 Old 02-17-2014, 01:48 PM   #1
TrunkMonkey's Avatar
Posts: 21   (View Stats)
TrunkMonkey is a jewel in the roughTrunkMonkey is a jewel in the roughTrunkMonkey is a jewel in the roughTrunkMonkey is a jewel in the rough
Default K0422-881 and K0422-882 differences?
So I did a search and found that he CX-7 has a different turbo but the mazda speed 3 and speed 6 turbos seem to get lumped in together. So my question is since they have different part numbers what are there differences. I'm assuming mazda wouldn't have seperate numbers for the same turbo. The reason I ask is my speed 6 needs a new turbo soon and I have found a turbo from a 2013 speed 3 for sale locally.
Thanks.
Da Cream Puff
TrunkMonkey is offline   Reply With Quote
 Old 02-17-2014, 02:33 PM   #2
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Speed3 and Speed6 have same turbo. The CX-7 K04 is different.
K04 Differences: K0422-582 vs. K0422-881 / K0422-882
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline   Reply With Quote
The Following User Says Thank You to MattJackson86 For This Useful Post:
ms6mil (02-17-2014)
 Old 02-17-2014, 03:09 PM   #3
If they are the same turbo why do they have different numbers?
Da Cream Puff
 Old 02-18-2014, 09:41 AM   #4
Sooooo anybody??? Why are there different numbers for these turbos if they are the same?
Da Cream Puff
 Old 02-18-2014, 12:46 PM   #5
Google search those part numbers and see what shows up. Found this, not sure if its right, but it makes sense:
K0422-882 for EU
K0422-881 for Japan and USA
 Old 02-22-2014, 09:54 PM   #6
So if I put a speed 3 turbo 882 on my speed 6 881 I will loose about 13hp or so?
Da Cream Puff
 Old 02-22-2014, 10:07 PM   #7
speed23's Avatar
Posts: 1,480   (View Stats)
Go ahead and use the turbo you found locally. K04s from speed3's have been used on speed6's many many times, including by myself. They're the same regardless of numbers. There will be no change in hp. Just dont use Cx-7 turbo.
 Old 02-22-2014, 10:27 PM   #8
I sure hope it works. Mine sucks down about a quart a
Month. I got a turbo from a 2013 speed3
Da Cream Puff
 Old 02-22-2014, 11:03 PM   #9
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
If it sucks a quart/month it may be the exhaust valve seals, not the turbo. I'm not sure if a leaky/smokey turbo can burn that much oil...
Ans since you're replacing your turbo why not go for something a bit larger (BNR, GTX)? Even on stock intake/exhaust and with upgraded fuel pump internals you will be better with a larger turbo.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-22-2014, 11:12 PM   #10
Hmmmm maybe. We shall see. I can't go bigger. My other turbo project takes all my money.
Da Cream Puff
 Old 02-23-2014, 05:25 PM   #11
torquemaniac's Avatar
Posts: 733   (View Stats)
The 582 (CX-7) as smaller exhaust A/R and compressor wheel than both the 881 and 882
I once took apart a 582 (CX-7) and 881 (MS6) side by side, and two difference I saw is the journal bearing design and the oil inlet banjo (the CX-7 banjo as a smaller oil passage)
Maybe Mazda made some change to the turbo at some point to prevent the smoking issue (by restricting the oil intake and altering the journal bearing design for the lessen oil pressure)
881 may be the old version, and 882 the new version?
Anyhow, before I put the MS6 turbo in my CX-7, I rebuilt it with the original journal bearing (the two version are included in the rebuilt kit), and put the turbo on the car with a MS6 banjo bolt (bigger oil inlet hole)... a while after, I begin to have smoking issue
The minute I put the CX-7 banjo bolt back, the smoking issue was gone (the CX-7 banjo as a small opening like the Bnoon bolt)
Maybe you just need a rebuilt (with the new journal bearing design) and Bnoon bolt?
2011 CX-7 AWD 2.3 turbo
Gen 1 vs Gen 2 piston and rod differences Lex MazdaSpeed 3 - Engine, Transmission & Driveline 42 08-14-2019 02:43 PM
K04 Differences: K0422-582 vs. K0422-881 / K0422-882 BAT-man 2010 MS3 - Turbo Induction 92 12-07-2016 09:02 PM
any differences between K04's? btstarcher MazdaSpeed 3/6 - Turbo Induction 5 04-09-2013 04:52 PM
Going from 93 to 91...what kind of differences will I see Stangcobra MazdaSpeed 3/6 - ECU Computer Tuning 16 09-13-2012 07:29 PM
Gen 1 - Gen 2 differences? steedspeed 2010 MS3 - Turbo Induction 15 11-05-2010 08:44 AM
Page generated in 0.30812 seconds with 24 queries
