 Old 03-06-2013, 06:45 PM   #1
08cosmic3's Avatar
Posts: 2,920   (View Stats)
Default I need a new recirculate hose. Options?
I'm not paying SU $59 for a hose. I can't seem to find anything on this although I'm sure it's out there in a thread somewhere.
 Old 03-06-2013, 06:46 PM   #2
CtrlAlt1337's Avatar
Posts: 149   (View Stats)
CtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the worldCtrlAlt1337 is the leader of the world
JBR has them for $35
2012 Silver Speed3
SLOWEST PU IN THE SOUTH
HTP 3.5'' Intake w/ Battery Tray - CPe 3.25'' TMIC - AT Internals - Turbosmart Dual Port BOV
SURE RMM/PMM
- UR CBE - CS Boost Tubes - Cobb AP - ebay Downpipe - Guardian Angel
NGK Iridiums - Matt Damon OCC
Stratified.
CtrlAlt1337 is offline   Reply With Quote
The Following 2 Users Say Thank You to CtrlAlt1337 For This Useful Post:
08cosmic3 (03-06-2013), bstover17 (03-06-2013)
 Old 03-06-2013, 06:55 PM   #3
08cosmic3's Avatar
That's a much better price but I'm thinking there has to be a $10 fix.
 Old 03-06-2013, 07:45 PM   #4
Spiral1183's Avatar
Posts: 250   (View Stats)
Spiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the worldSpiral1183 is the leader of the world
Find out the size of the hose and go buy some at Autozone
2007 Black Mica Mazdaspeed6 GT - Stockness
Spiral1183 is offline   Reply With Quote
The Following User Says Thank You to Spiral1183 For This Useful Post:
ABolewski (03-06-2013)
 Old 03-06-2013, 07:54 PM   #5
jm211's Avatar
Posts: 943   (View Stats)
A straight hose should work...The issue is its not a straight line of sight from A to B, as you already know
Although the hose only recirculates BPV air so I cant imagine a small bend of the hose will make any difference should you buy a straight one....I even the SU sells cheap colored hosing. Granted they charge 40$ for it.
 Old 03-06-2013, 07:54 PM   #6
ABolewski's Avatar
Posts: 1,279   (View Stats)
Agreed. I believe it's 1.25"? Maybe that's way Samsonite but for some reason I think that's what I measured.
Any tubing will work…
(sold)
 Old 03-08-2013, 05:21 AM   #7
Mistersix's Avatar
Posts: 2,585   (View Stats)
I had a similiar issue over the summer when i did my FMIC and needed a quick temporary fix. The problem is the size, or i.d. is not very common but heres what i made work.
The biggest coolant hose you can buy from a local auto parts store is 1" i.d. Even though its rubber it won't stretch around the fittings so i took a dremmel with a stone grinder bit and reamed out about an 1/8-1/4 inch about an inch deep into the hose. I then heated it up with a heat gun. With a little muscle it went on the bpv and recirc fitting with out issue.
But its rubber. So once it gets hot it starts to kink. Easy enough though. Get some worm clamps and clamp a bunch of worms to it.......J/k. tighten the clamp where the kink is and the worm clamp will keep it round. you may need more than one.
It doesn't look pretty but its the cheapest temporary fix i could come up with. And i scoured the web for a solution and found what you found. 30-60 dollar hose's.
Hope that helps ya.
 Old 03-08-2013, 06:02 AM   #8
JBR molded to fit.
rfinkle2 (03-08-2013), SLOWHATCH (04-10-2013), Vader (03-08-2013)
 Old 03-08-2013, 09:30 AM   #9
Ziggo's Avatar
Posts: 3,843   (View Stats)
I made one out of some samco hose. It wasn't cheap but the shit is bullet proof
Zigatapatalka
Ask Me About My:
 Old 03-08-2013, 09:31 AM   #10
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Made one out of coolant hose from Vatozone for $7
A thread for this, really?
The Following 2 Users Say Thank You to helmetface For This Useful Post:
Mistersix (03-08-2013), Spiral1183 (03-08-2013)
 Old 03-13-2013, 04:27 PM   #11
Coaststarlight's Avatar
Posts: 296   (View Stats)
Coaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the world
$12-$15 Fix:
Buy some heater hose or radiator hose from Home Depot or VatoZone, just a straight piece of proper diamitor
And a Brass 90'Degree elbow from Low's or home depot, and 2 extra worm clamps
Take the hose with you so you can check the size you'll need
Cut about a 2-2 1/2 inch off the hose, use that to connect the elbow to the BOV
Take whats left of the rest of the hose, cut it to proper length, and connect that to the elbow at one end and to the TIP Recirc tube at the other, done
You may or may not need the elbow, I forgot if that's needed for the BOV in the stock location, but if the hose needs to bend to the point that you might cause it to kink you can use a 90 degree like I did OR a 60 degree if its not that harsh of a turn depending on where you BOV is mounted
Long Block Built by GPwerks and Loose Screw Motor Sports
https://www.gp-werks.com/
http://www.crossoverauto.com
^Any Parts, Great Prices^
Last edited by Coaststarlight; 03-13-2013 at 04:27 PM. Reason: MSF Database - Automerged Doublepost
Coaststarlight is offline   Reply With Quote
 Old 03-13-2013, 04:34 PM   #12
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Hoover Vacuum hose? The wife may get upset though.
Nator is what it does.
Hose barb cap and factory oil cooler hose dia 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-07-2010 12:19 PM
My options for a new recirculation hose ms3ftmfw Mazdaspeed3/6 General Discussion 8 10-30-2008 08:16 AM
Page generated in 0.34235 seconds with 30 queries
