![]() Join Date: Aug 2011 Location: Boerne, TX
Rep Power: 112 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
(Thread Starter) | Not Ranked : 0 score Have new on order, but my question is this. If I get it sealed without the spring, is it safe to drive gently until new arrives? Is there a better safe option? I need the wheels...
__________________ _____________ 2006 Platinum MS6 GT zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI |
| Not Ranked : 0 score Post a WTB for a used stocker, they go for like $25.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (08-13-2014), Tres3 (08-09-2014) |
(Thread Starter) | Not Ranked : 0 score Thanks very much for the reply. I have the new one covered, but in the mean time, can I drive it (gently), if I seal up the broken one without the spring in it? It will vent all the time, right? If I stay out of boost, will that make the ECU screw anything else up? (My AP is on the way now too.)
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score maybe a local has a used one laying around you could borrow for a few days, check your nator section
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| The Following 2 Users Say Thank You to mxlplx71 For This Useful Post: | Easter Bunny (08-13-2014), Tres3 (08-09-2014) |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I wouldent risk it. Might turn a quick fix into something major. You can rent a car for a few days for fairly cheap |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score Duck tape that bitch back together And i ain't even playing
__________________ it's fun to do bad things Last edited by jack_hammer; 08-13-2014 at 09:20 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score |
| The Following User Says Thank You to littleloogy For This Useful Post: | SpencerC (08-15-2014) |
![]() Join Date: Jul 2013 Location: Orlando, FL
Groaned at 6 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score Actually went with epoxy. Held until new one got here. Thanks for the help.
| The Following 2 Users Say Thank You to Tres3 For This Useful Post: | jack_hammer (08-15-2014), SpencerC (08-15-2014) |
| Not sure what I broke.. | kylejenson | MazdaSpeed 3/6 - Turbo Induction | 6 | 08-08-2014 10:43 PM |
| This broke | mazdaspeeding | Mazdaspeed3/6 General Discussion | 10 | 01-04-2013 05:47 PM |
| Think I broke it | Zai_MS3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 30 | 08-25-2011 12:44 AM |
| So I think I broke something | OMGWTFHAX | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 02-28-2010 04:23 PM |
