 Old 05-07-2008, 12:26 PM   #1
enganear's Avatar
Posts: 197   (View Stats)
enganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the worldenganear is the leader of the world
I was watching my catalyst temp earlier today and it was routinely exceeding 820C. I am not sure how this relates to temperature in the exhaust turbine housing. The exhaust entering the catalyst should be cooler than the exhaust in the housing, but there is an exothermic reaction that occurs in the converter and I am not sure where the temperature is measured. If it was not such a pain in the ass, I would install a thermocouple in the housing as suggested. If I ever remove the turbo, I will definitely do this before re-installing.
-enganear
enganear is offline   Reply With Quote
 Old 05-07-2008, 12:28 PM   #2
-enganear
i thought the purpose of the catalyst was to heat up the unburned fuel, so the temp in that system is going to be higher since its a ceramic material?
 Old 05-07-2008, 12:32 PM   #3
enganear's Avatar
Yes, the converter is its own heat source and I would guess the sensor is somewhere near the center or end of the converter body. The temp at this point should be unrelated to the temp in the turbine housing. I was just surprised to see the temp so high under light loading.
-enganear
 Old 05-07-2008, 12:36 PM   #4
Are you using the DH to measure this temp? If so, i would say that PID is off.
 Old 05-07-2008, 12:40 PM   #5
enganear's Avatar
I was using my Auterra Dash Dyno. What are people seeing for catalyst temps with the DH?
-enganear
 Old 05-07-2008, 12:56 PM   #6
-enganear
Oh yes, i forgot you had one of those. Temps vary, from 600s to 900's. But the second you shut the car down, let it sit for a second, than turn it back on, the temp was higher than when it was running.
 Old 05-09-2008, 09:05 AM   #7
ptperformance's Avatar
Posts: 4,123   (View Stats)
-enganear
Coverter temp are high both before and after the converter. You will get readings that are higher 6 inches in front of the converter and 8 inches after. The pre inlet temps are elevated from radiant heat reflecting back up the pipe. I did a whole class on this crap and if you get under a car at idle with a good temp gun you can see what I am getting at.
You are also getting calculated temps, not actual temps. There is no temp sensor in our cats, its a guess at best.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/k04-turbo-report-neuspeed-5250/
Welche Leistung? - Seite 3 This thread Refback 05-16-2014 03:52 AM
Turboladerschaden 3MPS - Seite 5 This thread Refback 05-30-2013 12:46 AM
k04 information This thread Pingback 05-01-2011 06:07 AM
Who R the Si's Competitors? - Page 7 - 8th Generation Honda Civic Forum This thread Refback 02-11-2010 06:22 PM
COBBLE COBBLE? - Page 3 - MN Mazda Forums This thread Refback 05-07-2008 06:27 PM
COBBLE COBBLE? - Page 3 - MN Mazda Forums This thread Refback 05-07-2008 03:30 PM
COBBLE COBBLE? - Page 3 - MN Mazda Forums This thread Refback 05-07-2008 02:02 PM
COBBLE COBBLE? - Page 3 - MN Mazda Forums This thread Refback 05-07-2008 12:51 PM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
REPORT: 2010 Audi S4 to get supercharged V6 Haltech Automotive News 0 04-24-2008 08:40 AM
Intel’s Atom beats Via’s Isaiah – report Haltech Computers & Technology News 0 04-10-2008 03:00 PM
Report: Lite-On Working on Xbox 360 Blu-ray Add-on Haltech Computers & Technology News 0 04-01-2008 06:30 PM
REPORT: Audi R8 to get twin-turbo V10 power next year Haltech Automotive News 0 04-01-2008 10:00 AM
Page generated in 0.30304 seconds with 23 queries
