 Old 06-07-2009, 06:16 PM   #1
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
Default Installed CAI and now only have 10psi of boost
I installed my Mazdaspeed CAI yesterday and took it out for a test drive. It felt slower and I was not very pleased. I took it back and reset the ECU hoping that would help, but it didn't.
Double checked the MAF and even cleaned it - nothing.
The car is stock, so I wasn't sure what to look for. The previous owner had an aftermarket BOV on the car ( I can see where it rubbed the hood) and I think he used extra hose on the stock BPV. It had got pinched under the Intercooler cover.
Fixed that and I'm off and fast again.
Just letting others know in case it happens to them.
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
 Old 06-07-2009, 06:49 PM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
hmmm..not sure why u called this "installed ms cai and now i have only 10 lbs of boost" seems that one thing had nothing to do with the other.....maybe next time u call this thread. "bought a car from an asshole that pinched a bov hose"
D-Rick21 (06-07-2009), nyghtryder (06-08-2009)
 Old 06-08-2009, 01:57 PM   #3
Wide tire man
dbrier's Avatar
Because I pinched the hose.
Car ran fine, CAI intake went on, then only 10 lbs of boost. The hose became crushed when I put the IC cover back on.
MS6: finally installed my fvcking boost gauge m4tic MazdaSpeed 3/6 - Car Audio & Electronics 51 02-16-2014 04:09 PM
Installed new intake, now having boost problems LateralSpeed Miata - Forced Induction 3 07-13-2010 05:03 PM
Boost a pump installed TRU-BOOST MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 58 03-26-2009 03:40 PM
took off mbc and only seeing 10psi b-ron MazdaSpeed 3/6 - Turbo Induction 2 07-29-2008 11:01 PM
Page generated in 0.24030 seconds with 21 queries
