 Old 03-06-2009, 12:41 AM   #1
bast525's Avatar
Posts: 487   (View Stats)
bast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default How much is really safe...
okay, my car is almost completely stock. Only mods are an MS CAI with airflow straightener, and an Accessport. I've tried many different maps, beta's and official release, and most of them have either dissappointed with poor performance, or felt quick but had other issues like causing knock.
I found one map that I really like, KR is non existent, car runs very strong, overall the best map I've tried out of probably a dozen. My only concern is that this map tends to hold the boost kind of high in the upper RPM. Down low it seems fine, I spike 19-20 psi, quickly settle to high 17's, and then the boost holds very steady, from 16.5 to 17.5 psi depending on the weather and what gear I'm in. So it's not too high for the most part. It's right where I want it.
The problem is it just keeps holding it, all the way to redline, it is still around 17 psi. Now, I don't WANT to push as hard as I can, I don't want to be on the ragged edge, please don't misunderstand... this is just the way the map does it, but it just so happens to do everything else much better than other maps I've tried. If I could custom tune, I would run this exact map but drop boost to like 16 psi by redline. Normally, I shift at 6100 rpm anyways, but every so often I'm not paying attention and will run to the rev limiter, and it's times like that that I'm worried about.
I am worried that for a mostly stock car, 17.5 psi above 6000 rpm is going to have EGT's too high or is going to stress the turbo, but I dont' know this for sure, so I hope someone here can give me a better idea if this is risky or not. If I have to choose between an awesome running car with a greatly shortened life span on the engine or turbo, or a not-so-awesome running car that is more reliable in the long haul... well I guess I will have to go back to another map.
Additional info: air/fuel ratio is steady at ~11.5:1, timing advance at 6500 rpm is 13 degrees, and KR for the whole run is 0. Do you guys think this is safe with boost at 17.5 psi at high rpm? Can I keep running this map safely?
'07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune.
bast525 is offline   Reply With Quote
 Old 03-06-2009, 02:40 AM   #2
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
You have somehow achieved somehing wonderful. Dont complain about it. If it aint broke dont fix it.
TRU-BOOST is offline   Reply With Quote
 Old 03-06-2009, 09:31 AM   #3
bast525's Avatar
lol man trust me I dont want to stop running this map, but isn't that boost just too high for my mods?
 Old 03-06-2009, 10:02 AM   #4
speedtown's Avatar
Posts: 533   (View Stats)
speedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the world
you should be safe, if you were spiking well above 20 then you should start worrying, most people spike about 18-19 (with out any mods) and settle in around 15ish, you're not really pushing much more boost than that. I think I saw some where else someone with similar mods settle in around 12, but of course they weren't to happy about it!
Like truboost said you got something solid going for you don't F it up! lol
speedtown is offline   Reply With Quote
 Old 03-06-2009, 10:54 AM   #5
bast525's Avatar
yeah the spike I'm not worried about at all, it's the boost at high rpm, 5500+ that I'm worried about. Some little voice inside me telling me that 17.5 psi at that high rpm is just too much.
 Old 03-06-2009, 11:12 AM   #6
GFish's Avatar
Posts: 286   (View Stats)
GFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond repute
no that is fine i hold strong till red line with the ap
__________________________
2008.5 Mazdaspeed 3 GT Crystal White Pearl Mica
mods:30% tint front 2 windows 20% all other windows, clear bra on front and custom peace covering rear bumper, corksport mm inserts, and some other good stuff
GFish is offline   Reply With Quote
 Old 03-06-2009, 11:22 AM   #7
your fine. with no knock u should be extremely happy
 Old 03-07-2009, 10:18 AM   #8
elsinc01's Avatar
Posts: 6   (View Stats)
elsinc01 is an unknown quantity at this point
Are you settling in around 17.xxx psi and spiking above?
17.xxx psi is fine.. Be happy!
elsinc01 is offline   Reply With Quote
 Old 03-07-2009, 10:58 AM   #9
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
The key is no knock ... if the egt's go too high the knock will set in. As long as you've got a warning on the kr you should be good.
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 03-07-2009, 10:55 PM   #10
wassup61's Avatar
Posts: 1,232   (View Stats)
No knock = good to go. Stop worrying for now!!!
Also check your email.
-Jeff at PG
All wagon, No traction
 Old 03-08-2009, 12:14 AM   #11
Doc
Doc's Avatar
Posts: 526   (View Stats)
Doc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the world
Groans: 35
no dramas at all.. i run something similar.. i just spike more
Doc is offline   Reply With Quote
 Old 03-08-2009, 12:41 AM   #12
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
You are fine, 17.5psi with a cai as your only mod is no problem. If you had a turbo back exhaust, full intake, manifold, and ported heads and your stock turbo was holding 17.5psi I would not only throw the bs flag and would tell you to turn it down. As you are is fine though.
2006 Mazdaspeed 6
Am I safe? Stage 2 v1.03 Final Matrix311
Cobb Access Port/Maps
37 04-22-2011 07:52 PM
Are the mazdaspeeds safe when modded? booya620 MazdaSpeed 3 - Engine, Transmission & Driveline 35 02-01-2009 06:51 PM
Will this be SAFE? SLOMS3 MazdaSpeed 3/6 - Wheels & Tires 4 09-27-2008 11:44 PM
uping boost safe? bombdotcom MazdaSpeed 3/6 - Turbo Induction 2 06-09-2008 12:24 AM
SentrySafe FIRE-SAFE Combination Safe (1.2 Cubic Ft) $143.97 Haltech Hot Deals Section 0 03-28-2008 07:40 PM
Page generated in 0.34866 seconds with 29 queries
