 Old 05-15-2009, 07:15 AM   #121
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I will try a 900rpm idle map and hunt down some 5w40.
-- Mario Andretti --
 Old 05-15-2009, 07:17 AM   #122
Tiz
Tiz's Avatar
Posts: 15   (View Stats)
Tiz has a spectacular aura aboutTiz has a spectacular aura aboutTiz has a spectacular aura about
The only mods i have are hacked air box with kn filter, forge, and test pipel
I first noticed smoke at the autox at extended idle. Changed to rotellat 5w40 and stoped for a few months, Then the race pipe was installed and smoke city. THe next day i checked the oil level, a little over the full line when hot, drained some oil and after a week the smoke hasnt returned< i also removed a shim from the forge to compensate for the extra breathing and all is good so far.
Oil level is critical in these cars being that the pcv box is so close to the oil level.
Tiz is offline   Reply With Quote
 Old 05-15-2009, 07:18 AM   #123
bnoon's Avatar
Posts: 1,770   (View Stats)
Just an FYI for you guys, I've done a 900 RPM idle and run 0W-40 Royal Purple and I still smoke. Not as bad as the lower idle, but still there enough to make a cloud.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following User Says Thank You to bnoon For This Useful Post:
Fobio (05-15-2009)
 Old 05-16-2009, 01:14 AM   #124
Driver
Fobio's Avatar
Groans: 44
so I've tried the 1.03L beta map tonight, with upped idle to 900 and it's good! 10 minute idle, no smoke...mind you, there could still be some, but I couldn't see any smoke...good enough to not draw attention during the commute...plus, with the upped idle, the car PURRS...win-win!
on another note, I've sourced some Euro 5-40 synth...will report with more details when I get it in the car.
 Old 05-16-2009, 06:50 AM   #125
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
yes as tiz said oil level is critical as i proved this once even with 5w40. i had put 5.5qts of 5w40 in and drove around for a month with no smoke, i then added about .3qts and just like that i had minor smoking.
The Following User Says Thank You to bova For This Useful Post:
Tiz (05-16-2009)
 Old 05-17-2009, 06:07 PM   #126
btstarcher's Avatar
Posts: 4,852   (View Stats)
I have no clue what oil was used, but I just noticed white smoke at idle. Barely noticable but it was there. Dammit. I've had this car for less than a week...lol
 Old 05-21-2009, 07:18 PM   #127
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
i installed my downpipe 2 days ago and it smokes like a mofo idling
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 05-21-2009, 07:52 PM   #128
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
It sucks dont it..Is it a catless DP?If so have a high flow cat welded into your racepipe to try and stop the smoking,or hide it.
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 05-21-2009, 09:06 PM   #129
Miembro
Groans: 27
exhaust depot catless dp
 Old 05-21-2009, 09:07 PM   #130
Miembro
Groans: 27
so you guys say that by changing to 5w40 oil the problem may disappear? im going to change my oil soon so it would be a good idea..is anyone smoking with the spin on oil conversion kit? planning on doing that too
 Old 05-22-2009, 04:58 PM   #131
SharkDiver's Avatar
The spin-on kit will not make a diffrence in smoking or not.Just try the 5W40 oil and add a oil CC and see if it stops,If not try putting in a high flow cat.
 Old 05-22-2009, 05:18 PM   #132
stormin84's Avatar
Posts: 128   (View Stats)
stormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the world
If you have the ATR you may want to up the idle speed to 900 rpms, it has worked for me on clearing up the smoking and i believe it worked for another member too.
Falken FK-452 | 215-40R18 | Konig Hotswap |35% Tints| Greddy TT| Cobb Sri| Cobb Shifter| Cobb AP| Cobb Springs| Cobb RSB | Cobb Inlet Pipe |TS BOV |Dashhawk| COBB FMIC |CPE MM|CPE DP|
STILL TO COME: |Whatever I can get my hands on before she kills me|
stormin84 is offline   Reply With Quote
 Old 05-22-2009, 06:20 PM   #133
Miembro
Groans: 27
i dont have the ap...*sigh* but i will try the 5w40 for sure. thanks guys
 Old 05-22-2009, 08:26 PM   #134
Street Sleeper6's Avatar
Posts: 37   (View Stats)
Street Sleeper6 has a spectacular aura aboutStreet Sleeper6 has a spectacular aura about
man, i just quit smoking cigarettes, and now my car just started smoking! I put on a magnaflow cbe yesterday, and got big time blue smoke just today. i have had a test pipe on for months with no smoking. not sure why it would smoke, its not much of a diameter increase in the exhaust. it seems to be coming out of the left muffler primarily. mainly at idle, and after its been sitting for about 3 minutes. almost sounded like it started smoking when the fan came on? im hoping its just new parts and to give a few days. i checked it again later and the smoke seemed white?? weiird. otherwise i'll try the oil 5w40 a try if it dosent go away.
i also have a forge bpv (blue with 1 shim). did you notice improvements with no shims? or how many shims/color ring?
Deano ('06/MS6/6spd)
COBB AccessPORT-custom stage 2 map • COBB turbo inlet tube • COBB CAI • AWR motor mount • H&R springs • race Pipe • Forge BPV • Enzo plugs • magnaflow cbe • badgeless grill • sharkfin antennae • RX8 wheels
Street Sleeper6 is offline   Reply With Quote
 Old 05-22-2009, 08:39 PM   #135
 Old 05-22-2009, 09:03 PM   #136
kgb
kgb's Avatar
Posts: 808   (View Stats)
Groans: 88
Be careful man...looks like the smokes getting to ya....
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
 Old 05-23-2009, 10:53 AM   #137
sorry for the double post. apparently i cant see ANY of my posts, but you guys see two..so im typing in the dark here. i'll delete one when i can see some buttons or something forum moderator, whats up??
just put in 5w 40 Castrol syntec fully synthetic oil. see how that does. couldnt find PP anywhere
 Old 05-24-2009, 12:40 PM   #138
BentClamps's Avatar
Posts: 51   (View Stats)
BentClamps will become famous soon enoughBentClamps will become famous soon enough
Sorry if anyone hit on this already, but could the smoking simply be overfilled oiled? Turbo cars have a good bit of extra shit for oil to drain from, not to mention if some of the places aren't at a point which allows a good gravity drain. Also Dipsticks aren't exactly scientific measurement tools.
BentClamps is offline   Reply With Quote
 Old 05-24-2009, 12:41 PM   #139
kgb
kgb's Avatar
Groans: 88
To stop my smoking I went from 5w-30 to 10w-30 but some have done 5w-40. I also have an Access Port and used the ATR tuning software to up my idle to 900. I have a turbo back exhaust and all is good!
 Old 05-24-2009, 04:53 PM   #140
ok, so i've done alot of reading since i started smoking. i have a couple of Q's.
1. if you are smoking, and the problem quite possibly being the turbo seals, and you use a thicker oil and CC and that stops it from smoking, is that kind just putting a band aid on the real problem? i mean, its quite possible it could be stopped, but if it is the turbo seals and its under warranty, then wouldnt it be best to get it replaced? or does the cc and oil mend it before it hits the seals?
would i be losing any power by keeping the same turbo with cc/oil to stop the smoking vs. a new turbo?
2. if i decide to take my car into mazda to get the smoking checked out, do you think my catback w/ test pipe and CAI (i can put my oem bpv back on) left on will be ok in terms of not voiding warranty?
 Old 08-12-2009, 01:14 PM   #141
Default heading to dealership friday
well, my car started smoking immediately after putting on my magnaflow cbe. i had a race pipe previously with no problems. tried running 5w-40 with no luck. still smoking.
im going to put my bpv back to stock, and put my cat back in place of the race pipe before i take it in on friday morning. only mods i'll have is AEM intake and cbe (thats engine related). hoping that wont be an issue considering mazda sells similar parts. a pipe is a pipe.
car is still under warranty. 22k miles. i found MTOL 5505 referenced here: http://www.mazdas247.com/forum/showt...hp?t=123748050
hoping by passing that on to the dealer will help.
i've got all my oil change records as well. any other info i can arm myself with that before i go in?
thanks,
 Old 08-13-2009, 07:25 AM   #142
SharkDiver's Avatar
They may give you shit about your cbe but that depends on your dealer. With all the smoking problems they may just replace it with no guestions asked. It all boils down to how your dealer is with mods.
 Old 08-14-2009, 05:29 PM   #143
well fellas, took it in and good news.
they were able to replicate the smoking issue.
they changed my oil to a heavier oil (which i already had).
the called mazdausa and they said i will be getting the new pcv valve system when it comes out. not sure on when that will be.
if i still smoke after that, then will be a turbo replacement.
that was the official reply from mazda.
initially on the phone the guy said the cbe would void my warranty, but they didnt say a word about my mods. roger beasley mazda austin dealership is mod friendly.
i'm going to check back with them next week and see where they are with the pcv system
 Old 08-16-2009, 06:50 PM   #144
AirDale's Avatar
Posts: 10   (View Stats)
AirDale will become famous soon enough
I have a cobb dp and a cpe exhaust.. after i installed the dp there wasnt any smoke.. the white smoke only appeared after about 2 min of running the engine at idle directly after i put the new exhaust on.. and it was a lot of smoke.. smelt like burnt fire works.. and i waited a week or so to see if maybe the exhaust was burning some corrosion preventative inside the exhaust.. still major smoking when sitting at stop lights.. its embarrassing.. I talked to street unit and they said the reason why i couldnt see the smoke before the new exhaust was cause the old exhaust has lots of restrictions on it and absorbed most of it.. with the new exhaust it has a free flow right out..
I guess my question is.. Is this the bad seal in the turbo? And would just totally replacing the turbo with an upgraded one solve the problem?
thanks for any input
AirDale is offline   Reply With Quote
 Old 08-16-2009, 07:33 PM   #145
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
check this thread out
http://www.mazdaspeedforum.org/forum/foru...rning-fix.html
Speedn3 is offline   Reply With Quote
 Old 08-20-2009, 04:21 AM   #146
AirDale's Avatar
Cool thanks man
 Old 09-25-2012, 07:23 PM   #147
CamSpeed360's Avatar
Posts: 793   (View Stats)
CamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the world
Groaned at 31 Times in 13 Posts
I plan on it. But its out of warranty. And the service guy told me to be prepared with receipts of oil change records. I do.my own oil.changes and I throw receipts in the garbage.
2007 Black Mica MS3
JBR 3.5 Whale Penis Intake = Cobb V2/Treadstone FMIC = PTP HPFP internals
Snow Meth Injection, AIS 5GPH = TurboXS Downpipe/Racepipe = SSP-OCC
Road Magnet Springs = Bilstien B8 shocks = Cobb RSB = SURE RMM
Tuned by the FREEK
CamSpeed360 is offline   Reply With Quote
 Old 09-25-2012, 07:25 PM   #148
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
holy hell...
The Following User Says Thank You to speed_freak91 For This Useful Post:
bayarea_pat (09-25-2012)
 Old 09-25-2012, 07:35 PM   #149
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
did you post this in the wrong thread? the post before yours is 3 years old...
apropos your comment: if you don't have receipts, you can have them take off the valve cover and inspect the cams and such. if the car has been taken care of, it will be clean and shiny in there. if not, it'll have sludge and caked on crap.
also, i posted on your thread about this, the smoking turbo warranty was extended to 70k miles, no time limit.
edit: yes time limit. the warranty was extended to 7years/70k miles.
The Following User Says Thank You to tddvrrn For This Useful Post:
CamSpeed360 (09-25-2012)
 Old 09-25-2012, 07:38 PM   #150
My tapatalk does this all the time. That was supposed to posted on an entirely different website. But thanks for the advice.
FapaCalk
2007 Black Mica MS3
Tuned by the FREEK
 Old 09-25-2012, 07:39 PM   #151
Groans: 34
Thought it was 7 years 70k miles? Or is that the VVT?
tddvrrn (09-25-2012)
 Old 09-25-2012, 07:40 PM   #152
tddvrrn's Avatar
Groans: 103
shit you're right, forgot about the 7 years part.. i'm off to edit my posts. thanks for catching that.
 Old 09-26-2012, 08:56 AM   #153
I plan on it. "Jody White really fucked me at the Parr stealership this week"
2007 Black Mica MS3
Tuned by the FREEK
 Old 09-26-2012, 09:21 AM   #154
I really wish my.tapatalk would stop posting shit in this thread. Sorry.
2007 Black Mica MS3
Tuned by the FREEK
 Old 09-26-2012, 10:16 AM   #155
7 years from the manufacture date.
I will talk to Mazdausa and see what they say.
2007 Black Mica MS3
Tuned by the FREEK
My turbo was replaced under warranty last month and it's smoking again!! BlackMS3 MazdaSpeed 3/6 - Turbo Induction 34 07-26-2008 09:34 PM
UPDATE: No more smoking! Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 47 06-10-2008 07:33 AM
PCV - most likely cause of smoking bova MazdaSpeed 3 - Engine, Transmission & Driveline 40 06-04-2008 01:36 AM
Columbia House DVD Club Membership 7 DVDs for $.49 Each at Columbia House DVD Club Haltech Hot Deals Section 0 04-16-2008 09:40 AM
Page generated in 0.53933 seconds with 35 queries
