![]() Join Date: Aug 2012
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score If I go with a full corksport TBE w/ high flow CAT, after internals of course, along with front mount intercooler, rear motor mount, as well as a Cobb TIP and AP would I disappointed at all in the ride and with the sound also any problems that could arise in the future, I know about the smokey turbo but im hoping that the cat might prevent that from happening. ive been researching but im deployed and don't have a whole lot of time to surf the net so ive been doing my best just figured id as for some input...thanks |
| The Following 3 Users Say NO Thank You to jrobbinsms3 For This Un-useful Post: |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Reserved for grammatical corrections. Edit:
Second, I appreciate the fact that you've been doing some research, but you've left things extremely open-ended with the questions you've asked. This suggests that you actually haven't spent much time doing research on the platform, and you really want to be spoon-fed the information instead. With that in mind . . . Third, how will your car's ride be affected at all by the use of a TBE/FMIC/HPFP internals/RMM? None of these has any effect on suspension calibrations. The closest you've come is the RMM, and that will all depend on how stiff a mount you install, and that's something only you can decide. Moreover, if you're running a downpipe, you're going to end up with a smokey turbo eventually. The pressure differential across the turbo will cause the seals to begin leaking at some point. Fourth, you should spend a teeny bit more time focusing on whether or not to insert periods instead of commas. You'll have an easier time communicating your thoughts and getting the answers you seek.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! Last edited by Vansquish; 09-06-2014 at 12:44 PM. Reason: Grammarization. | |
| The Following 5 Users Say Thank You to Vansquish For This Useful Post: | blakjak0271 (09-06-2014), Easter Bunny (09-06-2014), magicka (09-06-2014), Pointless (09-06-2014), smoogs12 (09-06-2014) |
![]() Join Date: Aug 2012 Location: whittier, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Do you mean dissapointed in the HP gains? Depending on the RMM you get you may feel light vibrations. |
![]() Join Date: Apr 2012 Location: Pax River, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 613
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Holy run-on sentence batman!
__________________ 09 CWP MS3 GT3071R TUNED BY NISHAN |
| The Following User Says Thank You to T2J For This Useful Post: | Vansquish (09-06-2014) |
![]() Join Date: Nov 2012 Location: Winston-Salem, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,946
| Not Ranked : 0 score Smoky turbo happens regardless of cat or not. If you do all those mods at once that puts you at a bigger risk for something being wrong and making it harder to diagnose what the problem is. Do things one step at a time. Start with fuel pump internals of course then move on to the power mods, then finish things up with a tune to bring out the full potential of your car
__________________ Past 2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love ![]() Present 2014 Chevy Silverado Z71 |
| The Following User Says Thank You to CrawlingMS3 For This Useful Post: | Benis (09-06-2014) |
Groans: 111
However, if you think you may be disappointed by the exhaust noise you can always get a BNR turbo and use it with the stock exhaust (downpipe, test pipe and catback). You can as well use a larger top mount instead of the front mount. You will spend just a little more money (or just as much if you get a TMIC instead of a FMIC) but get a lot more power from your car. Eventually replace just the second cat with a resonated test pipe and that's it.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
(Thread Starter) | Not Ranked : 0 score When I say I have little to no time it means I don't give a shit about grammatical errors nor do I have time to sit down a fix them when I barely have time to eat. I thought this was a Mazda forum not a damn grammar class. Apparently most of you all have more time to be assholes then actually helping someone out So now that, that bullshit is out of the way. Thank you for your input, I did not think of the fact that doing everything at once would cause for a confusion in pin pointing a problem down the road if something wrong would arise. By ride I mean engine wise not suspension I guess I should of clarified that for some people. By noise I meant I don't want my car to sound like a piece of shit Honda. |
| The Following User Says NO Thank You to jrobbinsms3 For This Un-useful Post: | ms6mil (09-06-2014) |
| HP gains | proto05 | Gen2 MS3 General Discussion | 9 | 11-17-2012 10:12 AM |
| Horsepower TV | vivolorosso | Mazdaspeed3/6 General Discussion | 21 | 09-08-2011 08:30 PM |
| mods?/Gains? | tbone | MazdaSpeed 3/6 - Turbo Induction | 5 | 11-26-2008 07:06 PM |
| how much horsepower | Mr._Pickles | MazdaSpeed 3/6 - Turbo Induction | 39 | 05-09-2008 09:00 AM |
