![]() Join Date: Dec 2017
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score I just got my bnr s4 in and when I was emailing a company to dyno tune my car I asked them how I could drive it there with the new grimmspeed 3 port boost controller and they told me to run it off of wastegate till I get there. How would I do that? I emailed them back about five days ago asking how to do that and they never responded. |
| The Following User Says NO Thank You to Clay46 For This Un-useful Post: | MD1032 (08-08-2018) |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score The turbo runs off of the exhaust gasses so the waste gate lets the exhaust out. This causes the turbo not to spool and you get pulled on by that grinning soccer mom in a mini van from a light. You know the one with the kids in the back giving you the finger while laughing... The waste gate has a spring in it that keeps the exhaust gasses running thru the turbo until a particular amount of boost say... 14 psi is reached. This is called spring pressure. That means any boost over 14psi starts letting exhaust gasses spew out into the ehaust bypassing the turbo., This makes the turbo sad and slow once again. When you get tuned the tuner uses boost pressure to hold the wastegate shut longer and make many soccer moms sad and left in the dust.
FWIW if you are asking us what to do instead of this"shop" then you may want to ask yourself why you are going to them in the first place. Get a Etune here.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra | |
| The Following 4 Users Say Thank You to 5doorsoffury For This Useful Post: |
![]() Join Date: Jan 2017 Location: Buffalo NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score the turn around time for the base etune is usually a day or two. Ive never waited weeks for the base tune.. Revisions to the new maps can take longer after you send in your logs, about a week
__________________ 2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned 2011 mazda 6 |
Groans: 211
| Not Ranked : 0 score The only people I would EVER let dyno tune my car are the E-Tuners on here. If you are lucky enough to live close to them when they are available then that's the quickest way. Otherwise, pick any of the same E-tuners on this forum and you will get your base tune within a day or two like has been already stated. They know this platform better than any shop that tunes Evos and Subarus.
![]() Join Date: Jul 2017
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score If you want to bypass the boost controller and run spring pressure you just have to run a boost line between the turbo discharge and the wastegate. |
Why are you reviving an old thread? In doing so, you dragged MSMS3 with you. Shame shame.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) | |
| The Following User Says Thank You to Fstrnyou For This Useful Post: | MSMS3 (02-18-2019) |
| Not Ranked : 0 score i hope he find out by the time elapsed between the question and your answer...
![]() Join Date: Jun 2009
| Not Ranked : 0 score just unplug the two pin plug on the ebcs.
| Defective turbo or wastegate? | Speed3Pedro | MazdaSpeed 3/6 - Turbo Induction | 1 | 07-29-2017 10:59 AM |
| Any wastegate options that will fit ms6 stock turbo!? | Ms6ownersblike | Mazdaspeed3/6 General Discussion | 7 | 04-06-2016 08:21 PM |
| For You BT/Turbo Noobs - I haz Wastegate? | helmetface | MazdaSpeed 3/6 - Turbo Induction | 9 | 09-20-2011 06:20 PM |
