 Old 12-12-2013, 04:28 AM   #1
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Default JBR Power Path St2 will work will with a MS CAI yes no
Just a semi rhetorical question if I want to keep my CAI yet start upgrading the intake system, this combination would work? CEL is 50/50ish?
Thanks for reading another brownie question of the day.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 12-12-2013, 11:27 AM   #2
Quigs's Avatar
Posts: 1,152   (View Stats)
You mean the just the turbo inlet pipe I assume. When you say Power Path stage 2 it implies both the short ram intake plus the TIP. Since you already have the CAI all you need is the TIP. It will work fine with no CEL. Don't break the nipple off your EBCS.
This has been covered 354657431861357354318743576 times on the forums by the way, just so you know.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
 Old 12-13-2013, 05:59 AM   #3
Marcus's Avatar
Thanks and yes I meant just the tip. Knew I should've searched when thinking about it today.
Stratified S-OTS maps for the JBR Power Path Intakes Lex Stratified Automotive Controls 284 07-18-2017 04:45 PM
Power Path Stage II vs K&N/HTP [R]usty Gen2 MS3 General Discussion 23 09-19-2013 03:16 PM
Jbr power path stage 2 hitting hood. McKinley 2010 MS3 - Troubleshoot/Diagnostics 9 07-03-2013 01:48 PM
James Barone Power Path SRI / TIP bhamitgeek JAMES BARONE RACING 12 05-19-2013 03:26 PM
JBR Power Path Stage 1 SRI swerv0428 JAMES BARONE RACING 0 03-08-2013 10:54 AM
Page generated in 0.24100 seconds with 21 queries
