 Old 08-20-2009, 10:39 PM   #1
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Default K04 oil feed line & oil drain line
hey guys Im bout to install a pg reworked k04 but i wana upgrade the oil feed lines and oil drain line. Does anyone know where i get them for our cars. I did see a few kits on ebay for the K04 but they seem to be for vw. DOes anyone know what are the specs for these lines (length.diameter.fittings) ? Thanks
 Old 08-20-2009, 10:47 PM   #2
JumpingJackson's Avatar
Posts: 967   (View Stats)
i wouldnt bother with a stock turbo.. reworked or otherwise.
 Old 08-20-2009, 10:53 PM   #3
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
he already has a reworked pg turbo, he just wants to know if he can upgrade the oil/coolant return lines.
glocK23 is offline   Reply With Quote
The Following User Says NO Thank You to glocK23 For This Un-useful Post:
 Old 08-20-2009, 11:02 PM   #4
Tripple OG
NJSPEED3's Avatar
Groans: 113
not the coolant lines just the oil feed line and the oil return line. It is highly recomended when you replace a k04 with cooked seals. The oil feed line especially gets gunked up with burnt oil and restrict the oil path. So lines with possible wider i.D woulld be great!
 Old 08-20-2009, 11:54 PM   #5
Well its a pain in the ass because the fitting you need that comes off of the block for the feed line is very non-standard. Ask John @ PTP performance because he had to make me one for my S256
 Old 08-21-2009, 03:21 AM   #6
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I made drain line fittings for the Ko4 and the engine block so a -10 braided stainless hose could be used, but never tried them out, since I went to a ATP garret setup. I even made the nipples about 1.2 mm larger in hopes of letting the oil drain better, but this was before PTP came out with the solution to the PCV problem.....
 Old 08-29-2009, 11:02 AM   #7
bnoon's Avatar
Posts: 1,770   (View Stats)
The feed line on my 20K mile 08.5 GT does not have any problems at all with "gunk". Plus I've pulled apart 3 turbos now that supposedly had "cooked seals" and the seals are all within factory spec. Check the oil feed line out and show pics of the gunk if there is any. I would really like to see it because I doubt there is any.
Yeah, it's not the drain line itself that gets blocked, it's the pressure on the center cartridge that causes the oil/exhaust smoke issue.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following User Says Thank You to bnoon For This Useful Post:
Mazdamike2012 (11-04-2016)
 Old 08-29-2009, 11:16 AM   #8
after doing a turbo swap yesterday i cant even imagine finding another drain fitting that goes to the block
 Old 09-09-2009, 04:17 PM   #9
Tripple OG
NJSPEED3's Avatar
Groans: 113
yeah i did the turbo swap and pg mani a few weeks ago and the oil lines were clear and free of gunk. After installing the new turbo the smoke still persisted as well. Dat just tells me its the dam pcv system, seals on the k04 were fine.Now im waiting on ptp to send me that pill i lost the first one in the engine bay somewhere lol. But i dougt thats gonna work! Hopefully race roots has the solution
 Old 09-10-2009, 06:21 AM   #10
bnoon's Avatar
PTP's fix worked for me on my stock turbo that's been smoking for a year (since I got my TXS DP/RP combo). Almost makes me not want to put my damn SST in because it's been sooooo nice not smoking I just don't want to fuck with it right now.
2002 BMW M3 - Sold!
 Old 09-14-2009, 06:33 AM   #11
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
I'll be upgrading my turbo to a reworked soon. I won't have to drain the oil to disconnect the feed/drain lines for the turbo, will I?
vbt101 is offline   Reply With Quote
 Old 09-14-2009, 08:26 AM   #12
MSP6COP's Avatar
Posts: 323   (View Stats)
MSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the worldMSP6COP is the leader of the world
Groaned at 12 Times in 7 Posts
If you're that worried about them being gunked up (highly unlikely), take em off and clean them out. IT's pretty simple to do, though I wouldn't even think twice about ever doing that.
There's a few good how tos for installing turbos around here. You have to disconnect everything. Just make sure you clamp off your coolant lines so it doesn't spew out all over your engine bay. No worries about everything else.
Dyno (01/20/09)
Dyno (08/06/09)
I lost $925 to medieval read it HERE
MSP6COP is offline   Reply With Quote
 Old 09-14-2009, 10:46 AM   #13
vbt101's Avatar
I haven't been able to find any how tos on here. Can somebody point me to some?
3 Line Sig? badams118 Website Help/Feedback 2 12-02-2008 05:56 PM
Mr. Big Volume reaches the end of the line Haltech Automotive News 0 09-28-2008 10:20 PM
HKS Vac Line Question bykeryder4life MazdaSpeed 3/6 - Turbo Induction 17 09-12-2008 05:45 AM
Where to tap for boost other than the BPV line? ElBartoRex MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-21-2008 06:06 AM
Page generated in 0.32270 seconds with 28 queries
