![]() Join Date: Mar 2008 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
(Thread Starter) | Not Ranked : 0 score The information below, gleaned from a B5 site, offers some insight into the limitations of the K04 turbo that I have not seen mentioned before. High temperatures and softening of the shaft could also be the root cause of some of the reported turbo problems and also may explain why Mazda intentionally pulls the plug on boost at 6k rpms. Is anyone measuring exhaust temp in the turbine housing? -enganear K04 TURBOCHARGER REPORT FROM NEUSPEED For those readers unfamiliar with the background of the 3K-Warner K04 turbocharger here is a brief summary of past events. The K04 turbocharger (manufactured by 3K-Warner GmbH) is sold as an upgrade for 1.8T engines by several international tuners, including NEUSPEED. In the United States, NEUSPEED has sold the largest number of K04 turbochargers in the aftermarket for use on 1.8T engines. Over the past two years, we documented 8 K04 turbocharger failures and reported this information to 3K-Warner�s United States importer, Dura Products Corporation in Bradley, Illinois. After validating the statistical significance of the failure rate, NEUSPEED suspended its sales of the K04 turbocharger, and with the assistance of Dura Products Corporation performed extensive testing to determine the cause of the failures. Based on our joint findings, we prepared this report to brief current K04 users, and potential users, on the proper installation, operation and maintenance of the K04 turbocharger to maximize its service life. 1. INSTALLATION Each re-seller of the K04 turbocharger is responsible for providing installation instructions. The following information is intended to supplement those instructions, not replace them. A. Always drain engine oil and remove old oil filter prior to removing existing turbo from the vehicle. B. Always inspect factory oil feed line to determine if line has become coked with oil residue. If the oil feed line has dark, hardened coating inside of it, discard the line and replace it with a new Audi or Volkswagen genuine part. C. After the K04 turbocharger has been bolted onto the manifold and oil feed and return lines have been reconnected, install new oil filter and use synthetic engine oil only. Mobil 1 and Redline are the recommended brands. 20/50w is recommend for summer. 10/40w is recommended for winter. D. Before restarting the engine for the first time, the engine, oil lines and turbocharger must be dry-primed with oil. To perform this procedure, first locate the Engine Control Computer (ECU) and disconnect the multipin connector from the ECU. Next turn the ignition to the RUN position and crank the starter motor in several 4-5 second bursts. (Your oil pump will circulate oil, however no spark or fuel will be introduced into the cylinder.) Next turn the ignition key to the OFF/LOCK position and reconnect the multipin connector to the ECU. Next turn the ignition key to the ON/POWER position, but do not start the vehicle. Leave this key in this position for at least 30 seconds. (This sends power to the ECU, but the engine will not be running.) Finally turn the key to the START position to start the engine. Allow the vehicle to idle for several minutes, then shut down the engine and check the oil level. Top off if necessary. 2. OPERATION The K04 is designed to provide reliable, long-term service as long as its performance parameters are not exceeded. Driving the car at engine speeds above 5800 rpm with 15spi or greater boost significantly increases the exhaust temperature measured inside the K04 turbine housing. This signals that the maximum efficiency of the turbocharger has been exceeded, and that the energy produced by the turbine housing is now converting to heat rather than accelerating the compressor wheel faster. Unless a careful and extended idle-down is performed at the end of every hard driving session, the rapid heat build-up from high boost/high rpm operation causes the turbine shaft to soften, and allows the inconel turbine head to droop. The result is an imbalance that ultimately leads to a shaft failure. A. NEUSPEED has revised its ECU programming to reduce K04 boost pressure above 5800rpm. Current K04 users are encouraged to contact their ECU software supplier and request this change. Existing NEUSPEED K04 customers will be offered this software upgrade at no charge. Peak horsepower, measured at 5700 rpm, is unaffected by this change. The reduction in high-rpm boost pressure lowers the peak turbine exhaust temperature to approximately 875�C. As long as peak turbine exhaust temperatures do not exceed 875�C, the K04 turbocharger should continue to operate reliably. B. We encourage K04 users to install an exhaust gas temperature probe directly in the turbocharger housing to monitor peak temperature during operation. Do not mount the probe in the exhaust manifold. Do not mount the probe in the exhaust downpipe. The measurements obtained in these two locations cannot be compared to the 875�C critical temperature. We recommend using the HKS EGT gauge and thermocouple, it reads from 500�C-1200�C. It is easily purchased from any HKS distributor and incorporates a Peak Hold Warning feature. To install the HKS thermocouple, you will need to remove your turbocharger and drill a 5/16� hole into the turbine side housing. Use a 1/8� pipe tap and cutting oil to tap threads into the hole. (We used Sears Craftman tap #9-54531) Thoroughly clean the housing and hole of all cutting debris, coat the thermocouple threads with anti-seize compound, and install the thermocouple. C. K04 users should always bring their vehicle to a complete stop and allow the engine to idle prior to shutting down the engine. Recommended idle times vary from 1 minute after mild driving, to 5 minutes after aggressive driving. The idle-down procedure circulates fresh oil and coolant through the turbocharger, allowing it to cool gradually, prior to shut-down. D. NEUSPEED also now offers a 5 bar fuel pressure regulator to be used in conjunction with the factory 235 CC fuel per minute injectors. The 5 bar regulator does not materially affect the turbine housing temperature. However, our testing showed that it does provides a more consistant Air/Fuel ratio during high rpm operation. 3. MAINTENANCE A. Engine oil and filter should be replaced every 3000 miles. Do not change engine oil without installing a new oil filter. Check your engine oil level frequently. The turbocharger shaft spins over 10 times faster than your engine�s crankshaft, so an adequate oil supply is critical. B. Periodically inspect the turbocharger to determine if the wastegate rod and hardware has been bent or damaged. The K04 wastegate rod comes from the 3K- Warner factory with a locking clip over the adjustment nuts. DO NOT attempt to recalibrate the wastegate by moving the adjustment nuts. Any tampering with the wastegate can dramatically alter the boost characteric of the turbocharger and lead to serious engine damage. C. In the event that any air intake hoses are removed or disconnected during service, thoroughly inspect every hose and remove any foreign objects or debris that may have fallen or collect inside the hose(s). Any loose objects inside the air intake tract may be sucked into the turbocharger upon start up, seriously damaging the compressor blades. |
| The Following 36 Users Say Thank You to enganear For This Useful Post: | bertrand_CX_7 (11-14-2011), Boosted Beluga (01-19-2012), BryanHills (07-27-2011), CMESCOOT (05-08-2008), Constantin (05-08-2012), Crossbow (05-08-2008), dadasracecar (05-07-2008), Dahouse702 (11-14-2011), dangrus303 (02-29-2012), dereeek (01-19-2012), digitaljedi (05-07-2008), DISIindahead (01-19-2012), Dre (03-29-2010), duthsman (02-02-2012), eljefe62 (01-09-2013), Finchee (08-07-2014), FreeFlyFreak (10-14-2009), Hamilton69 (11-14-2011), JacksonMS30 (03-15-2010), Jesse MS3GT (05-07-2008), justint5387 (12-27-2010), Koenig (01-28-2010), LakeSTLMS3 (01-20-2012), MidwestSpeed3 (05-10-2008), Mike@Stratified (01-22-2012), Moonpie.Express (02-16-2009), ms3077 (08-09-2009), NYpest (05-07-2008), OMGWTFHAX (10-24-2008), p057 (01-19-2012), redboat (06-18-2013), rfinkle2 (01-19-2012), RiceBurn2.3T (07-23-2012), scriccs (11-26-2010), TurboWagon (05-07-2008), Zeya (06-10-2009) |
| Door is THAT Way Mate ----> ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score There's several different K04s. The K04-001, K04-021, K04-022 and I think there was a 023. I don't know how this factors in. |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score Wondering the same thing. Hell there have been KO-4 ran clear back into the 80's. Why all the sudden is there an issue? Or is it just our car that has these issues? |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score I wish I could find a definitive turbo map for our turbo. I don't think that one that everyone likes to post up is right. We would be getting surge at 3000RPM if it was right, or I am reading it wrong. |
What someone needs to do (I have but not releasing it) is get before and after turbine housing pressures. This will give you an idea for pressure ratios from turbine to compressor. Then you can calcualte off the inducer and exducer of larger compressor wheels to find the correct clip and relative (calculated) pressures. This is where the homework needs to be done to find the failure points in our turbo. I would do it but I am having enough issues with finding cores for the big wheel units that I don't want to buy new units to do more testing. The dealer has them on back order last time I checked anyways. | |
| Not Ranked : 0 score Thats ridiculous. I could probably build everything I needed to create a good test setup for less than 5k. The choke point isn't too terribly difficult to figure out using theory and I wouldn't expect it to be too far off. The Surge really has to be tested though. I have never heard of a turbo running out of steam at the top end like these are claimed to due to efficiency problems. Reaching the choke point sure, but never hitting a wall like this due to efficiency. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,016
| Not Ranked : 0 score WOW great work !!! |
| Good work Enganear!
(Thread Starter) | Not Ranked : 0 score I was watching my catalyst temp earlier today and it was routinely exceeding 820C. I am not sure how this relates to temperature in the exhaust turbine housing. The exhaust entering the catalyst should be cooler than the exhaust in the housing, but there is an exothermic reaction that occurs in the converter and I am not sure where the temperature is measured. If it was not such a pain in the ass, I would install a thermocouple in the housing as suggested. If I ever remove the turbo, I will definitely do this before re-installing. -enganear |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
-enganear | |
| Are you using the DH to measure this temp? If so, i would say that PID is off.
You are also getting calculated temps, not actual temps. There is no temp sensor in our cats, its a guess at best. | |
![]() Join Date: Mar 2008 Location: Monterey Park, ca.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
Groaned at 51 Times in 34 Posts
| Not Ranked : 0 score Great work, this is useful information, I will review it in depth tonight with my mechanic (roomate, lol). Thanks. I really am enjoying all the usefull information on this forum, I have learned a great deal about our car.
__________________ 2008 speed3- FOR SALE!!!!!!!!!!!!!!!!!! SEE HERE! http://www.mazdaspeedforum.org/forum/forum/f665/2008-speed-3-sale-177096/ 2000 Honda S2000(track car) |
![]() Join Date: Mar 2008 Location: Charlotte, N.C.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Thanks for the info! I had a good amount of Neuspeed products on my GTI and all were great.
__________________ 2008 Cosmic Blue Mica Mazdaspeed3 Sport Mods: Removed Dealer Sticker, Rubber Floor Mats, K&N Filter (OFF), TWM Shifter Bushings, Pennzoil Platinum 5w-30 Full Synthetic (Due @ 27350), "TWM", "Zoom-Zoom" & "Mazdaspeed" Vinyl Stickers, First Aid Kit, Mazdaspeed CAI (ON), RPMC Turbo Inlet (ON), THULE Trunk Organizer, 93 Octane Fuel, Continental ExtrameContact 225/45's Build Date: 08/07 | |
| The Following User Says Thank You to TurboWagon For This Useful Post: | 4-timer (07-11-2010) |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score I'd have to disagree with the extended idling. It's a water cooled turbo. Even with the engine shut off, coolant is still going to circulate through the turbo...the whole water cooled turbo system was developed to prevent turbo turds, or baking of the oil in the turbocharger. I'm not saying its bad to let the car idle for a bit...but excessively is a bit silly, unless you just finished a 25 minute track session. I think most of us are smart enough to not shut the car off in the middle of a 6,000 rpm 5th gear run. TurboByGarrett.com - Turbo Tech101
MS6 K04-2280 compressor plot | |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
Yeah true but what neuspeed was saying that the shaft droops when the shaft is not rotating and when it cools it causes the shaft to deform. If you keep your car running the shaft will still rotate and will not droop and will harden in a non deformed state. But anyways all this means is that our turbocharger is pretty much at and exceeding the design limits, and the range of the ms3 turbocharger probably exceeds maximum efficieny. And neuspeed inspected these cases primarily on the 1.8t engine. Given our engine 2.3L and DI, (flow is important not pressure) the efficiency is even more surpassed at 15psi and 5800 since our engine should flow more at that boost. But we already knew that the ms3 turbo is undersized. | |
![]() Join Date: Nov 2011 Location: Sumter, SC
Rep Power: 0 ![]() Thanks: 0
| The Following User Says Thank You to Mrmatt3465 For This Useful Post: | Reijin (01-19-2012) |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs | |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score good write up... I am glad to say I obsessivly ALWAYS let my car idle a while before i shut her off, though its prob not needed unless your on the track or a long highway run. The car manuel sais let the car idle for a while after a long highway trip or going up a long hill.
__________________ |
![]() Join Date: Mar 2008 Location: Earth
![]() They replace the turbine shaft with a light-weight one...though I don't know what material its made from... Are there any concerns there... So no matter if its the stocker or reworked, you'll still be limited to 6K RPM range with this turbo... I wonder how the reworked compares to the stocker in terms of failure, reliability, and efficiency... ![]()
__________________ 2008 Stage 3 Roush Mustang 302E 5.0L Stroker 647rwhp-620 rwtq | |
No reason for the LW shafts because of the clipping taking away so much material (if they clip theres). That is still TBD, no one has been able to run the turbo out past that due to the throttle closing. Compairison from us will be coming soon. Keep an eye out in our section. | |
![]() | | #24 | ![]() |
![]() Join Date: Apr 2008 Location: Lutz, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
| Not Ranked : 0 score same argument i have with people when i call turbo timers 'rice mods'....water cooled turbochargers aren't as fickle as people make them out to be. i agree with crossbow. but nice to see some info on it. if some of it is true about the shaft and such, that kinda sucks. looks like alot of people will be forced to upgrade sooner or later.
__________________ Dan - '08 MS3, some kinda silver |
| The Following User Says Thank You to ispypsi For This Useful Post: | Sadisticlollipop (02-04-2013) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Very good info. No doubt that removing exhaust restrictions (before, in, and after the turbo) will help bring these temps down. Also, I hadn't considered that it is possible we are hitting choke flow limits in the turbine; however, I wouldn't be surprised given the noted small turbine/housing. |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | ptperformance (05-22-2008) |
![]() | | #26 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Winter springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,251
Groans: 974
Groaned at 738 Times in 373 Posts
| Not Ranked : 0 score I'm happy with the turbo they chose for this car. Plenty of grunt down low / midrange where it needs to be for daily driving, I love the effortless passing at only 3k rpms. |
![]() | | #27 | ![]() |
![]() Join Date: Jun 2008
| Not Ranked : 0 score good post, thanks for the info |
![]() | | #28 | ![]() |
![]() Join Date: Nov 2008 Location: Taxachusetts
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score If they went with a bigger turbo, blown motors would more than likely been a bigger issue than Mazda would have been able to deal with.
__________________ 2008.5 True Red Mazdaspeed3 pretty much stock. Rally Armor URs, Weather Tech Floor Liners, and Hankook iPikes on 16" steelies for winter. |
![]() | | #29 | ![]() |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score not really since we don't have a defiant answer why the engines blow.
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
![]() | | #30 | ![]() |
![]() Join Date: Feb 2009 Location: Dupont wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
| Not Ranked : 0 score great job |
![]() | | #31 | ![]() |
![]() Join Date: May 2009 Location: Weston, FL
Rep Power: 0 ![]() ![]() Thanks: 9
| Not Ranked : 0 score If the K04 is undersized for MS3s. Can anyone recommend a more appropriate upgrade that can handle 350hp? |
![]() | | #32 | ![]() |
![]() Join Date: Jan 2009 Location: San Antonio, TX.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 212
Groans: 90
Groaned at 69 Times in 21 Posts
| Not Ranked : 0 score GT2871 should do fine. |
![]() | | #33 | ![]() |
| Banned ![]() Join Date: Sep 2009 Location: La Crosse, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
| Not Ranked : 0 score good info |
![]() | | #34 | ![]() |
| Banned ![]() ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score i like the stock k04 |
![]() | | #35 | ![]() |
![]() Join Date: Jan 2010
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score really good info |
| The Following User Says NO Thank You to phong3992 For This Un-useful Post: |
![]() | | #36 | ![]() |
Rep Power: 371 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score yea nice job, enganeer yea nice job, enganeer
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount Last edited by flyrevs2; 01-16-2010 at 09:08 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #37 | ![]() |
![]() Join Date: Feb 2010 Location: Harrisburg PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Cool, I always thought it was good for any turbo to have a "cool" down period before shutting down...anywayz, i was looking around the internet and the forums trying to find the specs of the the k04 that we have in our cars..anyone know?
__________________ 2008.5 Black MS3 GT -- Cobb SRI, Cobb Inlet, Cobb Downpipe, Denso ITV22, JBarone Stage 2 Short Shifter Plate, Sure Torq R3 RMM, PTP HPFP, PTP PCV Pill Maverick: I feel the need... Maverick, Goose: ...the need for speed!!!! -TOP GUN |
![]() | | #38 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score i dont know if this has been posted before but i couldnt find it via the search....i believe this is our compressor map |
![]() | | #39 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score Nice Info on the K04. After going through my last logs a lot of stuffs start making sence to me. Sad that some knowledgable members around here keep helpfull info for them self and friends. Brownies like my self really appreciate the efforts. Nice job man keepp on with the good work.
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. |
![]() | | #40 | ![]() |
![]() Join Date: Jan 2012 Location: Long Beach,Ca
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Has anyone thought of the difference in airflow between the 1.8T and MZR engine? You can't say you shouldn't rev your engine past 5800 rpm unless you are aware of the difference in airflow at that rpm related to the amount of boost. FYI Hypertech claims the EGT peaks at 800C on the stock tune, and peaks at 833 on their tune. Remember boost is not airflow. cfm numbers can very greatly at the same boost level between two motors. This information pertains ONLY to the 1.8T Volkswagen motor. I worked in the VW tuning industry for 10 years. There are so many versions of the K04 it will make your head spin. The current TSI motors from VW are making 300+ horsepower to the wheels with a VERSION of the K04. I guarantee it is not the same one used in our Mazdas. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/k04-turbo-report-neuspeed-5250/ | ||||
| Welche Leistung? - Seite 3 | This thread | Refback | 05-16-2014 03:52 AM | |
| Turboladerschaden 3MPS - Seite 5 | This thread | Refback | 05-30-2013 12:46 AM | |
| k04 information | This thread | Pingback | 05-01-2011 06:07 AM | |
| Who R the Si's Competitors? - Page 7 - 8th Generation Honda Civic Forum | This thread | Refback | 02-11-2010 06:22 PM | |
| COBBLE COBBLE? - Page 3 - MN Mazda Forums | This thread | Refback | 05-07-2008 06:27 PM | |
| COBBLE COBBLE? - Page 3 - MN Mazda Forums | This thread | Refback | 05-07-2008 03:30 PM | |
| COBBLE COBBLE? - Page 3 - MN Mazda Forums | This thread | Refback | 05-07-2008 02:02 PM | |
| COBBLE COBBLE? - Page 3 - MN Mazda Forums | This thread | Refback | 05-07-2008 12:51 PM | |
| First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo | Haltech | Automotive News | 2 | 05-04-2009 06:48 PM |
| REPORT: 2010 Audi S4 to get supercharged V6 | Haltech | Automotive News | 0 | 04-24-2008 08:40 AM |
| Intel’s Atom beats Via’s Isaiah – report | Haltech | Computers & Technology News | 0 | 04-10-2008 03:00 PM |
| Report: Lite-On Working on Xbox 360 Blu-ray Add-on | Haltech | Computers & Technology News | 0 | 04-01-2008 06:30 PM |
| REPORT: Audi R8 to get twin-turbo V10 power next year | Haltech | Automotive News | 0 | 04-01-2008 10:00 AM |
