Post: | truredms3 (07-31-2013) |
![]() | | #53 | ![]() |
![]() | | #54 | ![]() |
Groans: 87
(Thread Starter) | Not Ranked : 0 score Hey will I be seeing residue on my IC hot side inlet if my seals are bad? |
![]() | | #55 | ![]() |
![]() | | #56 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score i think you are picturing the can on the wrong end of the PCV system. it should be placed between the PCV valv (under the intake manifold) and the manifold vacuum source. it does nnot go up on the top in-line with the cai tube...that is where the fresh air is drawn in from, it isnt supposed to vent anything out, but it will with a crappy PCV valve while under boost. thats why the check valve is needed between the catch can and intake manifold.... it wont get past that and a pcv valve ! |
![]() | | #57 | ![]() |
As it is, the only time you have any flow through the pcv valve is when the pressure in the intake manifold is lower than the pressure in the crankcase. Since the crankcase is ported to the atmosphere through the valve cover tube, you only have flow through the pcv valve during periods of vacuum in the intake. During periods of boost, the pcv valve is closed and any blow by is vented to the fresh air tube behind the MAF. I do not understand how a different/additional check valve will change anything. To my knowledge we do not have a problem with reverse flow in the pcv valve system. some pneumatic check valves require 5 psi just to start opening. This would radically decrease the function of the pcv system. Is this the desired modification to the system? When I install my catch can, I will definitely keep the line to the intake manifold. I am going to use a coalescing filter as the reservoir. Northern Industrial Replacement Air Filter 3/8in. Fitting | Air Filters, Lubricators + Regulators | Northern Tool + Equipment And yes, I will take pictures.... -enganear | |
![]() | | #58 | ![]() |
| Not Ranked : 0 score the check valve stops the boost from leaking past the shitty stock pcv valve. |
![]() | | #59 | ![]() |
![]() | | #60 | ![]() |
| Not Ranked : 0 score yep. under boost the pcv is supposed to seal off and hold the boost back. it is very common however that it doesnt quite work that way. i have pressure tested my car for leaks, and yes my pcv does have a very slight leak. the chack valve along with the pcv will stop that. |
![]() | | #61 | ![]() |
... I feel your pain. | |
| The Following User Says Thank You to Staples187 For This Useful Post: | Death-From-A-Mile (03-30-2008) |
![]() | | #62 | ![]() |
![]() Join Date: Mar 2008 Location: Baltimore
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| The Following User Says Thank You to TENCms3 For This Useful Post: | Staples187 (03-30-2008) |
![]() | | #63 | ![]() |
| Not Ranked : 0 score I'm in Baltimore too. I appreciate the input from another local member, thanks. |
![]() | | #64 | ![]() |
![]() | | #65 | ![]() |
![]() | | #66 | ![]() |
. New seals please!
__________________ The fastest MS3 in the whole garage... | |
![]() | | #67 | ![]() |
![]() Join Date: Mar 2008 Location: detroit
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
| Not Ranked : 0 score [QUOTE=whoosh;7023]guys TRU-BOOST is right on the money just like many other mods, this may or may not cure some smoking but I can assure you 100%, that installing a catch can between the actual PCV and intake mani will cure oil in your intake tract and contamination / build up on your valves there is another problem that has surfaced that TRU-BOOST mentioned: the fact that a check valve is needed in addtion to the baffled catch can. Our OEM PCV valve leaks and causes excessive crank case pressure. I can't say what adverse affect that has on the MZR at this point in time but logically, it's not something you want. The ideal set up (my set up) is using a 90 degree fitting where the PCV valve currently resides run your hose to the "INLET" side of the catch can. Then install a heavy duty oneway or check valve on the "OUTLET" side of the catch can. Then obviously run that hose back to the rear vacuum port of the intake manifold. I'll post my test results in vid form of the leaky brand new PCV valve - it's bad, really bad here are a few pics for those that haven't seen them. I empty my catch can every weekend and get the same amount of fuelishoilywhitebrownstuff every time dude thats kinda gross. it looks like your car is vomiting into that catch can.
__________________ 2008 Sunlight Silver MS3 the toy 2012 Chrysler 200 Limited 3.6l the daily driver |
![]() | | #68 | ![]() |
| Not Ranked : 0 score BTW i know there was a thread on 247 about what build dates had the smoking turbos and i believe it said that only the 07s had the problem but is anyone with a modded 08 having the same problem? and if not would there really be any reason for me to put in the catch can and check valve on my 08?
![]() | | #69 | ![]() |
| Not Ranked : 0 score even if your car doesnt smoke a CC is a good idea. you still have oil getting drawn into your intake manifold. and the check valve will prevent that boost leak from your PCV valve..... yes its there ! |
![]() | | #70 | ![]() |
And yes, quite a few 08s have the problem.....including mine. There are several 08s on the other forums that were having the problems before I stopped hanging around them (the forums...). This is now my permanent home
![]() | | #71 | ![]() |
| Not Ranked : 0 score see this is the first i've seen of any 08s that have the problem. granted i dont screw around on 247 or the 3forums that much anymore
![]() | | #72 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score Lot of great info here guys, but not too many photos other then woosh's initial ones! Ptp, are you working on an inclusive kit to sell? (with check valve, baffle can, and hoses?). Or are you just going to offer some heavy duty valves? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/holy-friggin-smoke-s-334/ | ||||
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-25-2008 05:23 PM | |
| Installed the Turbo xs DP and let it smoke! | speed3 | MazdaSpeed 3/6 - Turbo Induction | 38 | 04-15-2008 06:20 PM |
