 Old 06-03-2011, 07:56 PM   #1
Justin Lee's Avatar
Posts: 150   (View Stats)
Justin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond reputeJustin Lee has a reputation beyond repute
Groaned at 32 Times in 15 Posts
Default How do I route this into my downpipe?
Is it even possible to attach a dump pipe to this?
I assume it just dumps to atmosphere correct?
Justin Lee is offline   Reply With Quote
 Old 06-04-2011, 11:43 AM   #2
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
What is it?
I don't know much about penis pumpers
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following User Says Thank You to drknyte For This Useful Post:
emag remrofni (06-07-2011)
 Old 06-04-2011, 06:15 PM   #3
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
He's asking where does the WG dump the excess.
Mods: stock
 Old 06-05-2011, 12:00 AM   #4
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
link to turbine housing?
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
 Old 06-06-2011, 08:06 AM   #5
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
? uh, I see the turbine housing perfectly fine.
Godspeed turbo? I'd question the quality of that thing. And yeah, unless that's a vband, how the flock does it bolt to a downpipe?
07 MS3
The original Genpoo Hater
 Old 06-06-2011, 08:26 AM   #6
faeker's Avatar
Groans: 731
It is a v-band. You can google GS turbo's and you'll find plenty of stories of just how shitty they are.
Mods: stock
Chimmike (06-06-2011)
 Old 06-06-2011, 07:57 PM   #7
wette460's Avatar
now I see the pic, wtf? Damn work computer blocking my shit! Yeah, Godspeed sucks man. Lots of better setups to be on than that. I'd rather go back to K04 than put that shit on my car. At least stock is somewhat reliable.
As for the WG, I have never seen an open design like that. The exhaust housing is v-band and there is no flange for the WG to fit up against the downpipe, so I'm assuming it just dumps that shit to atmosphere. Ghey!
 Old 06-06-2011, 08:00 PM   #8
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
gotta love china turbos
 Old 06-07-2011, 12:17 AM   #9
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
CHINACHARGER
The Following User Says Thank You to dooderek For This Useful Post:
Chimmike (06-07-2011)
 Old 06-22-2011, 04:11 PM   #10
Mazdanspeed3's Avatar
Posts: 157   (View Stats)
Mazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond repute
the wastegate is plumbed back into the vand, u can see the slit to the right of the vband exit, and the c clip holding a plate to reroute the exhaust into the vband outlet, just dont do it . ha
Mazdanspeed3 is offline   Reply With Quote
The Following User Says Thank You to Mazdanspeed3 For This Useful Post:
kmac (06-22-2011)
 Old 06-22-2011, 06:43 PM   #11
faeker's Avatar
Groans: 731
yeah..........that's just horrible. during my search of just how shitty these turbo's are, I was surprised at how many asshats were using them on Supra's, 240's, and other cars that are generally considered nice.
Mods: stock
kmac (06-22-2011)
 Old 06-22-2011, 11:02 PM   #12
Justin Lee's Avatar
Cagey seemed to have pretty good luck in his ebay turbo
 Old 06-22-2011, 11:13 PM   #13
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
lube
dick
ass
NATOR PA
Chimmike (06-27-2011)
 Old 06-24-2011, 11:47 AM   #14
Justin Lee's Avatar
Don't get me wrong I've never used a chinese knock-off, but I think it's mostly an uneducated guess on most peoples part who just want to jump on the bandwaggon of how all chinese turbos are made from recycled burmese soda cans and wont perform well, and will fail on you in a few miles.
There are numerous acounts of both fails and wins with these types of turbos, and from seeing some people I know use them and reading about it forum to forum it seems like its about 60/40 win to fail ratio but that raio seems to be growing further apart every couple of years (in favor of "win").
With the amount that you can save to take that sort of risk the risk vs reward is leaning heavily towards the reward, seeing as you can usually buy 4-5 (or even more) of these knock-offs for the cost of one genuine make.
Besides I'm not looking to put it on my 08 MS3 , but on my 1990 626 gt I bought for $600. Not that I havent thought about putting one of these on the MS3.
 Old 06-24-2011, 12:46 PM   #15
aaronc7's Avatar
Groans: 370
tons of guys on miata turbo run china turbos with great success. they won't spool as fast as a DBB garrett of course...but when you factor in the cost, it's hard not to consider them.
For a cheap car/project on a budget, sure why the hell not. A lot of guys seem to blow oil the oil seals, at least on Miatas, so guys just run an oil inlet restrictor and all is good. Not sure how oil pressure is on the 626 vs miata, but something to keep in mind.
Report: Cops pull over 100 cars en route to Monticello Haltech Automotive News 1 11-20-2010 11:53 AM
Jackson Body En Route to Staples Haltech Celeberty Smut 0 07-07-2009 10:50 AM
Cool Airbox and Snorkle re-route Kennosuke Custom Performance Engineering (cp-e.com) 6 12-22-2008 10:47 PM
Penske Racing transporter goes up in flames en route to Infineon Haltech Automotive News 0 08-21-2008 09:50 AM
Page generated in 0.34667 seconds with 28 queries
