![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 111
Groans: 56
Groaned at 43 Times in 21 Posts
(Thread Starter) | Not Ranked : 0 score Install went very good. I work at Dinan so I had access to lift and all the tools. Got lots of help from the techs. keep bitching about my car that is not a M3 blah blah blah. i have a leak in the exhaust so i am going to weld it on Monday when i go to work. 2008 with 6,000 miles. I dont care. Fuck the dealer and the warranty. I'm just gonna buy the hybrid turbo when is done. I dont need 30r turbo too much for me. |
| The Following 2 Users Say Thank You to speed3 For This Useful Post: | driver311 (03-28-2008), occschemguy (04-02-2008) |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Nice, Im guessing the stock modified turbo is gonna break the heart of some of the guys with the big turbos. LOL I cant wait for mine.
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
Groans: 56
(Thread Starter) | Not Ranked : 0 score yes sir. I mean your hitting 12's on stock turbo. So the the hybrid ine should get us in the 11's easy. For a FWD that is perfect. I would say 310-340whp. |
| Not Ranked : 0 score Im thinking 310-320whp on stock boost in my car, and 350whp on 20psi and race gas. Ill see how the dyno goes to decide if I wanna push it anymore. Im sure the turbo will be good for 24psi.
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score I am really starting to get concerned that 90% of the DP's on the market that smoke after install are this one. Why are all the turbo smoking after the install of the Turbos XS unit? |
| Not Ranked : 0 score |
| John,most people who install the Corksport or TXS unit see smoking. Its not the fault of any one company moreso, than the fault of the bad turbo seals. Since you are removing the big cat out of line, youre going to see that smoke big time.
There has to be something that is getting missed like EGT's or crank case pressures, something. I have an idea but not sure if it applies. Excessive back pressure can be keeping the turbo seals in place but when you get rid of that the CC pressure goes way up and pushes the seals out of the turbo, but you should see oil leaks if the CC pressure is that high. Something is just not adding up as to why all the turbo seals go away after the DP install. I would do some testing of the CC pressures but I just don't have the time. | |
| Well i removed the 2nd cat and my smoking became very constant after 5-15 seconds idling after seeing boost. I can only see how much more its exaggerated with a downpipe.
| Not Ranked : 0 score See that would tell me that its a back pressure condition in the CC. I have to check out the PCV issue and see if that line is filling up with oil. |
| What if i took a round metal plate, the size of the pvc line thats in the crank case and drilled a small hole? Would that give me my back pressure back to the CC?
| Not Ranked : 0 score Yes it would give you CC pressure but you don't want CC pressure, you want a vacuum in there if you can get it. This is whats confusing me. The turbo seal are a metal ring that take an incredible amount of pressure to either push out or overheat. I have no idea what the hell is causing them to start leaking but it has to be something that needs to be addressed before we get to many upgraded turbos out to people. I mean think about it, we can not have big wheel stockers leaking or burning oil. It can not be the turbo causing these issues, its something I am missing. |
Give you an example that relates to this. We were throwing on long tube headers on the cobras. The better designed ones were causing us to smoke and pull oil out into the exhaust.. After many hours of investigating, it came to be the oil was being pulled out of the valve seats.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
Maybe I will do some vacuum readings with the DP then the stock cated unit. Maybe the gauge will show some changes. | |
| My only concern with adding a breather to the valve cover is that unmetered air can enter the system. Remember, this happens with MAF cars and you need to be careful here. If it was speed density, i would of done this already. you know, i have a new breather i bought for the truck but never used. Im thinking it may fit the oil cap on the MS3.. I can try it and report my findings with AFR readings to match.
| T into the pvc line? That would be a small breather dont you think?
![]() Join Date: Mar 2008 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 804
__________________ There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior ![]() 35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential | |
| Not Ranked : 0 score Wrong type of back pressure. I am talking about before turbo back pressure. This is the type of pressure that builds up in your crank case. If that were to drop off all the sudden the you could end up with a vacuum condition that sucks the seal inward. When I made that post I thought someone would think I was talking about the after turbo pressures. Its not, it before turbo pressures that I am not concerned with. |
| Not Ranked : 0 score No it would be a small coversion T with a larger T coming off for the breather. They do have some very small breather filters out there that could work. I will be checking all this out tonight on the car and checking to see if I can get something work and cause the turbo seals to burn oil. |
| That would be a hot seller if it works.
| Not Ranked : 0 score my txs dp/ rp setup doesnt smoke.
__________________ On motor #3 Turbo #2 Now have a SSM 08 STi!! |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
my modded K04 is going on as soon as the corksport DP's come in to PG. i will be doing a catch can at that time too. PTP did you put to gether a can/check valve kit yet ? i would like one...at least the check valve anyways. | |
![]() | | #24 | ![]() |
Which CBE do you use and does it have a resonator?
![]() | | #25 | ![]() |
![]() Join Date: Mar 2008 Location: United States
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score You know.........I built a 10.6:1 393 stroker in my Lightning and didn't bother doing a windage tray. I DRANK oil through the damn PCV all the time. So I took off the PCV and ran an open breather. It stunk but worked. Shifting that SBF stroker at 6200RPMs created some crank case pressure. If you killed the PCV and just ran open breathers??????
__________________ 08 CBMS3 Daily driven. Modified:Maybe |
![]() | | #26 | ![]() |
On a mass air car, you need to fatten up the fuel where it leans out, especially during a gear change. Now on my 02, i fixed the PVC problem in a real inexpensive fashion. You take a dime, which fits the diamater of the passenger side pvc hose, and push it up about 1/4 up where the PVC valve from the pvc valve attaches from the valve cover. Than i replaced the factory PVC valve with one from a 1993 302 5.0l mustang. No more oil problem. A lot of guys were spending $350 on a setup consisting of dual catch cans, brass fittings and hoses.
![]() | | #27 | ![]() |
![]() Join Date: Mar 2008 Location: Kirkland, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groans: 87
| Not Ranked : 0 score Hey John do you have any suggestions for my setup? Obviously all of my plumbing is done, do I just need to install a check valve now? I can be the test car since mine is already smoking. I have Friday and Monday off of work if you want me to stop by and see if anything works to remedy this. |
![]() | | #28 | ![]() |
| Not Ranked : 0 score i have a PG race pipe and a chopped up stock CBE. i kept the muffler but got rid of the resonators. i just cant justify buying a CBE when i know it wont have any gains with that stock front cat in place. |
![]() | | #29 | ![]() |
![]() Join Date: Mar 2008 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 116
| Not Ranked : 0 score Bump. Any breakthroughs yet?
__________________ 2012 G37S; 7 speed paddle shifters 2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold 1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold |
![]() | | #30 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Groaned at 33 Times in 22 Posts
| Not Ranked : 0 score I would bet my first born that the issue is Oil Blowback into the Intake. I have a Catch Can on order and should be here next week. I don't see seals leaking to be honest, but I'm new to Turbos but not new to common sense. |
![]() | | #31 | ![]() |
| Yup, at this time, i totally agree with you.
![]() | | #32 | ![]() |
| Not Ranked : 0 score It didn't solve IDRVSLO's issue. He only gets a few drops of oil in his catch can http://www.mazdaspeedforum.org/forum/foru...l-smoking.html
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
__________________ 2012 G37S; 7 speed paddle shifters 2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold 1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold | |
![]() | | #35 | ![]() |
Now, man....If this catch can is the save all.........
__________________ 08 CBMS3 Daily driven. Modified:Maybe | |
![]() | | #36 | ![]() |
Groans: 56
(Thread Starter) | Not Ranked : 0 score If thats the case, I wont be needing a reworked ko4 after all. Just Cobb and thats it. I have try this my self. I really hope it works.
__________________ 2008 BM..MSCAI..8K HID..MAGNAFLOW CB.. <----- SOLDCurrent car: 1991 Sport 600 Z32. 487whp on 91 Octane |
![]() | | #37 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score Perhaps we should start a new thread detailing those with smoking issues, and whether or not the CC resolved them. If a high % of people resolve their smoking issue with CC's, then it's a high probability that was the main cause. (I'm sure a small amount of people might of actually had some seal issues, but I agree it can't be a large amount). |
![]() | | #38 | ![]() |
![]() Join Date: Mar 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 510
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score ahem...wasn't the A9L ECM from the 89 Notch LX Mustangs? I pulled one out of a wrecked 89 (along w/ the harness) back when I converted my old 88GT to MAss Air. Back on topic.. The catch can is a nice solution but we shouldn't have to run that. I'm curious to see how these rebuilt PG turbo's do in terms of smoking. I'd love to get a DP/RP but with all the smoke, it just isn't happening for a while. It sucks that we have to find a solution for a factory defect from either Borg-Warner or Mazda. |
![]() | | #39 | ![]() |
__________________ 2012 G37S; 7 speed paddle shifters 2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold 1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold | ||
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/installed-turbo-xs-downpipe-let-smoke-1188/ | ||||
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-31-2008 10:25 AM | |
| big turbo anyone? 3071r installed..... | mrlilguy157 | MazdaSpeed 3/6 - Turbo Induction | 443 | 10-13-2008 04:00 PM |
| GT35R turbo installed | whoosh@Realtune | MazdaSpeed 3/6 - Turbo Induction | 45 | 04-30-2008 08:45 AM |
| PG Manifold installed | SLS MS3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 25 | 04-04-2008 12:53 PM |
| HOLY FRIGGIN SMOKE(S) | Death-From-A-Mile | MazdaSpeed 3/6 - Turbo Induction | 71 | 04-02-2008 01:41 PM |
