  • 2 Post By anavrinIV
 Old 10-31-2013, 08:54 AM   #1
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
Default Jbr or sure or HTP ? 3.5 pcv system tube relocation ?
Im about to buy 3.5 intake for my beaner. I think its time to ditch the old ms3 cai intake can you guys list the benefits of htp vs sure vs HTP. Also can these intakes be bought as a package with harness and map ?if not wheres the best place to buy em. Seems I have a leak somewhere and can't get a proper maf cal so while I do a boost leak test I figure might as we'll upgrade the intake system.
tokoam is offline   Reply With Quote
 Old 10-31-2013, 08:58 AM   #2
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Benefits of SURE - Cullen eats penises. Red Bull.
Obviously the superior choice.
ABSpeed3 (10-31-2013)
 Old 10-31-2013, 09:02 AM   #3
This should be a flame-fest. you answered your own question by throwing in HTP versus sketchy brand of crap owned by a self-absorbed douchenozzle that has been banned from so many forums, SURE/SU is left with microregional and irrelevant pages that are desolate wastelands and ghost towns.
Most of their stuff has or will fail.
http://www.mazdaspeedforum.org/forum/foru...design-139503/
Last edited by Raider; 10-31-2013 at 09:02 AM. Reason: MSF Database - Automerged Doublepost
cshunter (10-31-2013), Spectrix (10-31-2013), TiGraySpeed6 (11-01-2013)
 Old 10-31-2013, 09:06 AM   #4
tokoam's Avatar
looks like me have mixed opinion's here..but raider dose have a good point as he listed Sure's fails
 Old 10-31-2013, 09:10 AM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
AND you fail at sarcasm.
JBR.
08.5MS3 and DoMiNic like this.
Blue Pu.
Chief_Wiggum (10-31-2013)
 Old 10-31-2013, 09:10 AM   #6
08.5MS3's Avatar
Groans: 89
 Old 10-31-2013, 09:10 AM   #7
What's the point of a lifetime warranty, if the company is no longer around, as well. Just sayin.
I would go to anyone else. HTP is an approved vendor, give em a call or PM em!
 Old 10-31-2013, 10:44 AM   #8
tokoam's Avatar
i just spoke to HTP and will place a order with them one reason i like theres better than JBR is that silicon can deforms with heat over time I have seen it with my own eyes with inlets ...can you please list the proper maf and harness i will need ? ... oh and on HTP site they have coupler selection listed is 3.5"-2.25" Reducer the correct size ? just want to make sure
 Old 10-31-2013, 10:48 AM   #9
DoMiNic's Avatar
Posts: 571   (View Stats)
DoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the world
Groaned at 8 Times in 7 Posts
I always see SURE/SU selling on Craigs List.. They are getting desperate. lol
TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned
Sold
08 FJ Cruiser Expo build in progress...
DoMiNic is offline   Reply With Quote
The Following User Says Thank You to DoMiNic For This Useful Post:
Raider (10-31-2013)
 Old 10-31-2013, 11:11 AM   #10
anavrinIV's Avatar
Groans: 63
Stock MAF, put in the new pipe. You know how to tune for this intake?
Blue Pu.
 Old 10-31-2013, 11:18 AM   #11
tokoam's Avatar
lex and I are still working on my tune but we hit a snag with this damn leak ...so I was instructed to do a leak test but since im going to pull out the intake to do a leak test on the inlet side why not replace it with what the bnr should really have which is why i thought of the upgrade here is my mafcal ...so you can see how skewed it is..
i found this article Stock Fitment 3 Bar Map Sensor Upgrade so to confirm since i plan on going meth or e85 in the future is why i choose 3bar base on this article i will need to cut maf harness and soder new pig tail connector for new 3bar sensor ?
 Old 10-31-2013, 11:46 AM   #12
Dont be shocked if OEM TIP is leaking, Mine was.
 Old 10-31-2013, 11:55 AM   #13
anavrinIV's Avatar
Groans: 63
You're mixing parts.
The MAF (mass air flow) sensor is what goes in the intake, the MAP (manifold absolute pressure) sensor is in the intake manifold. If you're going with a 3 bar MAP Matt Jackson makes a plug-n-play pigtail for the bosch sensor, I have links somewhere.
You use your stock MAF sensor in the new intake.
You'll also need to scale for the bigger intake (do a search for the correction factor) and tune for the bigger pipe.
Blue Pu.
 Old 10-31-2013, 12:06 PM   #14
manila's Avatar
Posts: 1,767   (View Stats)
BECAUSE...we all know that the clamp is hand tight on the OEM TIP.
'12 MS3 Black Mica w/ Tech
 Old 10-31-2013, 12:15 PM   #15
tokoam's Avatar
okay this is what i got in my cart
Bosch 3 Bar TMap Map Sensor with IAT
Bitwise Motorsports Bosch MAP Sensor Connector Mazdaspeed 3 Mazdaspeed 6
HTP 3.5" Intake System + 51R Battery Tray Combo Kit MS3
 Old 10-31-2013, 12:20 PM   #16
My clamp was actually all the way tight, floppy loose to the turbo for who knows how long.
 Old 10-31-2013, 12:28 PM   #17
anavrinIV's Avatar
Groans: 63
you'll have to tune for both the MAF and MAP. They are unrelated
Blue Pu.
 Old 10-31-2013, 01:00 PM   #18
tokoam's Avatar
order placed.....
 Old 10-31-2013, 01:13 PM   #19
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
your comments are clusterfucks of confusion lol
The Following 4 Users Say Thank You to breakfstincluded For This Useful Post:
Agent_Orange (10-31-2013), anavrinIV (10-31-2013), faeker (10-31-2013), Sid3wayS (10-31-2013)
 Old 10-31-2013, 01:42 PM   #20
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Op still is completely ignoring the fact that he's buying a upgraded map for no damn reason..... stock turbo can't even max out the stock sensor you just wasted like 100 on that sensor
Edit: I see prices have dropped a shit ton in price since I did mine
 Old 10-31-2013, 01:51 PM   #21
anavrinIV's Avatar
Groans: 63
OP also states he has an s3
Blue Pu.
 Old 10-31-2013, 06:49 PM   #22
tokoam's Avatar
Dude read my description I clearly mention I have a beaner !!!
Aka s3 that lex and I are tuning. .
 Old 11-02-2013, 08:32 PM   #23
Daily Driver
Nitr0EngiE's Avatar
Lmfao never heard of a beaner my bad I'll eat crow on that
Last chance to enter to win a Garage and Hardware Storage System from Flow Wall System! Haltech Automotive News 0 06-21-2012 10:10 AM
Page generated in 0.43613 seconds with 28 queries
