Like Tree5Likes
  • 1 Post By Mazdazilla6
  • 1 Post By speedfreak44
  • 1 Post By Enki
  • 1 Post By h20poloman
  • 1 Post By Arkangel77
 Old 02-16-2016, 09:55 PM   #1
Arkangel77's Avatar
Posts: 171   (View Stats)
Arkangel77 has much to be proud ofArkangel77 has much to be proud ofArkangel77 has much to be proud ofArkangel77 has much to be proud ofArkangel77 has much to be proud ofArkangel77 has much to be proud ofArkangel77 has much to be proud ofArkangel77 has much to be proud of
Default how to disassembly k04 turbo?
Anyone have any tips. How to seperate the housings? I have searched here and looked for videos but i am having no luck finding a video on k04 tare down. If you have a tip or video or any help, it would be very much aprechiated.
Apexi turbo timer, Cobb intake, E Focus RMM, XT-M5-QS trans oil, JBR OCC, DIY PMM, MOOG sway bar bushings, AP programing, MAX Performance Brakes, AutoTech HPFP Internals - More to come
Arkangel77 is offline   Reply With Quote
 Old 02-16-2016, 10:03 PM   #2
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
Mazdaspeed 3 and 6 Turbo Upgrade
BNR Stage 3 Turbocharger for Mazdaspeed 3 / 6 #BNR-MZ3 - Revolution Performance Motorsports!
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
 Old 02-16-2016, 10:06 PM   #3
Arkangel77's Avatar
Stock k04 turbo, mazdaspeed 3
 Old 02-16-2016, 10:09 PM   #4
gdawg25's Avatar
I know. Spending any time on the k04 is a waste of time. Time is money.
 Old 02-17-2016, 07:32 AM   #5
Arkangel77's Avatar
Not at All helpful - but thanks for the reply.
Trying to rebuild it or what?
sent from my Nexus 6P
YES - I am 75% sure Ima try to re-bild one , AGAIN.
Compressor housing, heat up the backside with a torch and smack it with a deadblow around the edge. Turbine housing, lots of prying and hammering. I've rebuilt the stock k04 before and it worked fine but I wouldn't want to do it again.
That's what I was thinking - It just makes me so nervous.
Originally Posted by speedfreak44 View Post
Yea it is kind of a bitch. I ruined the first k04 attemtping to split it. The next two worked fine but I think the first was a super high mileage e85 k04
I also destroyed my 1st one.... I bought a replacement but the Side to Side play on the Shaft is at least twice as much as my stock 131K mile K04. I just dont feel that installing it with so much play is a good idea. It should not be so hard to split the casing/housings!!!!!!!
Originally Posted by Majin View Post
VERY helpful video. I have watched it like 3 times. Only problem is that one just falls apart once the Bolts are removed, the K04 dose not do that! I had to beat on my 1st one to get casing to separate and as a result I chipped 2 of the edges on the compressor wheel fins.
Last edited by Arkangel77; 02-17-2016 at 07:32 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-16-2016, 10:22 PM   #6
 Old 02-16-2016, 10:24 PM   #7
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
redneck4Christ likes this.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 02-17-2016, 04:30 AM   #8
speedfreak44's Avatar
Posts: 1,391   (View Stats)
The line up:
 Old 02-17-2016, 07:27 AM   #9
Majin's Avatar
Posts: 113   (View Stats)
Majin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud of
https://youtu.be/99yMB5RII1U
Modifications: APv2//Damond PMM//HTP 3.5 SRI//JBarone RMM//3.25 TMIC with CS tubes//Autotech HPFP//Manzo 3" Catless downpipe//Matt D OCC Stage 2//Defi Boost Gauge//NGK Plugs//Koni FSD//Injector seals
Awaiting purchase: too much to list
"My mind is the space where my Id, Ego, and Anima all come together to exchange cookie recipes!"
Majin is offline   Reply With Quote
 Old 02-17-2016, 07:41 AM   #10
Arkangel77's Avatar
I am not sure how to shrink the link but this is a very helpful video on how to Re-Build. BUT no help on tare down.
https://video.search.yahoo.com/video...%2Cv%3Av&&tt=b
 Old 02-17-2016, 08:01 AM   #11
The compressor cover doesn't come off easily because it is RTV'd onto the backing plate, hence why I said heat and hammer.
The turbine housing doesn't like to come off because heat cycling will make it tighten onto the CHRA. Don't hit it sideways at all, some have a stake in the housing so it can't spin on the CHRA.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 02-17-2016, 12:17 PM   #12
Arkangel77's Avatar
Thanks for the help. Seems like this new (non mazda) k04 was not rtv'd together thank God!!! I ordered the rebuild kit, my hope is that it will eleminate the sideways slop i currently have in there. One day i will drive this car again lol. Thank you very much Mazdazilla6. Very informative and helpful posts man.
 Old 02-17-2016, 12:26 PM   #13
Umm, where did you get this turbo from? The picture isn't great, but that model number looks like it ends 582, which i believe is the CX-7 variant of the k04.
Vansquish (02-25-2016)
 Old 02-17-2016, 12:35 PM   #14
For reference, here is a link to a post in a thread discussing the difference between the 881/882 and 582 variations of the k04.
K04 Differences: K0422-582 vs. K0422-881 / K0422-882
You may want to contact whoever you got that from before you go any further.
Mazdazilla6 (02-17-2016)
 Old 02-17-2016, 07:24 PM   #15
Arkangel77's Avatar
It is a - 582, so seems like i just hit another wall.
forgive my ignorance but from what you linked it seems like the wheels are smaller and the Housing itself is also not not as large internally?
is that correct?
 Old 02-17-2016, 07:31 PM   #16
is that correct?
I believe that to be the case. I only read those threads casually before, but it sound like both the chra and comp housing are different.
 Old 02-18-2016, 12:10 AM   #17
Arkangel77's Avatar
Thank you fpr pointing that out to me. I totally missed it ...
I could not sleep so I just got done checking and it is IN fact smaller than the original. Another roadblock. UHG!!!!!!!!!!
The Following User Says Thank You to Arkangel77 For This Useful Post:
WetzMS3 (02-18-2016)
 Old 02-17-2016, 07:39 PM   #18
Arkangel77's Avatar
well - I will be braking out the MIC tomorrow and checking for myself
 Old 02-18-2016, 01:11 AM   #19
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Seriously your best bet is to file that dead turbo in the trash bin and buy a used mid mileage K04 for ~200 and call it done. Rebuild kit might be half that but most of the time (from what I've seen) they don't take to a rebuild all that well.
gdawg25 (02-18-2016)
 Old 02-18-2016, 04:10 AM   #20
If you do get one and rebuild it use a 360 degree thrust washer and step gap ring on the exhaust side. Both will help oil consumption. The entire rebuild should cost less than $100 if you do it at home. I think the last two I did cost me about $60 total.
Arkangel77 likes this.
The line up:
 Old 02-19-2016, 07:01 AM   #21
Arkangel77's Avatar
Hey guys - for those of you who are reading this thread, I got a New question. Only thing I am sorta nervous about is the balance on the Wheels. HOW do you guys make sure you have them balanced after you pull them apart? Not sure how to get them back in the exact same spot? Everything moves lol. Its easy enough to get the Nut and the compress wheel aligned but the real issue is the Wheel to the shaft!
 Old 02-19-2016, 05:46 PM   #22
Arkangel77's Avatar
Anyone? LoL
 Old 02-19-2016, 07:58 PM   #23
Enki's Avatar
Groans: 189
Just gonna keep asking until you get the answer you want huh? Gonna spend a hundred to save a hundred only to have to buy a new one anyway.
WetzMS3 likes this.
Vansquish (02-25-2016), WetzMS3 (02-19-2016)
 Old 02-19-2016, 08:10 PM   #24
Arkangel77's Avatar
I guess you are not bothering to read what I actually asked? I am not asking for a different response to the same question. I asked a NEW question. You are not privy to everything I am dealing with, I am NOT re-building my old dead Turbo..... I asked a Specific question and if you can't answer the question or contribute to the discussion then why are you even posting? Most everyone here is very helpful and I appreciate all those who are trying to help. If nothing else People can learn from this thread, Not everyone knows everything!
The Following User Says NO Thank You to Arkangel77 For This Un-useful Post:
 Old 02-19-2016, 08:33 PM   #25
Don't get butthurt home slice.
 Old 02-19-2016, 08:31 PM   #26
I posted earlier but I guess it never showed up...
You mark each wheel with a marker before removing them and just realign them. That is the simplest way
The line up:
The Following User Says Thank You to speedfreak44 For This Useful Post:
redneck4Christ (02-26-2016)
 Old 02-19-2016, 08:41 PM   #27
Arkangel77's Avatar
I was talking with a buddy erlier and thats what we were thinking, seems like we were on the right track i guess. Thank you for the responce.
Sorry, i got a sensative butt =)
Last edited by Arkangel77; 02-19-2016 at 08:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-20-2016, 10:02 AM   #28
h20poloman's Avatar
Posts: 5   (View Stats)
h20poloman is an unknown quantity at this point
you probably already know this but remember it is left hand threaded when you tighten the nut. A buddy of mine made this mistake.
a good alternative to rebuilding the k04 is to buy a cartridge and call it a day and then you don't have to worry about balancing it.
Rockauto sells one and is not expensive.
I am actually running it. so far so good.
h20poloman is offline   Reply With Quote
 Old 02-20-2016, 10:18 AM   #29
Arkangel77's Avatar
Yes - I did know about the Nut and Thank you! I also hears about the cartridge from Rock Auto. Here is a Link to that More Information for ROTOMASTER K1040215N
That's a Great Option also. I am probably going to rebuild this newer turbo I have. I got the Kit from Turbo Lab Turbo Upgrades for Audi, voltswagon, BMW, Mitsubishi, Subaru, Nissan, Buick, Mazda, and more. - but in the future who knows whats next? I still got my OLD 131K mile stock 07 Turbo off the car with its damaged compressor wheel to play with. I like to Tinker so who knows +0
THANK YOU very much for the Post. Its nice to see that some people get the fact that different people will choose to do Different things and that's OK
h20poloman likes this.
 Old 02-20-2016, 05:44 PM   #30
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
I did the same. Just reuse your hot and cold side outer housings. I think I payed $350cdn and ran it all summer so far. At that price, Ill just keep rapin' K04 chra till I got all my other necessary pre-parts. ADP distributors...in Canada, you pay 70 cents on our dollar (Fack!) I was dealing with Tuna <--dudes name!
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 02-25-2016, 02:54 PM   #31
Posts: 2,233   (View Stats)
The hardest part when i rebuilded one (Exept for separating the cold side cover) was to clean the turbine wheel shaft from the baked oil and carbon. It was so well baked that it was looking like it was part of the shaft...IF you don't do it correctly, it won't last long...Also check for the oil ring (Seal) groove wear, if the new ring seem to be too much loose, it will probably smoke on the first start.
I marked the wheel, shaft and nut with a marker and just put it back at the exact location. The guy that used it seem to be happy with it...
Going back to rebuild one, i will buy the new CHRA and just install it and call it done.
 Old 02-25-2016, 05:13 PM   #32
You don't need to mark them. They aren't balanced as an assembly at the factory. Each part, comp wheel and turbine wheel w/shaft, are balanced individually. Only certain aftermarket performance companies balance the wheels assembled.
Edit: And I can say this with confidence because I've rebuilt a stock turbo without marking. Thing worked great after I put it back together.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
The Following 4 Users Say Thank You to Mazdazilla6 For This Useful Post:
Arkangel77 (02-25-2016), redneck4Christ (02-26-2016), Vansquish (02-25-2016), WetzMS3 (02-25-2016)
 Old 02-25-2016, 05:18 PM   #33
Arkangel77's Avatar
I did not know that - Thank you for that Info
 Old 02-26-2016, 06:50 AM   #34
It could be for oem factory ones and also for most of aftermarket wheels but i preffer to do more than not enough....
And for exemple my Garrett have some balancing grind on compressor wheel nut that confirm, it got balanced as a whole unit.
The picture is not good to see that but if you zoom it, you can see the brighter mark on the nut. This is where it got notched to remove weight by Garrett (Was a new CHRA) 20160220_230103_resized.jpg
Mazdazilla6 (02-26-2016)
 Old 02-26-2016, 08:26 AM   #35
The picture is not good to see that but if you zoom it, you can see the brighter mark on the nut. This is where it got notched to remove weight by Garrett (Was a new CHRA) Attachment 222202
I'm glad to see Garrett does for their aftermarket turbos. I can assure you they still balance each piece individually before an assembly balance. It's just like a rotating assembly in an engine. You wouldn't just have the whole system assembly balanced because if you decided to change the flywheel later down the road, then you have to pull the crank out. Also I've talked a good amount with David Hall, owner of Bullseye Power and you can get total balance pretty close without an assembly balance. Doing the assembly balance is critical for something like a competition car that will push the turbo to the ragged edge.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 02-25-2016, 05:43 PM   #36
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
No need to rebalance the k04. I took mine apart, rebuilt it, new comp wheel (wheel was balanced separately). Threw it all back together, worked perfectly for another 10k miles or so, then I got tired of power dying at 5300rpms and went bigger.
Basically, just get a BNR S3.
 Old 02-25-2016, 05:55 PM   #37
You don't have to balance it as an assembly but it doesn't hurt.
Short version: get a bnr s2! (Dare to be different )
The line up:
 Old 02-26-2016, 08:47 AM   #38
OK has i said, i usually do more than necessary just to be sure that i won't miss anything...
 Old 03-13-2016, 04:54 AM   #39
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
you have the tools needed to balance a turbo? or are you going to pay someone to do it? sounds expensive if the latter
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 03-13-2016, 09:15 AM   #40
The k04 does not have to be balanced in a machine. Individual components are balanced already. Final balancing is typically done just to make sure it is perfect but the k04 has other issues that supercede the balancing.
The line up:
Jeff23spl (03-14-2016)
Cobb v2 cable disassembly madspd6 MazdaSpeed 3/6 - ECU Computer Tuning 7 10-15-2015 12:21 AM
transfer case disassembly - has anyone done it? mrQQ MazdaSpeed 6 - Engine, Transmission & Driveline 138 02-18-2014 01:25 PM
inspecting bore without disassembly? mrQQ MazdaSpeed 6 - Engine, Transmission & Driveline 37 02-08-2014 04:26 AM
How-to: MS3 Antenna Disassembly feldm4n MazdaSpeed 3 - How-To's 16 12-02-2012 01:27 AM
Dasboard disassembly help Enki MazdaSpeed 3 - How-To's 22 07-27-2011 05:48 PM
Page generated in 0.60889 seconds with 33 queries
