 Old 02-24-2013, 09:13 AM   #1
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
Default K04 OE Wastegate Actuator Question
CP-e thinks my WGA is toast after the rebuild. I guess I am getting boost creep. Does anyone know if Mazda sells just the WGA for the K04? I searched through the forums and only found aftermarket ones like Forge and Turbosmart. I have an inquiry to a Mazda dealership if they just sell the WGA. So far only as a complete K04 unit. Thanks in advance.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 02-24-2013, 10:09 AM   #2
I am sure you can find a used turbo for really cheap. What are the symptoms - post a log.
ASHMS3 (02-24-2013), Poohster (02-24-2013), Tomas (02-25-2013)
 Old 02-24-2013, 10:48 AM   #3
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
There's almost always a serviceable k04 for sale, or a BNRS3 for about the same price as a new OEM.
Tappin'
The Following User Says Thank You to ASHMS3 For This Useful Post:
 Old 02-24-2013, 12:15 PM   #4
Poohster's Avatar
Sorry, CP-e is dyno tuning my car and Sander has not given me the logs. I also need a new knock sensor. The car is still with CP-e. Just hoping someone sells a new WGA separate from the K04. Thanks for the replys, I will also look for a used one.I do have a used Forge WGA with a green spring that we can use as a last resort.
 Old 02-25-2013, 07:06 PM   #5
Poohster's Avatar
Anyone use a Turbosmart WGA?
 Old 08-24-2013, 09:54 AM   #6
Shanook's Avatar
Posts: 210   (View Stats)
Shanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond reputeShanook has a reputation beyond repute
did you ever replace yours?
Shanook is offline   Reply With Quote
 Old 08-24-2013, 06:03 PM   #7
Poohster's Avatar
Wow. a blast from the past. LOL!!! No I didn't. Found out that I had a small leak in my vacuum line that caused erratic behavior. So I am on the OE Wastegate solenoid and OE WGA. I have a used Forge WGA sitting in my garage and Grimmspeed WGA solenoid unplugged in the engine bay. Everything is working great.
Upgrade wastegate actuator EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 28 04-13-2014 12:08 PM
st wastegate actuator kmac Ford Focus ST Ecoboost - Turbo Induction 5 02-07-2013 03:24 PM
Page generated in 0.28105 seconds with 23 queries
