 Old 02-28-2019, 10:32 AM   #1
ItalianSA's Avatar
Posts: 82   (View Stats)
ItalianSA has a spectacular aura aboutItalianSA has a spectacular aura about
Default JBR 3.5" Intake Speed 6 Fitment
Has anyone installed the JBR 3.5" Intake with the BNR S4 on the speed 6? The mounting bolt is way off and the vacuum nipple is crashing with the master cylinder. The BPV portion of the intake is also smashing the shifter cables (assuming this would've cleared if the nipple wasn't hitting the master cylinder). I figured for ~$300 this would be a painless install, but that's proven not to be the case. It's looking like fab work will need to be done to make this fit right.
Any insight on your install would be appreciated.
"Some say that his genitals are on upside down, and that if he could be bothered, he could crack the Da Vinci Code in 43 seconds... all we know is, he's called the Stig."
06 MS6
BNR S4
Corksport DP, Catback, HPFP Internals
Treadstone FMIC
ItalianSA is offline   Reply With Quote
 Old 02-28-2019, 02:17 PM   #2
Loophole35's Avatar
Posts: 59   (View Stats)
Loophole35 is just really niceLoophole35 is just really niceLoophole35 is just really niceLoophole35 is just really nice
You may have to trim the silicon coupler a bit, like to the point it lets the intake touch the compressor housing. But that may just give you room for the nipple the bolt hole looks way too off to ever line up. Contact JBR.
Take the coupler off and mock the intake in place and make sure it fits without the silicon. If it does, trim the silicon till it can be installed.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
Loophole35 is offline   Reply With Quote
 Old 03-01-2019, 03:34 PM   #3
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Sell it and get an HTP. Problem solved.
If you keep it, good luck with it. JBR...meh, not on my car.
 Old 03-02-2019, 05:52 AM   #4
LenSpeed6's Avatar
Posts: 164   (View Stats)
Does HTP only do small runs of intakes now? I check from time to time an it seems like 3/4 of everything is out of stock.
06 Speed6
White/Black interior
 Old 03-21-2019, 11:25 AM   #5
Oli
Oli's Avatar
Posts: 19   (View Stats)
Oli is an unknown quantity at this point
I was wondering the same. It looks like now the intakes are built after you order them. Says on their website.
Oli is offline   Reply With Quote
HTP 3' intake fitment HaXiR MazdaSpeed 3/6 - Turbo Induction 12 06-26-2015 02:26 PM
GT2871r and intake fitment issues. Ey34nEy3 MazdaSpeed 3/6 - Big Turbo Builds 15 04-15-2015 11:17 AM
HTP 3" TIP fitment 2eatV8everyday 2010 MS3 - Turbo Induction 13 10-19-2012 09:00 PM
Review: 2009 Audi A6 3.0T suits high-speed cruising to a "T" - or is that an "S"? Haltech Automotive News 0 07-01-2009 10:30 AM
Page generated in 0.25578 seconds with 25 queries
