  • 1 Post By Agent_Orange
 Old 06-19-2015, 11:11 PM   #1
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Default HTP 3' intake fitment
I've been trying to look around and search for fitment with this intake. I've seen people post they were able to fit it on a gen2 without having to go smaller battery box/smaller battery. Have anyone with a gen 1 had such luck? If it's just not possible I'll go with the ecu relocation kit rather than the whole box/bat replacement. But I'm just hoping people have made this badboy fit with stock box/bat.
HaXiR is offline   Reply With Quote
The Following User Says NO Thank You to HaXiR For This Un-useful Post:
Pu Manchu (06-20-2015)
 Old 06-19-2015, 11:31 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
I heard those 3 foot intakes can be difficult to tune.
PurplFox likes this.
The Following 11 Users Say Thank You to Agent_Orange For This Useful Post:
brandon3212 (06-20-2015), Code Monkey (06-20-2015), Easter Bunny (06-20-2015), g00s3y (06-21-2015), ItsNox (06-21-2015), littleloogy (06-20-2015), Pu Manchu (06-20-2015), SarcasticOne (06-20-2015), speed23 (06-20-2015), speedfreak44 (06-20-2015), tegxsi (06-20-2015)
 Old 06-20-2015, 01:53 AM   #3
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Mine fits fine on a k04
Did have to remove the lower ECU cover tho...
 Old 06-20-2015, 01:56 AM   #4
HaXiR's Avatar
Well I'm going with the BNR stage 3. The htp listing on edge says it wouldn't fit, but im not sure if that's Gen 1 or 2? It would seem obvious but if people have fit it from a BNR just fine then maybe its possible?
 Old 06-20-2015, 02:43 AM   #5
Mastertrixter's Avatar
Posts: 386   (View Stats)
Mastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the world
I have a bnr s3 and htp 3". Fit ok with ecu in stock location. Minus the bottom cover. Just for the extra room I moved my ecu to the fuse cover thpugh and it leaves plenty of room
2011 speed 3
BNR s3 v2
snow performance wmi
dammon occ, egr deletes
htp 3"
cx piping with tr6 core
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
jbp ssp, weight, bushings, rmm, and rsb
koni oranges with road magnet springs
motegi mr116 18x8 +45
Powered by PURPLE DRANK
350/360 vdyno cf 1.01 on 91 pump only
Mastertrixter is offline   Reply With Quote
 Old 06-20-2015, 01:16 PM   #6
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
fit on my k04 no problem after removing the lower ecu cover
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
 Old 06-20-2015, 01:23 PM   #7
Quigs's Avatar
Posts: 1,152   (View Stats)
As people have said, it will fit just fine on the k04 with the lower ECU cover removed. I have heard that people have made it fit with a BNR, but I don't see how there was any spare room on my car and also a buddies car. On mine the intake was rubbing the ECU pretty significantly.
I relocated my ECU to inside the battery box anyway to make room for ease of working in the engine bay and for if/when I ever go BT. The easier option would be to move it to the top of the fusebox or just buy a small battery box if you don't want to modify the stock box to get it in next to a 51r.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
 Old 06-20-2015, 01:34 PM   #8
Raiders Bitch
Shampu's Avatar
Posts: 803   (View Stats)
Fit just fine on my car with the lower cover removed. Just like everybody in here has said and it says on HTP's website.
Instagram: Genpu_Drew
235/40 Pilot Super Sports
Tuned by Nishan
25% E85
 Old 06-20-2015, 11:37 PM   #9
HaXiR's Avatar
Ya well I'm going BNR s3, and trying to avoid having to buy a whole new battery and box...
 Old 06-20-2015, 11:39 PM   #10
You won't have to. Move ecu or at least bottom cover from the ecu.
And that on the s3. Trust me. See sig for why.
2011 speed 3
BNR s3 v2
htp 3"
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
 Old 06-20-2015, 11:45 PM   #11
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
get your shit together, OP, reading isn't that hard
94 M
MS6
IS350
The Following User Says NO Thank You to Pu Manchu For This Un-useful Post:
HaXiR (06-26-2015)
 Old 06-21-2015, 06:04 AM   #12
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Move the battery to the trunk, problem solved.
 Old 06-26-2015, 02:26 PM   #13
HaXiR's Avatar
I did read that, I'm pretty sure I even stated that. I'm still asking if people here have made it work regardless of what that says. Because some people have made it work on a Gen 2, and a couple have said on Gen 1. Thanks for the input
GT2871r and intake fitment issues. Ey34nEy3 MazdaSpeed 3/6 - Big Turbo Builds 15 04-15-2015 11:17 AM
rim fitment Jeremy M 2010 MS3 - Wheels & Tires 6 06-19-2014 08:34 AM
fitment lifeneverlasts MazdaSpeed 3/6 - Wheels & Tires 45 07-14-2013 06:46 PM
cpe TIP fitment, test pipe fitment dhsieh911018 Gen2 MS3 General Discussion 2 03-06-2012 03:34 PM
fitment help mczimer MazdaSpeed 6 - Engine, Transmission & Driveline 6 02-10-2012 09:58 AM
Page generated in 0.33402 seconds with 29 queries
