 Old 03-05-2009, 10:36 PM   #1
johnac08's Avatar
Posts: 141   (View Stats)
johnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud of
Default how much boost can your stock turbo hold?
just wondering how your stock turbo performs.
mine tapers 15psi after 5500 rpms.
johnac08 is offline   Reply With Quote
 Old 03-05-2009, 10:40 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
what are you doing here?
speed3 (03-19-2009)
 Old 03-05-2009, 10:55 PM   #3
wassup61's Avatar
Posts: 1,232   (View Stats)
Stock turbo can hold about 18 psi before running out of its efficiency range.
-Jeff at PG
All wagon, No traction
 Old 03-05-2009, 11:00 PM   #4
johnac08's Avatar
just trying to compare it on mine.
mine cannot hold 18psi after 5000rpm it goes down to 15. even how i set my sb
i also have full control flash
 Old 03-07-2009, 04:24 AM   #5
Doc
Doc's Avatar
Posts: 526   (View Stats)
Doc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the world
Groans: 35
at 6k im at around 17..
Doc is offline   Reply With Quote
 Old 03-07-2009, 05:06 AM   #6
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
try the search button
y2kc0wb0y is offline   Reply With Quote
 Old 03-07-2009, 07:23 AM   #7
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groaned at 86 Times in 65 Posts
you need to play with your PID boost settings
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 03-07-2009, 07:34 AM   #8
spheed3's Avatar
Posts: 487   (View Stats)
spheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond repute
We need a solid write up on those PID settings. I've read that toaster analogy a ton of times but the numbers still seem arbitrary to me...but I'm a lil slow lol.
Black Mica 08.5 GT
I'm parting out. Buy my stuff: http://www.mazdaspeedforum.org/forum/foru...ing-out-59908/
spheed3 is offline   Reply With Quote
 Old 03-07-2009, 07:46 AM   #9
wassup61's Avatar
PID tuning here
http://www.mazdaspeedforum.org/forum/foru...explained.html
 Old 03-07-2009, 08:37 AM   #10
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
most ive seen (at high rpm) is around 17.5 psi at 6500
 Old 03-07-2009, 08:56 AM   #11
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
here is how mine is set through 1st thru 3rd.
 Old 03-10-2009, 08:17 PM   #12
blackcherryspd6's Avatar
Posts: 35   (View Stats)
blackcherryspd6 is a jewel in the roughblackcherryspd6 is a jewel in the roughblackcherryspd6 is a jewel in the roughblackcherryspd6 is a jewel in the rough
Is there difference between an upgraded stock turbo or simply stock?
blackcherryspd6 is offline   Reply With Quote
 Old 03-17-2009, 08:54 PM   #13
ptperformance's Avatar
Posts: 4,123   (View Stats)
Huge difference, I will list them from out upgraded to stock.
SST:
Billet wheel (PTP exclusive) vs cast
clipped turbine wheel vs non clipped
ported exhaust housing, no port work
Ceramic on the SST, nothing on the stocker.
We take the time to upgrade the bearings and seals as well with the Mazda turbos as well.
Our upgraded stocker will allow 30 to 50 WHP gains to be seen over what the stock turbo makes. The billet wheel option is the only billet option on the market and if you have been in the know on turbos... billet is the only way to go now with the power numbers that some people are making with billet wheels.
 Old 03-11-2009, 08:32 AM   #14
wassup61's Avatar
Yes, there is a difference. A larger wheel, port and polished compressor/impeller housing and clipped exhaust wheel to increase response. The super stock turbo from Protege Garage flows about 35% more air, and is efficient up to about 25.5 psi, but really packs a punch and is very happy at 22 psi.
-Jeff at PG
 Old 03-17-2009, 08:49 PM   #15
With an upgraded WGA you can see as high as 18 psi at 6200 RPM on the stock turbo. With the SST we have seen as high as 23 psi at 6700 RPM with our WGA.
 Old 03-18-2009, 11:36 AM   #16
Haltech's Personal Bitch
PDXImportRacer's Avatar
Posts: 275   (View Stats)
PDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond repute
As soon as I get my Steedspeed mani I will have some #'s to show what Jon is talking about.
PDXImportRacer is offline   Reply With Quote
The Following User Says Thank You to PDXImportRacer For This Useful Post:
LBV (03-18-2009)
 Old 03-18-2009, 01:12 PM   #17
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
19 psi in the mid-6000's here:
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
Whats stock whp, tq and boost on MS3 Jasnall Mazdaspeed3/6 General Discussion 24 07-12-2017 04:01 PM
Stock boost tube size? bf360 MazdaSpeed 3 - Engine, Transmission & Driveline 0 02-03-2009 08:59 PM
Lower peak boost after Turbo Inlet install 802MS3 MazdaSpeed 3/6 - Turbo Induction 22 01-16-2009 06:54 PM
Big Turbo, Stock Boost Control Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 30 12-30-2008 04:57 AM
turbo effeiciancy = boost temp? gsrtype1 MazdaSpeed 3/6 - Turbo Induction 24 10-08-2008 09:43 AM
Page generated in 0.37593 seconds with 32 queries
